HDFury Vertex - Owners thread - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 1132Likes
post #4321 of 4440 Old 05-06-2019, 09:43 AM
JackB's Avatar
Quoted: 1352 Post(s)
Liked: 329
Attached is a screen shot taken without the Vertex connected to the Roku and projector.
Name:	Screenshot 2019-05-06 09.40.07.png
Jack
JackB is offline
post #4322 of 4440 Old 05-06-2019, 10:37 AM
HDfury's Avatar
Quoted: 4170 Post(s)
Liked: 1147
Ok good, please export config from GUI menu and post it as attachment in your reply, thanx.
Use Automix/SINK mode for DV support on AVR-Key/Integral. Linker does NOT support all DV.
Want to get DD+ and ATMOS sound from TV streaming Apps back to an AVR via HDMI since it fails via ARC or S/PDIF?
Show interest by posting your TV and AVR brand/model. We might select you in the future for some beta test.
HDfury is online now
post #4323 of 4440 Old 05-06-2019, 10:41 AM
HDfury's Avatar
Liked: 1147
GUI displays fine although it takes up a smaller amount of screen. Do I have to have all components hooked up when taking the screen shot or can I take the shot with the Vertex in my office?
It's always better if you can export config or take GUI screenshot when signal is going thru and all devices are connected, but if you cannot, it's ok, better have a config export without any devices connected rather than no config export.
post #4324 of 4440 Old 05-11-2019, 05:22 AM
DrMichael's Avatar
Quoted: 409 Post(s)
Liked: 209
I was wondering if anyone could tell me the difference between the 4K Vertex 2 and the Diva? The only major difference I’m seeing is the ambient light control and sync. Is that correct? Thank you!
DrMichael is offline
post #4325 of 4440 Old 05-11-2019, 05:54 AM
HDfury's Avatar
Liked: 1147
Diva have ambient light, lag tester and 1080p SDR output, so only 1x 18Gbps output
Vertex have 2 x 18 Gbps output and special management of +5v at output (can solve Android TV issues)
Apart from that, they all have same features (4 inputs, webserver, dedicated audio output that can extract HDMI/ARC/EARC audio and forward to any AVR input)
post #4326 of 4440 Old 05-11-2019, 07:18 AM
DrMichael's Avatar
Quoted: 409 Post(s)
Liked: 209
Thank you!
post #4327 of 4440 Old 05-16-2019, 07:00 AM
HDfury's Avatar
Liked: 1147
Arrow Vertex Android APP update and GoBlue firmware update
There is an updated Vertex Android APP available from Google Play, it add support for Android 9.
There is also an updated GoBlue firmware that fix a small bug on iOS.
post #4328 of 4440 Old 05-16-2019, 09:30 AM
Liked: 1
cbeckstein
cbeckstein is offline
post #4329 of 4440 Old 05-16-2019, 10:23 AM
Liked: 1
cbeckstein
post #4330 of 4440 Old 05-16-2019, 10:31 AM
no_cure's Avatar
Quoted: 161 Post(s)
Liked: 127
Dangerously interested in the upcoming Vertex 2!!!
But can I ask you to please explain, in plain language, how the AUDIO OUT port works on the Vertex 2? I've asked that question in another sub-forum, but this seems to be the most relevant place for that (please forgive my low tech question, I'm drinking from the proverbial fire hose learning about all these HDMI/EDID/HDCP formats and the associated handshake issues...)
Does it strip ALL flags relevant to 4k/LLDV/HDR video portion and independently send a blank 1080p signal that contains max 192 kHz/24-bit audio only? My AVR is HDMI ver 1.3 max, but my Sony TV can do most recent 4k video formats (LLDV, HDR10), and obviously I don't want the highest EDID resolution (belonging to Sony TV) to dictate what audio can be played on my AVR.
no_cure is online now
post #4331 of 4440 Old 05-16-2019, 02:17 PM
HDfury's Avatar
Liked: 1147
Yes of course it does that, selectable 720p/1080p blackframed video that will output sound from any devices at input and/or extract ARC/eARC from Sink at TX0 (up to Atmos for high bit rate for eARC)
So don't worry, it's especially made for setup like yours.
post #4332 of 4440 Old 05-16-2019, 02:53 PM
no_cure's Avatar
Quoted: 161 Post(s)
Liked: 127
Thank you @HDfury - I'm counting on it as I've just placed an order for Vertex 2! Now the waiting starts...June 17th, are you here yet??
