New Lumagen Radiance Pro Series - Page 58 - AVS Forum | Home Theater Discussions And Reviews
 4211Likes
post #1711 of 5998 Old 07-05-2017, 08:41 AM
SJHT's Avatar
Quoted: 1131 Post(s)
Liked: 757
What's the deal with this latest bunch of firmwares? Can't recall seeing so many replacements so quickly. Not sure I want to update.
SJHT is offline
post #1712 of 5998 Old 07-05-2017, 09:21 AM
Mike_WI's Avatar
Quoted: 445 Post(s)
Liked: 333
FW updates 062217-062617
Originally Posted by Mike_WI View Post
http://www.lumagen.com/testindex.php...ncepro_updates
Beta 062317
(replaced 062217 due to small osd issue)
Fixed an issue that could sometimes cause of loss of video output.
Fixed a bug causing output mask not to work.
Improvements to HDR intensity mapping.
Please continue giving us your detailed feedback on issues via email at [email protected] .
Update time ~1 minutes @230k from previous firmware
Is there a way we can sign up to get notified of updates?
Since not tied into a network notification, need to check AVS or the primary support site to see it.
Mike
EDIT
7/2/17 6:30pm - That FW just left screen (after I just updated it on Lumagen). FW must have been pulled for another one?
Originally Posted by Gordon Fraser View Post
some folk are having problems with it. they are working on fix
Beta 062517
(replaced 062217-062317)
Beta 062617
(replaced 062217-062517)
Fixed a display EDID issue that would prevent Pro from automatically using an 18Ghz output mode for some displays (Sony5000 projector being notable case) so the Pro would use 4k60 with 420 color when it should of used 4k60 422.
Looks like small system specific issues.
I have been so busy with outside activities that I have updated FW without viewing content after FW update.
Hopefully all works.
Watching last two episodes of Game of Thrones Season 6 tonight to prep for new season.
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & 18 GHz output x1 cards} - "new (112818 FW)" 18 GHz microcode - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #1713 of 5998 Old 07-07-2017, 11:44 AM
Mike_WI's Avatar
Quoted: 445 Post(s)
Liked: 333
Arrow FW Beta 070117
Beta 070117
Fixed up auto input selection which is enabled and configured in the menu under Other: I/O Setup: Auto Select .
Added Dobly Atmos flag to the global common audio formats (if you've already enabled common audio formats with "menu 0943" the Atmos flag will now be present).
Not all audio sources needed to see the Atmos flag but some sources do.
Fixed up a bug in 062617 which could cause no video on output.
HT Details: link
Mike_WI is offline
post #1714 of 5998 Old 07-09-2017, 05:54 PM
Rise & Grind
dinamigym's Avatar
Quoted: 326 Post(s)
Liked: 294
Not sure if it's just me but I've had major sync issues with my 5000 since both the 6/26 and 7/1 updates. Rolled back to 6/1 and everything appears back to normal. I have a 4242 all 18g ports.
Trinnov Altitude 16, Magico A3, Magico ACC, Magico A1s, Dual Rythmik FV25HP
Amps- ATI AT523NC, AT524NC, AT528NC
Kaleidescape Terra Server/Strato, Oppo UDP-203, Apple TV4k, XFinity X1
Sony VPL-VW5000, 136" 2.35:1 Stewart Studiotek 100 screen, Lumagen Pro 4242
dinamigym is offline
post #1715 of 5998 Old 07-09-2017, 07:58 PM
netroamer's Avatar
Quoted: 296 Post(s)
Liked: 94
I assume you mean audio/video lipsync. I just tried to play a 4k hdr stream from Fandango and the audio was more than a minute behind the video.
John
netroamer is offline
post #1716 of 5998 Old 07-10-2017, 01:31 AM
Gordon Fraser's Avatar
Quoted: 238 Post(s)
Liked: 297
no i think he meant syncing of video to the VW5000
dinamigym likes this.
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #1717 of 5998 Old 07-10-2017, 09:06 AM
Rise & Grind
dinamigym's Avatar
Quoted: 326 Post(s)
Liked: 294
Yes...sorry if I was confusing yes could not sync video until I rolled back to 6/1
post #1718 of 5998 Old 07-10-2017, 09:30 AM
Mike_WI's Avatar
Quoted: 445 Post(s)
Liked: 333
Video Syn Problem
Could not video-sync at all or "problems" syncing?
Describe the problem(s).
