New Lumagen Radiance Pro Series - Page 33 - AVS Forum | Home Theater Discussions And Reviews
 3121Likes
post #961 of 4878 Old 11-10-2016, 12:10 PM
LJG
LJG's Avatar
Quoted: 701 Post(s)
Liked: 410
Originally Posted by OMARDRIS View Post
Hi,
The Sony VW5000ES is such a good projector that I would advise you to contact you with Gordon Fraser. I know he has done exactly what I've described.
Peter
Gordon? Can you assist? This would be an extremely beneficial feature to the many 5000ES owners out there....
LJG is online now
post #962 of 4878 Old 11-11-2016, 01:20 AM
Gordon Fraser's Avatar
Quoted: 233 Post(s)
Liked: 281
Sorry i haven't sene this thread. I have been out for the last two weeks doing exactly this sort of thing for a ton of clients in UK with Sony, JVC and Epson projectors.
I am late to go out to do yet another (Sony 320 and Pro 4242) today so short answer.
Yes, right now you can profile your display and create a LUT to view HDR material on HDR or non HDR enabled displays with a Radiance. In my tests i've found the best results are to set the GLOBAL VIDEO HDR rec2020 both to ON. This makes sources know they can output those signal types even if the display cannot show them. Then assign the CMS bank you want to use to the REC2020/HDR section of Pro. Then change COLOURSPACE of CMS bank to SDR709. This stops Radiance from outputting HDR REC2020 info frame to display so you wont have your HDR enabled display bouncing in to it's crappy HDR mode when you don't want it to. Then find the widest gamut, brightest light output mode with most linearity available. Then profile away. I then usually make a three different LUTs with varying roll off points and roll off amounts to find the best viewable option on the display system i am working on.
mikela, Wookii and ARROW-AV like this.
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #963 of 4878 Old 11-11-2016, 03:27 AM
Hello, World!
Mark_H's Avatar
Quoted: 365 Post(s)
Liked: 257
Gordon, in your opinion, how does this faux-HDR look on projectors?
My cinema: The Cave!
My kit: 15' 2.35:1 Screen Research CP2 4-way mask, JVC Z1, Lumagen Pro, Meridian 861/621/7x5500/2xSW5500
Mark_H is offline
post #964 of 4878 Old 11-11-2016, 03:38 AM
Wookii's Avatar
Quoted: 2861 Post(s)
Liked: 2049
That's great Gordon - that will also allow the full use of the DI on the current line of JVC projectors also, which is currently disabled with a HDR input signal. Hopefully that will help address one of the major issues with using HDR on a PJ, which is the raised black floor on dark scenes as a result of running at max (or close to max) light output.
I guess I need to see if i can get my head around using Lightspace, given that Spectracal don't seem to be making much progress in this area with the Radiance Pro.
Wookii is offline
post #965 of 4878 Old 11-11-2016, 03:46 AM
Quoted: 233 Post(s)
Liked: 281
Mark,
It does depend on the system. The LS10000 I did yesterday was on a small screen and i was measuring 186nits full field on it. The client also had a 4K Panasonic 900 series LCD TV and i thought the HDR we got on the proejctor was much better than on the TV... as the black level was so raised when you whack up the backlight.....I thought yesterdays was great. the Sony320 i am working on now is getting 60 nits....it's going to be interesting...
Convergent-AV
post #966 of 4878 Old 11-11-2016, 05:41 AM
LJG
LJG's Avatar
Quoted: 701 Post(s)
Liked: 410
This sounds really great!!! There are times even with the 5000ES that the HDR version of the 4K UHD is lacking, and the SDR version is preferred this option that the Lumagen offers is very welcomed.
