Darbee vision darblet - Page 344 - AVS Forum | Home Theater Discussions And Reviews
 1156Likes
post #10291 of 10306 Old 05-04-2020, 07:35 PM
Seryl's Avatar
Quoted: 167 Post(s)
Liked: 107
Originally Posted by annisman View Post
Any idea what would happen with the new generation tuners when shows start broadcasting in 4K ? The Darbee wouldn't work with those correct?
Right, 1080P is the limit. Even so, 1080P sources can still be run through the Darbee for improvement before upscaling to 4K. I find that to work very well. I prefer the picture on my OTA Tivo>Darbee to the picture from my cable TV box for local stations. As wonderful as 4K can be, those of us who love the Darbee find it hard to put it in the closet, it has been that good.
humbland likes this.
Seryl is offline
post #10292 of 10306 Old 05-04-2020, 07:51 PM
humbland's Avatar
Quoted: 1164 Post(s)
Liked: 366
+1 on hard to let go of Darbee. Having one should be an AVS merit badge requirement
Seryl likes this.
humbland is offline
post #10293 of 10306 Old 05-04-2020, 08:11 PM
calentz's Avatar
Quoted: 233 Post(s)
Liked: 167
I am essentially doing the same as you, except I am taking it a step farther. I have the Darbee on the output of my Integra servicing 1080 and below to one input of my TV. (My Tivo is into one Integra input) My Ultra Blu-Ray sends signal to another input of my 75" 8K TV and handles ALL the various flavors of Blu-Rays.
Seryl likes this.
--Carl
calentz is offline
post #10294 of 10306 Old 05-04-2020, 09:30 PM
reechings's Avatar
Quoted: 226 Post(s)
Liked: 44
Yeah I'm a happy user as of now. Still playing with it a bit but it is cool to have as an option and watching The Last Dance on Netflix with a 135" screen it looks damn good
Sent from my Pixel 2 XL using Tapatalk
reechings is offline
post #10295 of 10306 Old 05-05-2020, 09:18 AM
fleaman's Avatar
Quoted: 260 Post(s)
Liked: 178
I was like, how you watching that on Netflix?
Well, it seems only international Netflix customers can and you're in Canada. USA Netflix it's not listed.
Luckily I've got espn as it's played on that channel...
reechings likes this.
fleaman is offline
post #10296 of 10306 Old 05-05-2020, 10:15 AM
WTS
WTS's Avatar
Quoted: 141 Post(s)
Liked: 44
So how did you set it up to get working 100%?
Walter
WTS is offline
post #10297 of 10306 Old 05-05-2020, 11:32 AM
reechings's Avatar
Quoted: 226 Post(s)
Liked: 44
Well after messing around some more with my PC (which only occasionally requires a power cycle of the Darbee to work) display settings I was able to get the Netflix app on the PC to work without stuttering so I was able to get 1080p Netflix without using the PS4 Pro. I don't game much on the PS4 but I think if I disable hdcp I will be able to use the Darbee for gaming on it. I haven't tried my Telus box yet since I have it hooked up upstairs to my Sony TV at the moment. I am using the hi-def setting at around 50% as I find it adds some pop and clarity without being too harsh on faces.
post #10298 of 10306 Old 05-05-2020, 12:02 PM
WTS
WTS's Avatar
Quoted: 141 Post(s)
Liked: 44
Good to hear. I set mine at 47%.
Walter
WTS is offline
post #10299 of 10306 Old 05-10-2020, 08:43 PM
reechings's Avatar
Quoted: 226 Post(s)
Liked: 44
Can anyone recommend a good Android based 1080p tv box with a remote that I can load up apps on and is Darbee compatible?
post #10300 of 10306 Old 05-10-2020, 09:03 PM
reechings's Avatar
Quoted: 226 Post(s)
Liked: 44
Anyone try it with shield tv non pro?
post #10301 of 10306 Old 05-11-2020, 06:56 AM
WTS
WTS's Avatar
Quoted: 141 Post(s)
Liked: 44
https://www.avsforum.com/forum/139-d...cy-thread.html
You need to read the thread in the link I pasted as it will tell you which boxes are accurate with their outputs.
Walter
WTS is offline
post #10302 of 10306 Old 05-11-2020, 08:42 AM
reechings's Avatar
Quoted: 226 Post(s)
Liked: 44
Took a look at the thread but not sure how it helps for my question. I was just hoping someone that has a Darbee could recommend an Android streamer box that works fine without handshake issues or hdcp problems. Cheers
post #10303 of 10306 Old 05-11-2020, 08:46 AM
WTS
WTS's Avatar
Quoted: 141 Post(s)
Liked: 44
My point is that you want to make sure you get one that has a bit correct output. If you don't care about that then don't bother reading the thread.
Walter
WTS is offline
post #10304 of 10306 Old 05-11-2020, 12:51 PM
LastButNotLeast's Avatar
Quoted: 2977 Post(s)
Liked: 2747
You may (or may not) have these with any device. Suggestions in the rest of this thread will help.
Michael
LastButNotLeast is offline
post #10305 of 10306 Old 05-11-2020, 03:14 PM
reechings's Avatar
Quoted: 226 Post(s)
Liked: 44
Michael
Yeah I understand. This thread covers a lot of years so I was hoping some people that might still be using the Darbee could tell me what streaming devices are working for them. I know that doesn't guarantee the same device won't work for me.
post #10306 of 10306 Old Yesterday, 09:54 PM
Erod's Avatar
Quoted: 1413 Post(s)
Liked: 922
Not sure why, but my darbee just died. I only used it for broadcast, but still liked it. It's about five years old.
Do they even still sell these things anymore?
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: RBH SV-661R and SV-661CR fronts, Jamo 626k4 side/rear surrounds, DefTech DI6.5R heights
Erod is offline
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