Mike
HT Details: link
Mike_WI is offline
post #1719 of 5998 Old 07-10-2017, 09:36 AM
Rise & Grind
dinamigym's Avatar
Quoted: 326 Post(s)
Liked: 294
Mike
Video sync was very difficult and often times required turning everything off and on several times to obtain. Even once sync occurred image would flash in and out quite often. Then if I tried to change sources from say KScape Strato to Comcast the video sync again required turning things on and off several times and even then left me without image for long periods of time. I'm talking long enough to where 5000 would go to standby mode.
post #1720 of 5998 Old 07-10-2017, 02:54 PM
msleb's Avatar
Quoted: 29 Post(s)
Has anyone installed the 070117 firmware and had NO sync issues, especially with a 5000ES? I was about to install tonight, can understand that some people might have issues, but would feel better if others have had uneventful installations
msleb is offline
post #1721 of 5998 Old 07-10-2017, 03:58 PM
Mike_WI's Avatar
Quoted: 445 Post(s)
Liked: 333
I installed it.
Gear in signature.
Sync takes a while with my chain (Oppo 203 -> Lumagen -> JVC) but it worked.
I have also (somewhat) recently updated the FW in JVC RS520 to latest and updated to latest Oppo FW.
Mike
HT Details: link
Mike_WI is offline
post #1722 of 5998 Old 07-10-2017, 04:12 PM
msleb's Avatar
Quoted: 29 Post(s)
I installed it.
Gear in signature.
Mike
Thanks Mike, it sounds like you made a few changes at once? Is the increase sync/handshake time notably longer with current firmware? I have Oppo 203 --> Lumagen --> Sony 5000.
Sounds like there might be a few more kinks to work out?
msleb is offline
post #1723 of 5998 Old 07-10-2017, 06:32 PM
Mike_WI's Avatar
Quoted: 445 Post(s)
Liked: 333
Clarification: I haven't noted any new syncing problems with latest FW.
Was just trying to point out the many links in the chain for most of us -- and in my case different FW updates.
The JVC sync time seems long. Not sure if the newest JVC FW fixed that.
The Lumagen FW seems stable for me.
msleb likes this.
HT Details: link
Mike_WI is offline
post #1724 of 5998 Old 07-11-2017, 05:53 AM
jabz's Avatar
Quoted: 165 Post(s)
Liked: 70
Hi, Im considering getting the Lumagen Pro for my 4K setup as I have an A-Lens and because of the recent HDR intensity mapping capabilities, also would like to get the best out of my VW520 HDR capability.
I have an Xrite i1 Pro that I purchased from Amazon a couple years back and Chromapure 2.x with Autocal licence. I am not sure if I should upgrade to Chromapure 3.x or get LightSpace as that has been talked about a bit in this forum. Does LightSpace have an Autocalibration feature? There's several versions, which version works with the Radiance Pro?
Sony VPL-VW520 | Elitescreens TT 135" 2.35:1 | Elitescreens TT 120" 16x9 | Prismasonic HD-6000F | Onkyo TX-RZ3100 | Oppo UDP-203 | PS4 PRO | ATV4K | LG OLED 65 C7 | Klipsch Reference RP-280 | Klipsch Reference RP-280C | Klipsch Reference RP-250S | Klipsch Reference RP-150M | Klipsch Reference R-115SW | Klipsch Reference R-140SA
jabz is offline
post #1725 of 5998 Old 07-11-2017, 01:56 PM
sillysally's Avatar
Quoted: 1182 Post(s)
Liked: 1053
I use LightSpace Pro and have for many years. I also have a Pro 444x and LightSpace works like a charm with the 444x for auto cal and as a pattern generator for any size triplet window patterns and APL from 0 to 100%.
All you do is run a profile (any size you want), and then use that profile to experiment with color spaces to tone mapping when making one or many 3DLUT for the Pro 444x from the same profile. All you need to do is setup your white point, meter, set how many color points you want to profile. Once the profile is done set your color space and tone mapping to make the 3DLUT, LightSpace does the rest with auto cal.
The more measured color points you set the longer the time for running the profile in autocal.
Making the 3DLUT with autocal only takes about 5 seconds and then is ready to load into the 444x memory's.
Ted, Steve or Gordon can give you a better idea of what level of LightSpace would suit your needs.
I use about 9200 color points when running a profile. What I do is start the profile and go to bed. When I wake up the profile is done and my display is blanked out, black screen so no burn in.
ss
"Don't worry be happy"
LG77C8, Klein K10-A, Jeti 1211, CMS Lightspace, Calman home plus licence for K10-A, Murideo 6G.
sillysally is offline
post #1726 of 5998 Old 07-12-2017, 08:08 AM
SJHT's Avatar
Liked: 757
We need that Gordon Lightspace/Lumagen guide....
