it is a mess. How to neat it up? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-29-2020, 03:29 PM - Thread Starter
NHOFFMAN's Avatar
Hi there,
This is in a house. The network room is in the business side.
How do I neat this up so at least we can install the drop ceiling grids to save electrical bill.
Any suggestion is appreciated.
I am lost!
Thank you
ID:	2718692   Click image for larger version
NHOFFMAN is offline
post #2 of 3 Old 04-30-2020, 07:05 AM
oktoberrust11's Avatar
Quoted: 104 Post(s)
Liked: 53
Looks like it was started with good/neat intentions, then the "next guy" came in and didn't follow anything, all downhill from there. Do you have an overall pic that shows the relation between the 2 points where the ladder rack attaches to the walls?
Remove the T-bar from the drop ceiling grid. For any wires that aren't following the main/velcro'd path down to the rack, I would see if there is slack to route the cables to the main bundle. If not, you'll need to remove the termination from the patch panel/wherever it goes and re-route. You may need to extend some cables with a "Consolidation Point;" 1 is allowed per run. You may find that some cables are not terminated to anything.
Cut out all those zip ties and replace with Velcro once you're done. Cut out the ceiling tiles where the main bundles come down.
Matt
My Area: Samsung 75" Q9FN / Marantz NR1608 / Polk Signature S55 / Xbox One X / PS4 Pro | Living Room: Samsung UN55LS03N ("The Frame" 2018) | Family Room: Sony XBR-65X850E
Nuvo Player Portfolio Whole-Home Audio System (P4300, P200, P10 keypad, P30 tablet)
Xbox Live: oktober rust | PSN: oktoberrust11
oktoberrust11 is offline
post #3 of 3 Old 04-30-2020, 07:12 AM
DAK
DAK's Avatar
Liked: 109
Hold on while I buy some stock in Velcro cable ties. ...OK, go.
DAK is offline
Reply Home A/V Distribution
