New Lumagen Radiance Pro Series - Page 260 - AVS Forum | Home Theater Discussions And Reviews
 6549Likes
post #7771 of 8025 Old 05-10-2020, 06:24 PM
blake's Avatar
Quoted: 1034 Post(s)
Liked: 154
Originally Posted by jrp View Post
I have been considering a hush-box, but at the moment my wife has veto'd it as being unsightly. I am working on convincing her as I would like the extra light output. The current 88 nits actually looks great with the Radiance Pro DTM. So not in a huge rush to build the hush box.
Just curious : Is your manual iris wide open or clamped down a bit?
blake is offline
post #7772 of 8025 Old 05-10-2020, 10:41 PM
uderman's Avatar
Quoted: 132 Post(s)
Liked: 64
Originally Posted by Killroy View Post
Originally Posted by EVH78 View Post
They are still selling those 9Ghz models. I seriously cannot see here any cannibalizig of stock when you have different models since they do not come with the same price tag....
Yeah, you got me on that one but if I am not mistaken, if you buy the 9Ghz unit and then want to upgrade it all to 18Ghz you will pay more to upgrade the cards than if you just bought the 18Ghz to begin with...right?. Upgrades are always more expensive than just buying native.
There are a couple of benefits to 9GHz inputs. They have less issues with older equipment and longer HDMI runs. It is also a significant cost cut if you don’t need all 8 inputs 18 GHz. They are also faster in switching inputs on those devices you don’t have 4K60 or HDR.
I have 2x 18GHz cards and I use only one input per each so I can still use pip/pop when they are available. I have 3x 1080p sources on the remaining 9GHz cards one of which is a Radiance 2144 that has analog legacy devices connected to it.
bferbrache and Mike_WI like this.
Wanted:
HD-VMD Discs
Muse/Hi-Vision Discs - Mint/Complete Only!
uderman is offline
post #7773 of 8025 Old 05-11-2020, 08:48 AM
Erod's Avatar
Quoted: 1435 Post(s)
Liked: 937
[quote=skylarlove1999;59625108]
Originally Posted by Erod View Post
Can the pixel shift not be turned off?[/quote @bobof already replied accurately. Conspiracy theorists believe just the presence of the extra optical element degrades the image quality. . But seriously some people do believe that it does. I don't know of any NX9 owners who use the 8k pixel shifting feature.
Sent from my SM-G965U using Tapatalk
So does the NX9 cast a noticeably better picture than the NX7? I know it has a better lens, but does that manifest in 4K images?
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: RBH SV-661R and SV-661CR fronts, Jamo 626k4 side/rear surrounds, DefTech DI6.5R heights
Erod is online now
post #7774 of 8025 Old 05-11-2020, 08:59 AM
skylarlove1999's Avatar
Quoted: 2269 Post(s)
Liked: 2411
[quote=Erod;59627616]
I have not seen an NX 9 in person so I don't want to speak out of turn. From people who have seen both the consensus seems to be that there is a slightly sharper and Brighter Image for the nx9 but they said for the extra money it is not something that is really worth it in their opinions unless money is not a consideration. Obviously if you have the extra dough the JVC NX9 does throw a better image from all the people who have seen both.
Tristan Jones
skylarlove1999 is online now
post #7775 of 8025 Old 05-11-2020, 09:32 AM
xchap2001's Avatar
Quoted: 18 Post(s)
Hello guys hope all is well.
I have a Radiance Pro with 18g cards and 9g cards. I can't get 18g working. says no input, but the 9g card works all the time i plug it in. i tried 0851 / 0850 code no luck.
I tried different hdmi cables all rated for 18g, 4.4.4. etc & 6 foot cable. no luck. i reset the Pro no luck.
What are you guys using/or did to get 18g to work? I have a strato player and sony A1E set up to hdmi 3 which will display 444 18g n enhance mode.
With the strato plugged direct to the t.v. it works , but with the Pro it doesn't. No Input. on 18g. Thanks Guys
xchap2001 is offline
post #7776 of 8025 Old 05-11-2020, 10:36 AM
Quoted: 283 Post(s)
Liked: 383
I had the same symptom when I first installed my Radiance Pro. I resolved it by changing to a Fiber HDMI cable (RUIPRO). Nothing else changed, but my certified HDMI cable, which worked at 25 feet length without the Radiance Pro, just couldn't get it done. Not a lick of issues since I bought the fiber cable.
What is the length of the cable from your Radiance Pro to display?
Karl Maga is offline
post #7777 of 8025 Old 05-11-2020, 11:19 AM
xchap2001's Avatar
Quoted: 18 Post(s)
I have 2 from Rupio one fiber ,one regular , audio quest 6 feet
post #7778 of 8025 Old 05-11-2020, 04:51 PM
jrp
jrp's Avatar
Quoted: 515 Post(s)
Liked: 1553
Wide open for HDR.