LJG is online now
post #967 of 4878 Old 11-14-2016, 04:11 PM
p5browne's Avatar
Quoted: 3991 Post(s)
Liked: 3166
http://www.lumagen.com/testindex.php...ncepro_updates
Beta 102916- Fixed bug in version 102116 that in some cases could cause audio problems. Fix for input setup not using correct input configuration in some situations. Fix for issue that in some custom mode setups would make the menu unreadable. Fix for a couple video loss issues. Some minor menu fixes. Please continue giving us your detailed feedback on issues via email at [email protected] .
Update time ~1 minute @230k from previous firmware
Eventidal likes this.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #968 of 4878 Old 11-15-2016, 07:05 AM
tspotorno's Avatar
Quoted: 128 Post(s)
Liked: 55
FYI, this update fixed all of the audio dropout issues that I was having with the Strato and the Panasonic UHD player!
However, my DirecTV DVR HR24-500 will not pass the audio thru the Pro to the RS20i. I have to run standard stereo cables... Anyone else having issues with their DirecTV boxes?
Mike_WI likes this.
Sony VW5000 | Stewart Vistascope 14' ST100 screen
Datasat RS20i | 3 x MC601 | 1 x MC205 | Oppo 205 | Lumagen Radiance Pro
B&W 800 / HTM 2 Diamonds | 4 x Paradigm ADP3 | 2 x Fathom F212 | 4 x ML Vanquish
D-Box HEMC & 2 x SRP 330 platforms | Synology DS3615xs 12x6TB drives
tspotorno is online now
post #969 of 4878 Old 11-15-2016, 10:06 AM
Quoted: 253 Post(s)
Liked: 111
I was having big issues with the Pana 900 while switching from blu ray to Netflix. The screen would turn dark and I would have to turn the radiance completely off to get a signal. Also I would demand to change the position of the Darbee in the processing chain as all of my sources (Satellite Sky, Pana UHD, PS4 etc.) are 4k now and they output 4k even if the material is 1080 or below. The point is, that even if I convert the signal within the radiance I cannot use the Darbee as it is in first position...
Eventidal is offline
post #970 of 4878 Old 11-16-2016, 02:13 AM
mhafner's Avatar
Quoted: 246 Post(s)
Liked: 106
Genlock
Has the genlock bug with the JVC projectors been fixed?
mhafner is offline
post #971 of 4878 Old 11-16-2016, 02:17 AM
Wookii's Avatar
Liked: 2049
Not as far as I am aware, no. I was under the impression they were going to roll back to the Genlock code that was in the Pro originally, and did work great with the JVC's, but they must have chosen to take a different route as I've still not seen Genlock changes appear in any recent firmwares.
Wookii is offline
post #972 of 4878 Old 11-16-2016, 11:44 AM
SJHT's Avatar
Quoted: 1022 Post(s)
Liked: 681
What calibration material from the Lumagen Pro are folks using to set brightness with using STANDARD PIC on JVCs? In the past, I have used enhanced which allowed "blacker than black" making calibration easier, but most feedback from the JVC forum is that calibrators are using STANDARD. Just curious. Contrast is straightforward with the ramp pattern and I so use that same pattern for setting brightness. Maybe a bit off topic, but thanks.... SJ
SJHT is offline
post #973 of 4878 Old 11-17-2016, 09:29 AM
rfpublic's Avatar
Quoted: 21 Post(s)
Lumagen has the JVC genlock issue on our list. We just raised the priority for working on this issue.
Randy Freeman
Mark_H and Wookii like this.
rfpublic is offline
post #974 of 4878 Old 11-17-2016, 06:36 PM
p5browne's Avatar
Liked: 3166
Beta # 102916 - Don't use---has bug with selecting output mode correctly. Wait for next FW update.
UN65KS9800 - Mine
p5browne is offline
post #975 of 4878 Old 11-18-2016, 07:05 AM
Mike_WI's Avatar
Quoted: 434 Post(s)
Liked: 411
Beta 110116-
Fix for output mode selection issue in 102916 and includes all other improvements listed in 102916 update.
