New Lumagen Radiance Pro Series - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 4122Likes
post #3151 of 5857 Old 05-22-2018, 08:43 AM
thrang's Avatar
Quoted: 2629 Post(s)
Liked: 2134
Originally Posted by Kris Deering View Post
The problem here is there are no “SDR limits” when it comes to luminance. This is why I’m confused about why the Sony is having this issue. I could understand it not supporting 2020 with a SDR signal, we’ve seen that with other displays, but limiting luminance doesn’t make any sense at all. Which makes me question it as a setup issue. But without having access to one I can’t say for sure. I wish there was someone local with that combo that I could test out. Then I could provide feedback for you or other members with this setup.
Sent from my iPhone using Tapatalk Pro
Originally Posted by bobof View Post
Same here, seems positively nuts, since you're effectively crippling the maximum screen size for no obvious reason.
Unless the laser can't run that hot for long or some other weirdness.
Its nothing to do with the laser running in high output...thats not an issue.
There seems to be some processing in the 5000 that remaps HDR levels when the flag is SDR. It processes 2020 automatically. I'm not saying this is correct or purposeful - who knows at the moment - just the behavior. When it sees the HDR flag, all seems quite well.
Kris - if you're ever in the NYC area, you're welcome to come visit. There are really no settings that can circumvent this behavior, unless there is something buried in the service menu...
Kris Deering likes this.
thrang is offline
post #3152 of 5857 Old 05-22-2018, 08:44 AM
thrang's Avatar
Liked: 2134
Originally Posted by Wookii View Post
if you're happy with the results, then its probably a moot point. It was purely a suggestion to prevent you having to overlay two different sets of tone mapping, and also give you a route to be able to accurately calibrate greyscale and gamma, which presumably you can't do with the current method.
I'm not being dismissive, just not following the suggestion - I'm open to explore options!
thrang is offline
post #3153 of 5857 Old 05-22-2018, 08:48 AM
aka jfinnie
Quoted: 2653 Post(s)
Liked: 1752
There's no such things as HDR levels when the flag is SDR - they're just SDR levels at that point, so it seems odd.
Am I right in thinking you're not actually making a 3DLUT based on the profile of the projector in SDR mode?
bobof is online now
post #3154 of 5857 Old 05-22-2018, 08:53 AM
thrang's Avatar
Liked: 2134
I'm using the 3D calibrated LUT done by Ken Whitcomb, which was done as SDR out to the 5000. This is the same approach that others are using here with Ken's calibration...
Unless there is something "wrong" with the calibration workflow (he used Calman). That would be the only other common denominator between myself and others here with 5000/Radiance/calibration workflow
EDIT - Is it possible the SDR patterns were used inadvertently? I presume that could lead to these results...
I have Chromapure and a Display 3 Pro.. I guess I could dust this stuff off and see if there's a step by step guide on how to do this myself to compare...
thrang is offline
post #3155 of 5857 Old 05-22-2018, 09:11 AM
aka jfinnie
Liked: 1752
Don't know Calman. With Lightspace I known you have to create two LUTs and upload to different CMS memories in the Radiance. One for REC709, and one for REC2020. If you have the Radiance sending REC709 and REC2020 you will have to have made two measurement profiles, one at each output type from the Radiance. If you don't do that you would end up constrained by the LUT you create for REC709 I think (or perhaps not have an active own profiled LUT at all).
Anyway, sounds like you're in the hands of a pro so not much point trying to second guess how it is set up.
bobof is online now
post #3156 of 5857 Old 05-22-2018, 09:19 AM
thrang's Avatar
Liked: 2134
@jrp
Jim if I send you my Radiance config, can you analyze it to see if the calibration was done correctly? (are the HDR2020 luminance values limited to SDR for example, and perhaps what patterns were used for a given cms calibration)?
thrang is offline
post #3157 of 5857 Old 05-22-2018, 12:43 PM
jrp
jrp's Avatar
Quoted: 426 Post(s)
Liked: 1137
@jrp
Sorry, but not able to look at the calibration and see from the config file.