I have the iris two clicks down for SDR. I am liking SDR closer to the 108 (-ish) nit mastering level rather the the commercial theater 48 nit (14 Foot Lamberts) level.
Jim Peterson
Lumagen
jrp is offline
post #7779 of 8025 Old 05-11-2020, 05:01 PM
Kris Deering's Avatar
Quoted: 4402 Post(s)
Liked: 8046
This sounds like something you should be talking with your dealer about. The whole point of working with a dealer is to ensure that they support the product and answer your questions! That is part of what you paid for with the product!!
My Home Theater UPDATED JUNE 2020
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is offline
post #7780 of 8025 Old 05-11-2020, 05:43 PM
xchap2001's Avatar
Quoted: 18 Post(s)
Yes I though that I might be able to get some help here before I contact jim or pat. Thank you
post #7781 of 8025 Old 05-12-2020, 08:25 AM
Liked: 8046
Your post is confusing. You say you have plugged to 18G and 9G and HDMI 3. What SPECIFIC outputs do you have on the Radiance? Is this a model with four outputs? If so, what output are you using for 9 and for 18? What is the output configuration for those, video only or both?
Did you buy this direct from Lumagen?
post #7782 of 8025 Old 05-12-2020, 03:00 PM
Mike_WI's Avatar
Quoted: 510 Post(s)
Liked: 456
Arrow Fw 050120
http://www.lumagen.com/testindex.php...ncepro_updates
050120
- Posted 051220
Fix for rs232 response when using "Full V3" option for rs232 status reports.
Please continue giving us your detailed feedback on issues via email at [email protected] .
(reposted 050720 to correct revision date reported onscreen)
Update time ~1 minutes @230k from previous firmware
OzHDHT and riddle like this.
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & 18 GHz output x1 cards} - "new (051820 FW)" 18 GHz microcode - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #7783 of 8025 Old 05-12-2020, 05:07 PM
xchap2001's Avatar
Quoted: 18 Post(s)
Ok thanks guys I got it taking care of.
post #7784 of 8025 Old 05-16-2020, 10:58 AM
Ash Sharma's Avatar
Quoted: 1228 Post(s)
Liked: 920
Has anyone seen micro stutters - video only - when using streamers such as Apple TV4K and Roku Ultra with the latest Firmware upgrades?
I have Both on Westworld (which is 2K material) and Malaficient 4K HDR on Disney Plus using the same streamers.
I sent a e mail to Jim and he advised I should look at my HDMI cables - which are the same in a rack system from previous firmware and no chance they have moved.
No micro stutters observed when using UHD BD or Kaleidescape.
Was just wondering others experience.
Ash Sharma is online now
post #7785 of 8025 Old 05-17-2020, 05:42 AM
audioguy's Avatar
Quoted: 5762 Post(s)
Liked: 4873
I was reading the @Kris Deering review of the 4K Zappiti system. He noted the following:
Zappiti system does not retain HDR metadata, which could cause issues with some displays.
Would this lack of HDR metadata affect the way my Lumagen does DTM? Or one of the newer JVC projector models that has DTM built in?
audioguy is online now
post #7786 of 8025 Old 05-17-2020, 06:45 AM
aka jfinnie
Quoted: 3353 Post(s)
Liked: 2599
Last time I checked the Lumagen does pay some attention to the MaxCLL metadata presented; so if you have a test pattern with pixel data at 10000 nit for example but metadata being sent saying only 1000 nits MaxCLL you will see a different result at the top end of the luminance range (more clipped) than if the metadata was correct and stated 10000 nits.
bobof is online now
post #7787 of 8025 Old 05-17-2020, 09:45 AM
Liked: 8046
The Lumagen uses the metadata to establish some pads so it doesn't have to guess as much. It doesn't actually need to do this, but in testing we found that it helped with titles that are in the lower nit values for most of the movie (Blade Runner for example). So there could be some minor differences in performance. Zappiti tried to fix the metadata problem but it hasn't been yet.
A7mad78 likes this.
post #7788 of 8025 Old 05-17-2020, 10:03 AM
audioguy's Avatar
Liked: 4873
Thank you. Possibly good news for me. I also have some audio calibration clients who have the the current JVC PJ's that have an internal DTM capability. I would assume that those projectors would lose some or all of the DTM capability if they were to purchase a Zappiti??
post #7789 of 8025 Old 05-17-2020, 10:08 AM
Liked: 8046
JVC claims that their projector's don't rely on the metadata for their DTM solution, but I found that it did in fact change what mode was used. So at least in my testing, the metadata is used. But again, JVC claims it doesn't not.
post #7790 of 8025 Old 05-17-2020, 10:16 AM
audioguy's Avatar
Liked: 4873
Thanks again and congrats on your new relationship with JVC on their RS4500 + Lumagen + DeepDive AV calibration package. Does that mean you may end up going back to an R4500 from your RS3000? Just curious.
