Automating my House with Crestron Home OS 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bgarcia
post #1 of 4 Old 05-07-2020, 04:18 PM - Thread Starter
bgarcia's Avatar
Quoted: 87 Post(s)
Liked: 121
Hi All,
I am implementing Home OS3 for my house outside of the theater which for now will remain as a seperate Crestron System with it invoking some functions on the Home OS3 system. Thy theater has screen masking, a Barco Thor, Lumagen, 16 x 16 HDMI 2.0 switcher etc.
The list of equipment that will be controlled by the Home OS3 system includes:
  1. 10 Sony XBR 9XXE series or later TVs (IP control)
  2. 2 Samsung TVs (IP Control)
  3. 10 sources for video (2 DirecTV 4K Genies, 2 Apple TVs, 1 Strato-C/M300 player in a Co-Star configuration, 2 Roku Ultras, 2 PCs, and 1 XBOX One X)
  4. 18 Zones of audio (Sonnex)
  5. Autonomic Controls MMS-5A for 5 streaming audio / iTunes sources
  6. Cen-Track for 2 AM/FM Tuners / 2 Sirius XM
  7. Crestron DM-NVX for all video distribution outside of the theater (Video over IP)
  8. 2 Denon AVR-2600H for 5.1 in two rooms wired for 5.1
  9. 11 HVAC Zones using Crestron TStats
  10. ~ 100 Lighting Loads Crestron wired lighting control CLX1-DIM4, CLX-1DIM8, CLX1-DIMU4, and CLX-2DIMU8 lighting modules
  11. ~ 10 Fan Loads (Crestron wired control CLX-1Fan4)
  12. ~ 50 Keypads CNX-B?? series from Crestron
  13. ~ 50 Lutron Shades (Radio RA2)
I am right now getting all of the devices rack mounted and cabled for the sources. I have had the Crestron Thermostats for about 9 years, and I now finally getting them hooked up to a control system. Lighting is moving from something I had programmed in D3 Pro, to Crestron Home. I am going to move the lighting over Memorial Day weekend.
I am thoroughly documenting and labeling everything as part of this effort.
I need to find a source for Josh.AI as from what I saw at Cedia, it kicks Alexa in the butt for home automation and it appears to be supported by Home OS3.
I will post here as I make progress
Right now I have all the thermostats connected, and one room setup with a Sony TV, a DM-NVX-351C setup as an encoder with an Apple TV as a source, and a DM-NVX-351 as the Decoder connected to the Sony TV.
So far I have been very impressed with Crestron Home OS3.
Bryan
AV_Integrated likes this.
bgarcia is offline
post #2 of 4 Old 05-19-2020, 03:29 PM - Thread Starter
bgarcia's Avatar
Quoted: 87 Post(s)
Liked: 121
Update on my Home OS3 implementation
  • I have added a directv 4k Genie using IR. Crestron just released IP drivers for the 4K Genie so I will need to update to that driver this weekend.
  • I have also set up a Strato-C, and an M300 player paired using a Co-Star switch.
  • I have two rooms setup to use the DirecTV, Apple TV, and the Kaleidescape. I will be adding an additional Apple TV, and 2 more DirecTV receivers to choose from.
  • I haven't decided if I am going to add a Roku Ultra device
  • After a few challenges (my understanding) I got my Sonnex Swamp 24x8, Swampe-8, and Swampe-4 setup for my whole house house audio (20 Zones available and I am using 17 Zones), and 7 sources (AM/FM Tuner, XM Tuner, Autonomic MMS-5A for five channels of streaming setup) I still need to finish setting up streaming sources on the Autonomic MMS-5A. Once I got past my understanding of setting up the Sonnex system, I was able to configure all 17 zones in under 30 minutes.
  • This weekend I plan to switch my lighting control from a D3-PRO based solution to Home OS3. That is going to be a VERY VERY big effort. I expect it will take two to 3 days to move and program everything, and any scenes will get create after that.
  • The latest release (yesterday) of Home OS3 added support controlling Lutron Shading via the Radio RA2. Unfortunately my Radio RA2 died, I have bought a replacement unit, but I am hoping my integrator that installed them will take care of replacing.
  • I will next need to start adding rooms that have Sonos Soundbars connected, and rooms that have built in 5.1 speakers. I have to figure out how to have two Crestron NVX decoders in the room (one for the TV, and one for the receiver (I purchased factory refurbished Denon AVR-X2600H receivers for the two rooms with a built in 5.1 speaker setup)
  • I hope to have time to try to get one room setup with Alexa connected to the Home OS3 system. My first attempt a week and a half ago was a miserable failure (I presume it was due to my lack of understanding)
I remain very impressed. My biggest issue has been a number of thermostats went off line. I powered them off and back on and it seems like it fixed all but one. I may have a flaky thermostat that I have to replace.
Bryan
bgarcia is offline
post #3 of 4 Old 05-20-2020, 03:21 AM
thebland's Avatar
Quoted: 2588 Post(s)
Liked: 1855
Bryan
Hey Bryan
Do you have an installer or are you programming the entire system yourself?!
Looks like quite an undertaking!
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #4 of 4 Old 05-24-2020, 08:26 PM
Liked: 0
Hello,
That is a substantial set up. I am about to add Crestron lighting and switch from Vantage. In doing so I am adding a CPR4 and hopefully depending on my integrator control my lighting with the existing CP3. My integrator is still against switching over to the OS 3. From what I can see it is more customizable from an end user but he is dead set against it currently. I also want to add Josh.ai to have more control . I was hoping to get your thoughts on OS3 .
Rajen Doshi is offline
Reply Home A/V Distribution