Jim Peterson
Lumagen
jrp is offline
post #3158 of 5857 Old 05-22-2018, 01:21 PM
desertdome's Avatar
Quoted: 1535 Post(s)
Liked: 1837
Hi Wookie
Not following here... if the Sony kicks to HDR mode, there is no need to use an external tool for a custom gamma - it looks great in the hybrid approach. The Sony HDR mode does not have the issues the JVC has with its HDR Gamma mode being way off...
The issue is to see if the Sony can process a SDR2020 signal without remapping the embedded HDR luminance levels to SDR limits.
So perhaps I'm missing your point here...
There are no "embedded HDR luminance levels" when you send an SDR2020 signal to whatever is next in the signal chain. The correct setting for this is HDR off and Color Space set to BT.2020. I've been to Sony headquarters in San Diego for HDR training with Sony engineers. While Sony prefers to use their own tone mapping, they have also enabled one to use upstream tone mapping and send SDR2020 to the 5000ES. It does not remap anything when using the correct settings.
Sony says in their manual, "If the setting is not correct for the input content, the bright and dark areas of the video may appear too bright or too dark." This happens if you leave HDR to Auto, but send it SDR2020 content. Perhaps this is what you see as the problem. I think the HDR mode is triggered by the detected color space. One is either going to let the Sony do the tone mapping and send it HDR and BT.2020 or let the Lumagen (or madVR) do the tone mapping and set HDR to Off. There really isn't a use case when one wants to have the Lumagen tone map some of the time and have the Sony tone map some of the time and have the HDR Auto setting detect the HDR metadata. I just sent the 5000ES back to Sony today so I can't check into this further.
Ponderosa Theater
High Impact AV
- ISF Level III Video Calibrator, THX-HAA HT3 Audio Designer/Calibrator
desertdome is offline
post #3159 of 5857 Old 05-22-2018, 01:58 PM
thrang's Avatar
Liked: 2134
I've tried HDR off with a tone-mapped SDR2020 signal from the Radiance and it does not change the presentation of the image: Auto and Off for HDR are exactly the same. So this is not a "correct" setting in my experience (and the experience of others here who have compared both approaches)
As much as I theoretically agree with you that that hybrid approach doesn't make "sense," it is in actuality the better approach for Radiance and 5000 users as far as I can ascertain in my content testing to date...and after conversations with Sony, and other comments posted here about limitations with the current processing in the 5000. It seems to assume an SDR flag means "that's the color volume" it should expect in the incoming signal; yet the tone-mapped signal of course contains a larger color volume (and peak whites) - greater than expected for SDR (29 fl/100 nits?). According to Kris, other devices, such as the JVC 4500, could care less how the flag is set in the incoming signal, and processes/displays whatever is presented within the limitations of the device. Apparently the Sony cares for some reason.
Everything I understand is that color output is impacted by both 2020 (P3) as well as the higher luminance values of HDR. So if the 5000 is not processing this correctly, brightness and color range would be reduced, which is pretty much what I see.
I mean, take the Radiance out of the chain - an HDR signal from your UHD player is brighter and more vibrant on the 5000 then sending tone-mapped SDR-2020 from the Radiance to it. It just is.
I'm ALWAYS open to re-looking at a wrong setting, or just learning more - but again, a few others are also trying this hybrid approach and are much more satisfied with the results. Again, this appears not to be a Radiance issue, but how Sony is processing higher luminance values via a SDR2020 signal.
https://www.soundandvision.com/conte...-hdr-and-color
thrang is offline
post #3160 of 5857 Old 05-23-2018, 06:54 AM
LJG
LJG's Avatar
Quoted: 758 Post(s)
Liked: 487
Hi Kris:
I see you are getting a 885 for review next week, perhaps you could look at this for the Sony users here.
LJG is offline
post #3161 of 5857 Old 05-23-2018, 08:15 AM
Kris Deering's Avatar
Quoted: 4005 Post(s)
Liked: 6976
Originally Posted by LJG View Post
Hi Kris:
Not getting it for review, it is the unit that I already reviewed some time ago. I am just going to play around with it again starting next week. Want to see how it reacts to the Lumagen stuff, though I don't know if it has the same issues that have been brought up for the 5000ES. But I'll chime in on what I find.
