Nuvo & iTunes Playlists - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-30-2020, 12:34 PM - Thread Starter
djjefft's Avatar
Looking for some Nuvo users to help with a challenge I am having with playlists with my my Library music.
I am using a Nuvo system that I had installed when we built the house just over 2 years ago. We currently have four P3100 units and I am using 11 zones at the moment.
I have a Win10 PC with iTunes and my ripped library of 20,000+ songs that i use Nuvo Music Share to have the ability to use my mp3's on the Nuvo system.
My 8 year old PC took a dive and I had to get a new PC and get things rolling again. I am at the point where I can play my library on the system again, but the playlists no longer convey to the Nuvo system. Nuvo says its a Apple thing, which I believe, but there has to be a work around. They suggested a downgrade in my version of iTunes, but don't suggest a version that would work. I see on the iTunes site you can go backward, but the next most current version of iTunes is almost 4 years old.
Anyone else who uses Nuvo having the same challenge? Solved it?
Looking for any help here.
Thanks in advance.
Jeff
djjefft is offline
Reply Home A/V Distribution