Fixed up an issue in 101416-102916 firmware that could cause loss of video in some situations like fast forwarding with some source devices.
Update time ~1 minutes @230k from previous firmware
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & 18 GHz output x1 cards} - "new (112818 FW)" 18 GHz microcode - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #976 of 4878 Old 11-18-2016, 05:35 PM
dlinsley's Avatar
Quoted: 492 Post(s)
Liked: 379
USB extender or long RS232 for calibration?
I've asked Lumagen for a recommendation, but thought I'd ask the collective wisdom here too.
I'm currently remodeling, and my equipment is moving from about 10' from the screen to a closet at the back of the room about 25' from the screen. During calibrating, I guess I could extended the colorimeter/spectro USB cable but presumably the easiest option is to keep my laptop on the floor by the screen as I have been doing and instead extend the connection to the Radiance. Has anyone used a long USB extender or just a long RS232 cable? Till now I was using USB during calibration to avoid unplugging the control system from the RS232, but I may not be using that when I put everything back together.
armando garcia likes this.
dlinsley is offline
post #977 of 4878 Old 11-18-2016, 11:52 PM
alex_t's Avatar
Quoted: 78 Post(s)
Liked: 130
Hello.
USB supports length up to 5 meters. Beyond that you need to add an active repeater.
RS232 has theoretically no limit for the length but, actually, the speed for data transfer (baud) decreases according to the total length.
For length more than 5 meter I would use the RS232 port or an active USB repeater if you prefer USB.
dlinsley likes this.
alex_t is offline
post #978 of 4878 Old 11-18-2016, 11:58 PM
Quoted: 233 Post(s)
Liked: 281
As i have used a USB to serial adapter with my leptop since the days of the original Lumagen vision series i continue to do so. I have a 10m extension cable i plug in to my 2m null modem cable and my short usb to serial adapter and this works no problem. I have used this on an old samsung win7 laptop, a macbook (2012) and two macbook pro's from 2010 and 2016....
dlinsley and Surfdrifter like this.
Convergent-AV
post #979 of 4878 Old 11-19-2016, 12:03 AM
alex_t's Avatar
Quoted: 78 Post(s)
Liked: 130
Hello Gordon,
I do exactly the same. USB to serial plus a straight extension RS232 cable (12m).
Gordon Fraser and dlinsley like this.
alex_t is offline
post #980 of 4878 Old 11-19-2016, 01:47 AM
Hello, World!
Mark_H's Avatar
Quoted: 365 Post(s)
Liked: 257
Using about 20' of USB here without issues. Previously I'd run a long RS232 cable and have to unplug the Radiance from the Crestron control, but no more. USB for the win!
Mark_H is offline
post #981 of 4878 Old 11-19-2016, 07:39 AM
dlinsley's Avatar
Quoted: 492 Post(s)
Liked: 379
Thanks everyone, so both work well
I still have the USB-Serial adapter I used with my XD (and would have to feel around back to switch it over) but with the Pro I switched to USB to leave the RS232 plugged in. The Radiance will be barely using 5% of even USB 1's bandwidth, so I'll just go with whatever Fry's have in stock.
dlinsley is offline
post #982 of 4878 Old 11-19-2016, 02:44 PM
jjcook's Avatar
Quoted: 463 Post(s)
Liked: 188
You can try a Tripp Lite USB repeater cable; I haven't used it with my Radiance 2143 but it's worked perfectly fororher applications:
Tripp Lite USB 2.0 Hi-Speed A/B Active Repeater Cable (M/M) 25-ft. (U042-025) https://www.amazon.com/dp/B00BFRKYSU..._VvnmybFDH7NA8
jjcook is offline
post #983 of 4878 Old 11-19-2016, 09:38 PM
dlinsley's Avatar
Quoted: 492 Post(s)
Liked: 379
Thanks! I've ordered the 36' version (great price for both this and the 25') as I can leave it plugged into the Radiance in my rack and then bundled up in my rack drawer ready to just slide open and unspool when I need it - with enough length still to get to the far end of the room. Perfect.