My Home Theater UPDATED DEC 2017
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is offline
post #3162 of 5857 Old 05-23-2018, 08:56 AM
LJG
LJG's Avatar
Quoted: 758 Post(s)
Liked: 487
Thanks Kris!!
LJG is offline
post #3163 of 5857 Old 05-24-2018, 03:42 PM
SJHT's Avatar
Quoted: 1122 Post(s)
Liked: 745
Just got included in the beta of the Lumagen Pro Kaleidescape costar. Not sure how much I can say,lol, but it is SLICK.....
Craig Peer and Mike_WI like this.
SJHT is offline
post #3164 of 5857 Old 05-25-2018, 03:50 AM
aka jfinnie
Liked: 1752
So is that basically using the Lumagen Pro to do the switching instead of the diddy little switch they usually use, or something else? What's the benefit of doing it with the Pro?
Mike_WI likes this.
bobof is online now
post #3165 of 5857 Old 05-25-2018, 08:01 AM
SJHT's Avatar
Liked: 745
Faster, less hardware, separate configs, etc......
bobof likes this.
SJHT is offline
post #3166 of 5857 Old 05-25-2018, 01:21 PM
LJG
LJG's Avatar
Quoted: 758 Post(s)
Liked: 487
I am having issues running my Directv mini 4K through Lumagen, all of the 4K signals (104,105,106) are muted/off no audio or video. The 720P and 1080i are outputting just fine. Running same cables direct to Sony 5000ES works perfectly. Anyone else running DTV mini4K through Lumagen into Sony 5000ES?
LJG is offline
post #3167 of 5857 Old 05-25-2018, 02:58 PM
jrp
jrp's Avatar
Quoted: 426 Post(s)
Liked: 1137
For those who do not know what the Kaleidescape Costar feature is, it allows a Kaleidescape Strato to be the master device and control another Kaleidescape player using a single OSD. If you own a Kaleidescape player, or wish to, contact Kaleidescape for more information.
The Kaleidescape "Costar for Lumagen" uses the Strato's HDMI Info Frame output to tell the Radiance Pro whether to select the Strato output or the "Costar" output. This is better than the external auto-switch (or internal Pro auto-switch) since the output of both the Strato and the Costar can be left on. This eliminates the "acquire a new signal" delay needed for the auto-switch Costar variant. With the auto-switch approach the time it takes the HDMI input chip to acquire a new signal as either the Strato or the Costar output is enabled has to be added to the switching time.
As mentioned, using the Costar for Lumagen, you can also have a different input setup for the Strato, and the Costar player.
Kaleidescape charges for the "Costar for Lumagen." For new sales of the Radiance Pro in the USA or Canada, Lumagen is offering a $500 retail credit toward the purchase of a new Radiance Pro once the customer shows they have purchased the Costar for Lumagen feature from Kaleidescape. Ask your Lumagen dealer to contact Lumagen for details of this limited time offer.
Spizz, SJHT, Mike_WI and 1 others like this.
Jim Peterson
Lumagen
jrp is offline
post #3168 of 5857 Old 05-25-2018, 03:47 PM
Steve Bruzonsky's Avatar
Quoted: 1602 Post(s)
Liked: 796
I have a DirecTV Genie 54 w a 4k mini-Genie running 4k into Radiance Pro then to 5000ES and no issues whatsoever. For many months now! Check the 4k mini-Genie Settings menu to ensure you can output native rate including 4k.
https://www.avsforum.com/avs-vb/show....php?t=1158431 No dealer is authorized to tell you I refer to them - any referrals I make will be done personally by me. Over the years I have found certain dealer(s) who I cannot recommend for good reason.
! 9.4.13 Trinnov Altitude 32 Theatre renovation/upgrade starts end of July 2019!
Steve Bruzonsky is online now
post #3169 of 5857 Old 05-26-2018, 11:03 AM
LJG
LJG's Avatar
Quoted: 758 Post(s)
Liked: 487
Thanks for the try Steve, but Native rate settings are correct in DTV mini, not sure what is going on.
