Rack surge strip - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-30-2020, 02:22 PM - Thread Starter
no1ufgator's Avatar
Rack surge strip
This could be the wrong placement/forum, but any recs for a decent rack mount surge strip? Looking to spend less than $100. Any feedback is appreciated.
no1ufgator is offline
post #2 of 8 Old 04-30-2020, 06:47 PM
kwoody51's Avatar
Quoted: 71 Post(s)
Liked: 38
Here you go... https://www.amazon.com/Tripp-Lite-Ne.../dp/B00006B834
Have 2 of these in my rack, work flawlessly!
kwoody51 is offline
post #3 of 8 Old 04-30-2020, 08:28 PM
Merlin2000's Avatar
Quoted: 17 Post(s)
I suggest you ensure surge protection, however, for a 35%+ savings, you can go with another brand https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The alternative Tripp Lite is another $20+ https://www.amazon.com/Tripp-Lite-Ne...00006B83A?th=1
Lifetime warranty is great, but power strips tend to not be something most folks replace. It's just a bunch of wires under plastic, so not much to go wrong... So think of TCO but also the factor of dealing with a bad power strip.
For a couple bucks, you gain a potential extra warranty.
Merlin2000 is offline
post #4 of 8 Old 05-01-2020, 10:49 AM
ezlotogura's Avatar
Quoted: 274 Post(s)
Liked: 119
the first link has a better outlet layout for wall warts compared to the 2nd and 3rd link
just food for thought - figure out your layout before you purchase
ezlotogura is offline
post #5 of 8 Old 05-03-2020, 12:41 PM
Neurorad's Avatar
Quoted: 293 Post(s)
Liked: 163
Hard to get to those outlets, when mounted to the front of the rack, e.g. for a hard reset of a component. Leave some room above and/or below, to fit your hand in there.
I added another power strip sitting on the bottom of my rack, at the back, with that plugged into a Cyberpower front-mount PDU, for easy hard rebooting of 2 components.
Big benefit of the vertical PDU, at the back of the rack. Saves space at the front for components, too.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 8 Old 05-04-2020, 06:32 AM
Quoted: 21 Post(s)
Liked: 0
Tripp Lite 14 Outlet Network-Grade Rackmount PDU, 15A Surge Protected Power Strip, 15ft Cord with 5-15P, (DRS-1215),Black https://www.amazon.com/dp/B00006B83A..._3KbSEbSSGVZDM
Sent from my Pixel 3a using Tapatalk
kevinp1969 is offline
post #7 of 8 Old 05-04-2020, 01:42 PM
Neurorad's Avatar
Quoted: 293 Post(s)
Liked: 163
I also use a Middle Atlantic rack mount SPD in another rack - 915R. Several variations exist. Bought it used locally for $25.
Many of these on ebay, for $20-30. Try Craigslist, too.
https://www.ebay.com/sch/i.html?_fro...antic&_sacat=0
Edit - not as shallow as the other regular PDUs, easier to plug and unplug components, when mounted to the front rails.
Neurorad is offline
post #8 of 8 Old 05-07-2020, 05:52 PM
kwoody51's Avatar
Quoted: 71 Post(s)
Liked: 38
This is the one I actually have, not the one I linked to.
Mine has 8 outlets in the back vs 6. While the spacing is tighter I'd rather have 8 outlets and manage my wall wart spacing than give up 2 outlets as I need/ use all 16 outlets.
kwoody51 is offline
Reply Home A/V Distribution