SJHT is offline
post #1727 of 5998 Old 07-12-2017, 08:27 AM
leemathre's Avatar
Quoted: 64 Post(s)
Liked: 51
I need the "For Dummies" version.
Lee Mathre
Las Vegas, NV
leemathre is offline
post #1728 of 5998 Old 07-12-2017, 08:39 AM
SJHT's Avatar
Liked: 757
Me too. Even just creating a basic LUT for SDR. Somebody tell me "use this value, check this box, etc.". Mine come out horrible and I go back to Calman. SJ
Mark_H and leemathre like this.
SJHT is offline
post #1729 of 5998 Old 07-12-2017, 07:08 PM
Mike_WI's Avatar
Quoted: 445 Post(s)
Liked: 333
Arrow FW Beta 070217
Beta 070217
More reliable and faster input switching in some cases than firmware 052017-070117.
HT Details: link
Mike_WI is offline
post #1730 of 5998 Old 07-13-2017, 04:17 AM
ConnecTEDDD's Avatar
Quoted: 3397 Post(s)
Liked: 4227
Hi,
If you have X-Rite i1PRO (Spectrophotometer) then you will need to get the X-Rite i1Display PRO (Colorimeter) to be able to take measurements for 3D LUT (because stand alone i1PRO is slow and poor at low light measurements), you will use i1PRO as a reference to create a meter correction table (which will improve the colorimeter color accurancy) while i1Display PRO is a lot faster and very good at low light measurements, so having both meters it's be best combo for any home calibration enthusiast.
LightSpace is the oldest software in the market which designed for 3D LUT display characterization, think that they were involved in pro area for 3D LUTs from 2009, no-one knew at HT area that time what was a 3D LUT....ChromaPure released @ August 2009 while CalMAN had version 3.0 out that time
So when LightSpace was creating 3D LUT profilings for thousand color points for movie/film industry (with 1 meter read per color) the same time ChromaPure/CalMAN has able only to measure (graphical presentation what meters was reading, dE calculation, generate graphs from reading) of 11-point Grayscale and simple Gamut readings (6 colors only, RGBCMY).
These facts show exactly how advanced color science LightSpace had before a lot of years for 3D LUT's and can guarantee you professional level of final results.
LightSpace's Chief Colour Scientist is the same person that developed the Colour Pipeline for Industrial Light & Magic (ILM: George's Lukas Motion Picture Effects Company), WETA Digital (Peter's Jackson Visual Effects Company) & Park Road Post (Peter's Jackson Post Production Facilities). Their Chief Colour Scientist was also responsible for the colour science in TrueLight; as you can see there's a large amount of colour science knowledge behind the LightSpace's Engine.
LightSpace is reading one point one only time, so for a 4913 color point 3D LUT it takes 4913 meter readings for example, doing this... LightSpace will know better how your projector/display is responding and about what colors can display and created a virtual model of your display to feed it's engine... The more points you feed it's engine, the greater idea of what your display is capable and what corrections can be applied, so LightSpace generates a correction 3D LUT table at once for all color points together, so it counts linearity of the correction, more smooth, and with better final results, and it will avoid to try to fix something that can't fixed or try extreme corrections to get you low dE somewhere but not good result later validating visually etc.
When you finish the measurement with LightSpace it saves one measurement data file. You use that file to generate the colorspace correction 3D LUT tables. The correction generation takes about 2-3 seconds only. For example you can generate different corrections in a few seconds, with different gamma, for example one correction with 2.2 Gamma, other with 2.3 Gamma other with 2.4 other with BT1886, so from one measurement run you can generate as many colorspace conversion you like, with different gamma values, without needing to take new measurements. When a newer version of LightSpace will be released and you see that at it's release notes the colorspace engine is improved for example, you don't need to take new measurements....you just install the newer LightSpace version, you opening your last measurement data file and you generate the new corrections.
Additionally from November 2016, LightSpace has added HDR Multiplier feature for HDR Projection and custom roll-off parameters which a lot of Lumagen PRO users are using already for HDR 3D LUT generation for projectors. All that time no other calibration company has something to offer similar, this is why LightSpace is the only choice for Lumagen PRO users which work as expected.