I presume that, since my input devices are quite common (Apple TV 4k + Cambridge Audio CXUHD disc player) you've worked any possible/known bugs and the V2 should work flawlessly with them. My only concern is the audio sink: my Krell Evolution 707 SSP (HDMI ver 1.3 only) is quite legacy and not that common...hence my HDMI audio extractor question.
post #4333 of 4440 Old 05-17-2019, 05:33 AM
HDfury's Avatar
Liked: 1147
Yes, the new generation is based on Vertex technology which is proven super reliable and widely compatible. however, a new device release can have initial hiccups, but we are here to fix any problem at light speed, for ex: we made 4 updates in 2 days for Diva
Walky likes this.
post #4334 of 4440 Old 05-18-2019, 05:48 AM
JonnyVee's Avatar
Quoted: 274 Post(s)
Liked: 163
I preordered the new Vertex2 and have a few basic questions. I’ll have an HTPC, Xbox One X, and a PS4 Pro as inputs.
- Output 1 —> Denon x4400 -> JVC x790 Projector
- Output 2 —> Denon 730H -> LG OLED B7
1. My x790 is in a seperate room. To connect the RS232/DB9 adapter. I just need a standard male to female 3.5 mm audio extension cable?
2. The Vertex will allow the two outputs to send different 4k input signals simultaneously? Therefore, I can watch movies on the projector while my kids play Xbox or PS4 on the Oled (or vice versa).
3. The Vertex will allow the two outputs to send the same 4k input signal simultaneously?
4. The Vertex can be controlled via the Logitech Harmony hub?
Thank you.
Rec Room: JVC x790 w/120" Silver Ticket screen, Denon x4400H 5.1.4 with Kef Q100 L/R, Q200 centre, T101 surrounds, Ci160er rear atmos, Energy Rc-Mini - front atmos, SVS PC-2000. Family Room: LG 65B7P OLED, Denon s730H 5.1 - Kef Q500, Q200c, Energy v-mini - surrounds. Calibration Gear: X-Rite i1Display Pro, Calman Home Enthusiast, trial & error, and a patient wife.
JonnyVee is offline
post #4335 of 4440 Old 05-18-2019, 06:00 AM
HDfury's Avatar
Liked: 1147
Thank you.
1. Yes correct.
2. Yes it's a full matrix, no problem for that
3. Yes
4. Yes (just note that it can takes a couple of weeks before codes become available on harmony db, you can also send them your own IR code list to add to your account)
Looks like you are all good
JonnyVee likes this.
post #4336 of 4440 Old 05-18-2019, 10:07 AM
ultrasilent's Avatar
Quoted: 263 Post(s)
It`s very frustrating that we don`t have such option as Full Video + audio autosense in Automix in Vertex. And that`s why no audio when HD audio bitstreamed to audio device without HD Audio support.
So many Automix modes and no such important mode...
Zidoo X9S (1.4.16.), Vertex FW 1.36.1.41,
Himedia Q10 Pro (2.0.4) > 6ft copper > Vertex > 6ft copper > SONY X9405C HDR TV (HDMI 4)
Nvidia Shield Android TV (7.1.0.) 2015 16Gb+ 1TB HDD>6ft copper >----> 6ft copper > Yamaha RX-A2020 HDMI 1.4 > SONY X9405C HDR TV (HDMI 1)
ultrasilent is offline
post #4337 of 4440 Old 05-18-2019, 10:16 AM
Quoted: 263 Post(s)
Originally Posted by ultrasilent View Post
So, as I understand, we have 2 options:
1. switch manually edid`s in vertex
2. add new EDID option in automix (explained in previous post).
1. Yes that's a solution
2. Not possible due to previous answer.
3. I would say you have a third option which is to add an EDID manager to correct AVR edid issue between Vertex top out and your AVR, insert something like Dr.HDMI 4K there and you should be perfectly fine.
How Dr.HDMI 4K can help in this situation without Automix mode (Full Video + audio autosense)?
post #4338 of 4440 Old 05-18-2019, 11:09 AM
claw's Avatar
Quoted: 2215 Post(s)
Liked: 2070
Maybe HDfury can confirm whether or not the RS232 port enclosure has been changed on the Vertex2 compared to the original Vertex.
With the original Vertex you need to purchase an extension cable with connector that will fit inside the Vertex port opening. See this post:
https://www.avsforum.com/forum/37-vi...l#post57119054
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Vertex/Linker/Integral
claw is offline
post #4339 of 4440 Old 05-18-2019, 11:47 AM
HDfury's Avatar
Liked: 1147
Yes corrected ! Any will work now.
post #4340 of 4440 Old 05-18-2019, 11:54 AM
HDfury's Avatar
Liked: 1147
Not sure what you are talking about, NATIVE flag gives best possible Audio from any connected, TOP MAX flag copy exact AUDIO specs from device at TOP OUTPUT.
