How do I control home media equipment remotely? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-12-2020, 12:41 AM - Thread Starter
Liked: 0
Hello,
I am setting up a home media system in my new home. I will have a PC, AVR, NAS and Xbox in a server rack about 15m away from my lounge.
How can I best control this equipment from my lounge?
I am running Cat6a, HDMI and USB 3.0 to the lounge. Should I run some sort of IR wire?
Many thanks for your advice!
Andrew
Andrew Clarke is offline
post #2 of 3 Old 05-12-2020, 08:56 AM
ezlotogura's Avatar
Quoted: 274 Post(s)
Liked: 119
Originally Posted by Andrew Clarke View Post
Hello,
Andrew
IR, RS232 or if you use Harmony maybe even some RF
Xbox not local could cause lag/delay with remotes, just an FYI. I am no expert in that area (or most areas!)
You can run IR over ethernet wire if needed.
ezlotogura is offline
post #3 of 3 Old 05-12-2020, 12:34 PM
Neurorad's Avatar
Quoted: 293 Post(s)
Liked: 163
I use category cable to extend IR.
Harmony remote -> RF -> Harmony Hub
Harmony Hub -> wifi -> AVR
Harmony Hub also hardwired to TV, via category cable. 2.5 mm IR (mono) output of Hub, adapter to 3.5 mm, 3.5 mm input on category cable breakout board, cat cable to TV, 2 of those conductors connected to a pigtailed 3.5 mm mono male connector, plugged into Sony TV IR input.
3.5 mm breakout board, no guesswork
https://www.avsforum.com/forum/93-re...nd-useful.html
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Home A/V Distribution
home media setup , remote control extender