The correct license level where you can use any Lumagen processor and i1Display PRO, i1PRO1/2 is the LightSpace HTL, you can contact me for more details here: http://www.displaycalibrations.com/contact_us.html
BTW, there no annual fees for updates with LightSpace, there always free.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #1731 of 5998 Old 07-13-2017, 06:22 AM
jabz's Avatar
Quoted: 165 Post(s)
Liked: 70
Originally Posted by ConnecTEDDD View Post
Hi,
Thanks for the comprehensive explanation, certainly helps. I only have the X-Rite i1Display Pro (Colorimeter), should I also get a X-Rite i1Pro (Spectrophotometer)? to use with LightSpace?
jabz is offline
post #1732 of 5998 Old 07-13-2017, 06:34 AM
Liked: 4227
Since you have the colorimeter, you can work with that, it can work as stand-alone for 3D LUT, but if you want to improve more it's color accuracy then you have to add i1PRO2.
While i1Display PRO Colorimeter, it's fast, accurate at low light, it's not so good to measure each display spectral characteristics, so for that reason they have add some 4-5 generic tables for each display technology to select (from the factory), so it has OLED,LCD,LED,CRT, Projector selections where you load some generic corrections to fix it's inaccuracy of color measuring. The problem is that each device is unique so even if you measure 10 different projector models, they will have different spectral response, so the best thing is to create a unique correction table for each specific device you need to calibrate. For that reason you need a spectrophotometer like i1PRO2, to create a meter correction table for the i1Display PRO.
So ideally you need to have both meters, one to use it as a reference (i1PRO2) which is a spectrophotometer, so it will be used only initially to create a 4 color matrix correction table (measure White/Red/Green/Blue) with i1PRO2 and then measure the same colors with i1Display PRO (colorimeter) and after that LightSpace will calculate the offset correction, so you will use only the i1Display PRO for the whole calibration. This procedure is something you do initially.
post #1733 of 5998 Old 07-14-2017, 03:51 PM
jabz's Avatar
Quoted: 165 Post(s)
Liked: 70
I purchased the following spectrometer i1pro 2 from eBay I hope it's the right one. There's so many different names etc.
jabz is offline
post #1734 of 5998 Old 07-14-2017, 04:16 PM
Liked: 4227
Yes, it's fine, you got the correct spectrophotometer.
post #1735 of 5998 Old 07-16-2017, 04:33 PM
Liked: 4227
Hi guys, for LightSpace users using Lumagen PRO, there some additions related with HDR calibration, since I don't have a Lumagen PRO/Projector combo to test them out, I can provide a download link for any LightSpace user which want to test these new features, if he will send me a msg here: http://www.displaycalibrations.com/contact_us.html
Light Illussion has released a Beta Build of LightSpace CMS 8.0.0.2630 (15 July 2017) which adds some new HDR Tone Mapping Options.
The LightSpace's User Guide has been updated to cover these new options, here: http://www.lightillusion.com/lut_man...ace_conversion)
dlinsley likes this.
post #1736 of 5998 Old 07-17-2017, 07:53 AM
thrang's Avatar
Quoted: 2647 Post(s)
Liked: 2151
Beta 070217
This firmware has eliminated any handshake issues with my Sony 5000 that cropped up recently (as others have noted)
thrang is offline
post #1737 of 5998 Old 07-17-2017, 08:00 AM
thrang's Avatar
Liked: 2151
Every time I look at Lightspace, I go slightly blind...it is so confusing, with so many options (many of which seem completely unnecessary for home theater use) that I can never come close to making the plunge for it.
Plus they can't spell color correctly...
Hopefully a much more streamlined GUI with a better sense of presume workflow will be developed to broaden its appeal, as I do understand it does the job well.
Mark_H, darrellh44 and Eventidal like this.
thrang is offline
post #1738 of 5998 Old 07-17-2017, 08:33 AM
Rise & Grind
dinamigym's Avatar
Quoted: 326 Post(s)
Liked: 294
Yes...70217 seems rock solid!
post #1739 of 5998 Old 07-17-2017, 01:28 PM
Quoted: 120 Post(s)
Liked: 51
I am new to video processor and have a few questions. I have heard about madvr. Is the lumagen pro unit just a standalone unit with similar function to madvr? How is the scaling compared to madvr? Is the intensity mapping feature on a frame by frame basis, thus simulating the Dolby vision/HDR 10+? Can it handle non linear scaling so that i can convert all display to scope format and fill my screen?
What are the advantages of this unit if dolby vision or HDR 10+/dynamic hdr becomes more prevalent?
Thanks for any help you can provide on these questions.
Tuning is offline
post #1740 of 5998 Old 07-18-2017, 07:19 AM
SJHT's Avatar
Liked: 757
Hopefully, Gordon's upcoming dummy guide for Pro and Lightspace will help. SJ
Eventidal likes this.
SJHT is offline
Reply Video Processors