AUTOMIX by definition is MIXING EDID together, there is nothing to mix on a device that have 1 input and 1 output.
As far as I recall your problem (and you should add link to discussion when you come back after many posts and you are not on the current page anymore), the AVR was corrupting the EDID by reporting wrong max bandwidth or something like that, so inserting Dr.HDMI4K will advertise correct video and audio specs always.. thus solving the problem of AVR reporting wrong data.
post #4341 of 4440 Old 05-18-2019, 02:05 PM
Quoted: 263 Post(s)
three options in one setup:
1. 4k source - vertex - AVR (HD Audio) - 1080p50 TV - I need 1080p23 and HD audio
2. 4k source - vertex - AVR (HD Audio) in stand by - 1080p50 TV - I need 1080p23 and core audio
3. 4k source - vertex - 1st output 4k TV + 2nd output AVR (HD Audio) - I need 4k and muted audio (1st output) + 1080p and HD audio (2nd output)
Problem with option 2: no audio when playing file with HD Audio. Please advice.
post #4342 of 4440 Old 05-18-2019, 02:19 PM
Quoted: 263 Post(s)
[Automix Algo]: Select the mixing algo of your choice, available algo are: Min Mixed Capabilities, Max Audio/Min Video, Top Output Priority, Bot Output Priority, Max Audio/Max Video (default)
Can you please explain every mode in fine details?
post #4343 of 4440 Old 05-18-2019, 02:45 PM
Quoted: 263 Post(s)
So, when we have one input and one output then [Automix Algo] makes no difference in EDID creation?
post #4344 of 4440 Old 05-18-2019, 03:28 PM
HDfury's Avatar
Liked: 1147
Export config when you try option 2 and explain better, if you send HD AUDIO and AVR is OFF, how do you expect this to work ?
If you believe Vertex can take HD audio and output STEREO for your TV, then answer is NO, none of our devices do any audio format manipulation.
Fine details ? what do you mean exactly ? or what is not clear ? the names are self explanatory. (ex min video/max audio = take min video capabilities from both edid and take max audio capabilities from both and build an edid out of it)
I see no relation with what I wrote and what you just wrote here but to answer your question: ALGO are USELESS if there is only ONE DEVICE AT OUTPUT.
post #4345 of 4440 Old 05-18-2019, 03:39 PM
Quoted: 263 Post(s)
Export config when you try option 2.
I just double checked my posts from this april and see that I had no problem before with Option 2. But today this doesn`t work...
Also I had problems today with Option 3: PCM instead of HD Audio to AVR.
I suppose that something goes wrong with MY Vertex...
How better reset Vertex in this case? May be some options to turn ON and OFF and back?
post #4346 of 4440 Old 05-18-2019, 03:47 PM
Quoted: 263 Post(s)
1. Export config when you try option 2 and explain better, if you send HD AUDIO and AVR is OFF, how do you expect this to work ?
2. Fine details ? what do you mean exactly ? or what is not clear ? the names are self explanatory. (ex min video/max audio = take min video capabilities from both edid and take max audio capabilities from both and build an edid out of it)
1. I expect that vertex should send proper EDID to my source and source will send HD Audio or core audio accordingly...
2. example:
[MUTE BOT TX AUDIO]: If you use an AVR at TOP output, you might want to disable sound going to equipment connected at BOT output. Here you can mute the BOT output sound.
in this case, do Vertex count BOT TX AUDIO capabilities?
post #4347 of 4440 Old 05-18-2019, 03:50 PM
HDfury's Avatar
Liked: 1147
When you have your setup working, you export config and then you can update firmware/hard reset, whatever, and restore working config anytime.
post #4348 of 4440 Old 05-18-2019, 03:53 PM
HDfury's Avatar
Liked: 1147
2. example:
1. Yes so your writing was wrong since you wrote you want to send HD audio when AVR is OFF, so try to formulate something that make sense and attach config for it if you meet a problem.
2. Muting sound have nothing to do with EDID creation. 2 separate things.
post #4349 of 4440 Old 05-18-2019, 04:19 PM
Quoted: 263 Post(s)
I never wrote than I want to send HD Audio from source when AVR is OFF. Where you red about it?
post #4350 of 4440 Old 05-18-2019, 04:20 PM
Quoted: 263 Post(s)
Is it common case that I need to hard reset Vertex from time to time to have proper result in setup?
Reply Video Processors
avr-sound