LJG is offline
post #3170 of 5857 Old 05-26-2018, 12:20 PM
SJHT's Avatar
Liked: 745
I have Dish 4K, but is there some type of HLG setting you need to set on the Pro or DTV box? Just guessing.... SJ
SJHT is offline
post #3171 of 5857 Old 05-26-2018, 12:37 PM
LJG
LJG's Avatar
Quoted: 758 Post(s)
Liked: 487
The box Mini4K is set correctly I am not sure why both the audio and video is muted for 4K broadcast's through Lumagen, I just swapped mini 4k boxes and both work direct to Sony but neither works through Lumagen. It's very odd and must be a setting in the Lumagen some where buried.
where.
LJG is offline
post #3172 of 5857 Old 05-28-2018, 07:55 AM
Liked: 796
where.
If its the Lumagen - give JimP at Lumagen a call tomorrow and have him walk you through steps to check your audio out settings! If its the Lumagen that will solve the issue.
Another thing you can do first is simply replace the HDMI cable from Mini4k to Lumagen to see if that might solve the issue.
post #3173 of 5857 Old 05-28-2018, 12:11 PM
LJG
LJG's Avatar
Quoted: 758 Post(s)
Liked: 487
Issue resolved thanks all for help
LJG is offline
post #3174 of 5857 Old 05-28-2018, 01:44 PM
Liked: 796
What was it? HDMI cable?
post #3175 of 5857 Old 05-28-2018, 02:21 PM
LJG
LJG's Avatar
Quoted: 758 Post(s)
Liked: 487
EDID from switcher which did not cause a problem direct to projector, so I did't re-look at switcher until I tried everything else. Upgrade firmware to switcher and it plays nicely with Lumagen now.
LJG is offline
post #3176 of 5857 Old 05-29-2018, 09:20 AM
Liked: 796
Are you using the switcher box after your DirecTV mini4k? (I assume so since you have a 5000ES projector AND multiple flat tvs for multiple sports watching at once!)
What switcher box are you using?
post #3177 of 5857 Old 05-31-2018, 02:38 PM
cappy1's Avatar
Quoted: 48 Post(s)
Liked: 29
Originally Posted by tibia View Post
...if you setup both Chromapure and the Pro to do SDR2020 calibration but using a Rec 709 source and 2.4 power law gamma Auto-Calibration works fantastically well.
Why would you want to use Rec.709 instead of Rec.2020?
cappy1 is offline
post #3178 of 5857 Old 06-02-2018, 05:52 PM
thrang's Avatar
Liked: 2134
Anyone email Lumagen lately? Two days I’m getting bounce backs from Jim’s address...
thrang is offline
post #3179 of 5857 Old 06-02-2018, 06:57 PM
wjchan's Avatar
Quoted: 16 Post(s)
Liked: 30
I did some quick measurements today with a Jeti 1511 probe. Playing the windowed 100% white 1000- and 4000-nits patterns from R. Masciola's Advanced Calibration Disc through my Panny 900 player, I got about 208 nits using the HDR->SDR IM setting calibrated by Ken Whitcomb. When I switched to HDR into Sony--still through the Lumagen albeit uncalibrated--I got about 220 nits. Ken told me there is a ~8% loss due to the calibration so the numbers look fine at first glance. Is there anything else you want me to test?
--wilson
P.S. I was zoomed into 16:9 on my 140" 2.40 ST100 screen with laser at 50 and that's why it's kind of bright.
wjchan is online now
post #3180 of 5857 Old 06-02-2018, 07:41 PM
mskreis's Avatar
Quoted: 151 Post(s)
Liked: 48
Yep. I’ve noted the same.
JVC RS640; RUIPRO 10m HDMI cable; Marantz AV7704; Lumagen Pro 4240; Oppo BDP-203;Triad Silver LCR, Onwall Bronze Surround, Inwall Bronze Omni, KEF Inceiling Ci 160QR x 4; Dual RSS460HO-4 18" SWs
mskreis is offline
Reply Video Processors