Kris Deering and OzHDHT like this.
post #7791 of 8025 Old 05-17-2020, 02:42 PM
Liked: 8046
Not really a relationship per se. JVC is just promoting the combination of a 4500+Lumagen+setup/calibration from Deep Dive AV as the best video performance from their lineup. They were going to include the RS3000 in the mix as well, as it applies just as much (really to the whole lineup). I'm sticking with my RS3000 though.
Ash Sharma, cargen, OzHDHT and 3 others like this.
post #7792 of 8025 Old 05-17-2020, 04:45 PM
Semi-Advanced Member
ht guy's Avatar
Quoted: 292 Post(s)
Liked: 303
Well deserved, Kris! Nice.
Kris Deering likes this.
ht guy is online now
post #7793 of 8025 Old 05-17-2020, 11:20 PM
gattorodolfo's Avatar
Quoted: 26 Post(s)
Liked: 4
unfortunately also I have noticed micro stutters never seen before the latest firmware. the cables are ruipro and for two years now they have never given problems. this only happens with streaming content
gattorodolfo is offline
post #7794 of 8025 Old 05-18-2020, 05:07 AM
Ash Sharma's Avatar
Liked: 920
If you install the previous firmware and the micro stutters go away please post and I will do the same.
Thanks in advance.
post #7795 of 8025 Old 05-18-2020, 05:29 AM
aka jfinnie
Liked: 2599
I've not seen this, watched a fair bit of Netflix in recent days. Worth noting I run with genlock on, which shouldn't ever have Radiance-added frame skips or doubling. If you don't run with genlock on you would always potentially see them at some point but I guess it is feasible that this has got more prevalent?
Worth noting too that there is a growing amount of 4k/24.000p content on the Netflix service. AppleTV cannot play this content correctly at 24.000p and instead plays it at 23.976p. This drops 1/1000 frames (or a frame approx every 42s) which looks like microstutters.
Other players may have the same issue or the reverse issue (24.000 playback instead of 23.976p). This might appear to fit the description of a microstutter.
There is an ever-growing and non-exhaustive list of titles here:
https://www.avsforum.com/forum/39-ne...000-video.html
Might be worth reporting what the Lumagen UI is saying for the inbound and outbound refresh rates when seeing the issues.
bobof is online now
post #7796 of 8025 Old 05-18-2020, 05:56 AM
Quoted: 88 Post(s)
Liked: 25
Can I ask what setting you have Genlock on please.
Des511 is offline
post #7797 of 8025 Old 05-18-2020, 06:40 AM
aka jfinnie
Liked: 2599
I have mine set to Auto-Fast. Cards are all 18G, projector is JVC X7900, cable to PJ is Ruipro hybrid fibre 10m. Rack cables are all 2m monoprice 18G certified slim cables.
My AppleTV setup is different to some folk in that for AppleTV I run the ATV to the AVR (Arcam AVR550) and then video out of that to Lumagen. I only do that for the AppleTV to work around some audio issues I sometimes note on AppleTV with Atmos and audio muting / dropouts due to HDR metadata changes. It works for me, but accept it's not the most recommended of setups.
I should add I'm not recommending any of the above but it "works for me".
bobof is online now
post #7798 of 8025 Old 05-18-2020, 01:46 PM
jrp
jrp's Avatar
Quoted: 515 Post(s)
Liked: 1553
For micro-stutter, we have seen this sometimes be due to HDMI cabling. However, it can also be frame drops or repeats due to the mismatch being input and output rate as bobof suggests.
Video content really should be 23.98 or 59.94, and not 24.00 or 60.00. To eliminate output restarts going form 60.00 (OSD) to 59.94 (Content), our direct commands for 4k output turn "Rate Match" to Off. While 60.00 is a legal video rate, I consider it a mistake for any consumer content as it runs against defacto usage which is either 59.94 or 23.98 Hertz.
Unfortunately if sources are outputting video content a 24.00 and/or 60.00, and the drops/repeats bother you, you need to set "Rate Match" = On, to reduce the number of dropped frames.
If you have not used a direct output mode code (MENU 087X) to manually set the output you can change this in the active output style (MENU  Output  Styles  Styles0  HDMI Format  Rate Match by default). However, if you have used one of the direct output mode codes (MENU 087X), the Rate Match is forced off and you need to undo the command with MENU 0870, and a Save. Then you would set the output rate using the Menu. Please note I am talking to Patrick about either new manual output mode command that do not turn off Rate Match, or a way to again enable Rate Match after using a MENU 087X manual output mode code.
