Smart Home Pre- Wire - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-28-2020, 04:46 PM - Thread Starter
horsegoer's Avatar
Quoted: 70 Post(s)
Hello All. So I'm running out of time. have about 1 week to get my cabling in as all the walls/ceiling are open.
Might do video distribution.
Right now this is what I'm thinking of running.
3 cat 6, 1 2 strand fiber and coaxial to every tv location.
Cat 6 to every camera location.
cat 6 to WAP location.
Would like shade control( what size/ # of conductors would i run)
speaker wire to speaker locations.
Not sure what I should do about alarm system...wired or wireless.
Anything else you guys can think of or critique please do. Thank you very much.
beau
horsegoer is offline
post #2 of 13 Old 06-28-2020, 09:01 PM
ezlotogura's Avatar
Quoted: 281 Post(s)
Liked: 119
different shades have different wiring needs. some are low voltage, some can be controlled and powered by ethernet, etc
ezlotogura is offline
post #3 of 13 Old 06-29-2020, 01:17 PM
Postmoderndesign's Avatar
Quoted: 583 Post(s)
Liked: 366
Install conduit to allow easy future cable upgrades.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Display: LG OLED 65e6p, Player: OPPO UDP-203, AVR:Yamaha TSR 7810, Streaming: Comcast 100Mbps RG6 to Cat6a, Speakers: Mains Vandersteen IIC, Center, Surrounds, Rears Klipsch
Postmoderndesign is online now
post #4 of 13 Old 06-29-2020, 04:56 PM
smoothtlk's Avatar
Quoted: 369 Post(s)
Liked: 118
You always run wire and don't depend on wireless when you can access the studs.
Smaller shades you can run 14/4 for low voltage shades. Large / heavy drape shades 110 volt. Most will be low voltage.
14 / 4 for speaker cable for short to medium length runs. 2) 12/2 or 1) 12/4 for each speaker pair for long length runs.
Landscape wiring low voltage. 12/2 underground rated cable. Multiple runs so you can turn on / off separate zones and reduce the wire length daisy chaining all lights.
Spa / Sauna / Pool to outside. Multiple Cat6.
IP Cameras (POE). Cat6 to each camera location.
Definitely do video distribution while you can. HDMI (if runs are very short) or Cat6 (for HDBaseT or IP video distribution).
Cat6 to all touchscreen in wall high traffic locations (kitchen / foyer / backyard / game room)
All wires got to your centrally mounted equipment rack that has planned ventilation / cooling / power / networking connections.
smoothtlk is offline
post #5 of 13 Old 07-01-2020, 05:49 PM - Thread Starter
horsegoer's Avatar
Quoted: 70 Post(s)
thanks all. so do I need 3 cat 6 to each tv location? I'm running a fiber to each tv for future. got all the cable cheap since I'm in electrical industry.
post #6 of 13 Old 07-02-2020, 11:24 AM
Quoted: 583 Post(s)
Liked: 366
First of all use cat6a F/UTP:https://www.blackbox.com/en-us/store...6A41AW-PB-1000 or better still: https://www.blackbox.com/en-us/store...ABC50S-BK-1000
  • Use with Black Box CAT6A components for a 10GBASE-T channel.
  • Tested up to 650 MHz.
  • Foil shield construction virtually eliminates alien crosstalk.
  • A center isolation member maintains pair separation for optimal NEXT performance.
  • Supports IEEE 802.3 and 10GBASE-T, and TIA 568-C.2. ETL tested.
  • Construction: Internal separator, FEP insulation, dielectric tape, drain wire, aluminum/Mylar tape.
  • Smaller outside diameter than normal CAT6A UTP (0.283").
  • Guaranteed for life!
connect the cable to a grounded cat6a patch panel in an equipment cabinet:
https://www.blackbox.com/en-US/store...ory_Type=CAT6A
Wrap the drain wire: https://www.lanshack.com/shielded-cat6a-jack.aspxhttps://www.lanshack.com/shielded-cat6a-jack.aspx
I do not know how many cat6a cables you need. When I did my installation four years ago I installed two cat6a cables so I could combine them for more that 18 GBPS. But a way to combine two cables for one signal has never been developed.
Install conduit so you can easily add cables later.
post #7 of 13 Old 07-02-2020, 12:01 PM - Thread Starter
horsegoer's Avatar
Quoted: 70 Post(s)
I already bought cat 6. ugh
post #8 of 13 Old 07-02-2020, 02:57 PM
Quoted: 583 Post(s)
Liked: 366
There are still people using cat5e and possibly cat5.
If you have not put in conduit do that now.
If you decide to add more cable cat6a would be a good idea or fiber may do as well or better. As I have never used fiber I cannot advise on fiber.
post #9 of 13 Old 07-02-2020, 06:49 PM - Thread Starter
horsegoer's Avatar
Quoted: 70 Post(s)
I am running a fiber with the cat 6.
beau
post #10 of 13 Old 07-03-2020, 07:28 AM
Quoted: 583 Post(s)
Liked: 366
You may need transceivers with fiber
post #11 of 13 Old 07-03-2020, 05:09 PM - Thread Starter
horsegoer's Avatar
Quoted: 70 Post(s)
Ok, thanks. I'm just going to run it nayway. Got it very cheap since I work in the electrical field.
beau
post #12 of 13 Old 07-03-2020, 05:19 PM - Thread Starter
horsegoer's Avatar
Quoted: 70 Post(s)
Can someone help with how many cat 6 I should run to each tv location. Again I'm also running a fiber.
Will make a big difference in cable qty if I run 2 or 3 cables of cat 6. Thank you
beau
post #13 of 13 Old 07-04-2020, 04:24 AM
smoothtlk's Avatar
Quoted: 369 Post(s)
Liked: 118
No one can answer the question if 2 or 3 is good enough without knowing your plan.
Room functions, wiring architecture, wire lengths, etc.
But since you don't have that plan, the more the merrier as long as they fit in the box and wire route.
Reply Home A/V Distribution