With the frequency of updates from Lumagen, I can just relax in a chair too rather than being tied to the rack
mikela likes this.
dlinsley is offline
post #984 of 4878 Old 11-20-2016, 01:06 PM
MJV29's Avatar
Quoted: 60 Post(s)
Liked: 29
Could you let us all know if this works for you? I would love to be able to do the same thing.
MJV29 is offline
post #985 of 4878 Old 11-20-2016, 01:34 PM
dlinsley's Avatar
Quoted: 492 Post(s)
Liked: 379
Will do. It may be a while to do so in anger, but I can plug my Radiance in just to try it when it comes.
My build thread is way out date, with much changes but I'm on the down slope now (I hope!)
MJV29 likes this.
dlinsley is offline
post #986 of 4878 Old 11-21-2016, 12:09 PM
ConnecTEDDD's Avatar
Quoted: 2921 Post(s)
Liked: 3569
Light Illussion has released a Beta Version of LightSpace CMS 7.1.7.2513 (21 November 2016) which adding an HDR Multiplier feature for HDR Projection.
This gives the capability to test different Luminance multipliers, like 2x or 6x or 10x etc. to see which looks better to your setup, since the 3D LUT correction generation is very quick (2-3sec).
With projectors since they are not officially supported for HDR, you can use the x10 'Cheat'. (I have posted an example here: https://www.avsforum.com/forum/24-dig...l#post47096753)
This is basically what Dolby do with their HDR projection.
So the 100nits peak white output projector is treated as if it were 1000nits.
The normal HDR EOTF is then applied as for 1000nits.
But now you can try different luminance multiplier values using that LightSpace Beta.
If there are users that are interesting to take a test drive; I can provide them a download link, just contact me here.
jamesmil, turls, mikela and 3 others like this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #987 of 4878 Old 11-21-2016, 02:30 PM
turls's Avatar
Quoted: 509 Post(s)
Liked: 225
Has anyone used a Dune Solo 4K with Radiance Pro? I have .ISOs that won't play in 3D on it, and these are .ISOs that play with a Mede8er through the Radiance Pro, and in another room through a seperate matrix video setup using Dune HD Base 3D.
Newest beta firmware on both boxes.
EDIT: was some type of glitch (support is telling me I have cabling issues with the inconsistency I have with this box and various sources). Worked last night. Only different I know of was a different day and maybe a different power on order (although I tried some power cycling the other night without success).
Matt
turls is offline
post #988 of 4878 Old 11-21-2016, 02:56 PM
Liked: 3569
About LightSpace and HDR, there added some more info, including with the new projection multiplier, to the website: http://www.lightillusion.com/hdr_calibration.html and http://www.lightillusion.com/lut_man...e_colour_space
post #989 of 4878 Old 11-22-2016, 09:06 PM
p5browne's Avatar
Liked: 3166
Beta 110416- Fix for an issue causing banding with HDR or Rec2020 sources. Please continue giving us your detailed feedback on issues via email at [email protected] .
Mike_WI likes this.
UN65KS9800 - Mine
p5browne is offline
post #990 of 4878 Old 11-23-2016, 05:39 AM
Wookii's Avatar
Liked: 2049
Originally Posted by ConnecTEDDD View Post
Light Illussion has released a Beta Version of LightSpace CMS 7.1.7.2513 (21 November 2016) which adding an HDR Multiplier feature for HDR Projection. . .
Ted, would I be right in thinking that a user would currently need to produce a separate 3D LUT, in different CMS slots, for each disc mastering level (1000 nits, 4000 nits, 10000 nits etc) and switch between them manually as required?
I assume the end game is for the Radiance to inspect the incoming HDR metadata and select the correct LUT on the fly?
Mike_WI likes this.
Wookii is offline
Reply Video Processors