The only way to completely eliminate the frame drops and repeats completely is to turn on Genlock for the rate(s) you notice with the "micro stutter." If you still see the frame drops/repeats with Rate Match = On, then you should try Genlock on using MENU  Input  Options  Genlock  (Off, Auto24-Normal, Auto24-Fast, Auto-Normal, Auto-Fast, command. Frame drops/repeats are more noticeable at 23.98 Hertz. If you do not notice them at 59.94 Hertz, try Auto24-Normal, and if you do notice them at 59.94 Hertz try Auto-Normal.
Genlock should eliminate the frame drops/repeats, but be aware of the following:
- If a 60.00 source is active and "Rate Match" is Off, the output is 59.94. Genlock will not lock on in this case, and so it will be disabled due to this small, but significant, difference.
- Genlock increases switching time. If you have a projector with a long lock on time (most do it seems), this will be a very noticeable increase.
- I recommend having one memory with Genlock Off (e.g. MEMA), and a second with Genlock On (e.g. MEMB). Then you can switch and channel surf as before using MEMA. Then when you get to a program you want to enable Genlock for, press Pause, then switch to MEMB, wait for the picture to return, then press Play.
- For sources that are mostly used for 24 Hertz content like Bluray players, I suggest you consider using the Radiance Pro's Output Setup Menu to program a Output Style for that specific input to always outputs 24/23.98. I program our Radiance Pro this way for our Oppo 203, and our Strato, players. Since I am always starting and stopping content this means I pay the projector HDMI restart time when I first select that input.
- If you have an Oppo 203, I suggest you consder programming the OSD to always output at 24 Hertz if you are like me and use it to view movie content. This allows the movie to start without changing the rate out of the player to the Pro.
jamesmil, bjorg, giomania and 5 others like this.
Jim Peterson
Lumagen
jrp is offline
post #7799 of 8025 Old 05-20-2020, 09:39 AM
Mike_WI's Avatar
Quoted: 510 Post(s)
Liked: 456
JVC and Lumagen Team Up
From AVS Insider Email
(glad to hear about collaboration)
JVC and Lumagen Team Up For Unmatched HDR Performance
In a recent press release, JVC announced it was teaming up with video processing powerhouse, Lumagen, to bring unparalleled video performance to JVC's native 4K DLA-RS4500 laser home theater projector. Chief among the upgrades offered is a reference HDR dynamic tonemapping solution which allows for frame by frame analysis and compensation. DTM elevates the already stellar performance of the RS4500 to a new level.
To get the most from this combination of hardware, both JVC and Lumagen recommend Kris Deering of Deep Dive AV for setup and calibration. While the RS4500 and Lumagen Radiance Pro video processor are intuitive enough for end-user setup, ensuring the absolute best performance requires a knowledgeable calibrator such as Kris to get the most from the hardware.
Kris Deering added that his "goal is to optimize the visual experience through advanced calibration and comprehensive system setup. The Deep Dive AV-JVC/Lumagen combination provides the best of both worlds: stunning picture quality and minimal operator intervention. Simply turn the system on, select an input, sit back and enjoy."
The press release went on to state the specific performance upgrades the Lumagen processor adds:
1. Dynamic Tone Mapping for 4K HDR material – Dynamically analyzes HDR images on a frame-by-frame basis and automatically adjusts the brightness and color to optimize HDR performance for each scene, and each frame.
2. Superior 4K Upscaling – Lumagen is renowned for the quality of their No-Ring™ scaling.
3. Advanced Calibration Capability – Allows for comprehensive 1D and 3D LUT calibration to extract the best possible performance from the JVC projector and any input source.
4. Custom sizing and aspect ratio geometry controls for optimal display of all content.
5. Auto Aspect Ratio Selection for UltraWide Screens – Properly display any aspect ratio within the UltraWide screen automatically, preserving the source’s intended aspect ratio.
6. Non-Linear Stretch – Automatically adjusts 16:9, and higher, aspect ratio sources to fill an UltraWide screen.
HT Details: link
Mike_WI is offline
post #7800 of 8025 Old 05-20-2020, 10:46 AM
Craig Peer's Avatar
Quoted: 8048 Post(s)
Liked: 10604
I feel extremely fortunate to have a JVC RS4500, a Lumagen Radiance Pro, a Panamorph DCR lens and to have had my system calibrated by Kris Deering too.
Ian_Currie, SJHT, JFR0317 and 11 others like this.
Craig Peer is online now
Reply Video Processors
