HDFury Vertex - Owners thread - Page 153 - AVS Forum | Home Theater Discussions And Reviews
 1205Likes
post #4561 of 4945 Old 10-22-2019, 04:50 AM
HDfury's Avatar
Quoted: 5623 Post(s)
Liked: 1702
Originally Posted by Viscious82 View Post
Does this still allow the vrr video signal to work properly?
Sent from my SM-G960U using Tapatalk
Yes, it's all about getting VRR to work while extracting full audio, it's done using an unconventional way since as you might know, this is normally not supposed to work that way but we found a way and it works.
Now to make a hardware available out of it, we need some real demand for it which we don't have yet.
Viscious82 likes this.
Maestro: 4I/4O +4K HDR over HDBT +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver. [Won Best Product Award]
Diva: 4I/3O +Ambient Light +Lag Tester +4K HDR > 1080p SDR +HDMI/ARC/eARC sound to AVR input +autoswitch +webserver.
Vertex2: 4I/3O +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
HDfury is online now
post #4562 of 4945 Old 10-22-2019, 05:40 AM
Viscious82's Avatar
Quoted: 201 Post(s)
Liked: 62
Sign me up. Is it for hdmi 2.0 or 2.1 devices? Or both? Make something low cost like an avr key. My use would be for the xbox one or pc with an amd graphics card. It's too bad that you can't update the integral 2 to support it. That would be even better.
Viscious82 is offline
post #4563 of 4945 Old 10-22-2019, 05:54 AM
HDfury's Avatar
Liked: 1702
We can make it for both 2.0a/b or 2.1, and yes that cannot be made via software, it needs new hardware because as wrote above the method is unconventional.
post #4564 of 4945 Old 10-22-2019, 05:49 PM
sthompson's Avatar
Quoted: 222 Post(s)
Liked: 88
I continue to have issues with the RX unit not seeing any input. It will work fine for a few days and then it doesn't. Powering off the RX unit for 10 seconds and then plugging it back in fixes it.
The Link Powersave function on the RX unit is turned off.
sthompson is offline
post #4565 of 4945 Old 10-22-2019, 05:50 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 2161 Post(s)
Liked: 2711
Sounds like you should be posting this in the Maestro thread...
gsr is offline
post #4566 of 4945 Old 10-23-2019, 04:23 AM
HDfury's Avatar
Liked: 1702
Please use Maestro thread if any issue, I sent you a firmware via PM, please try it, if still problem with it please provide setup description and config export in maestro thread.
post #4567 of 4945 Old 10-23-2019, 03:07 PM
sthompson's Avatar
Quoted: 222 Post(s)
Liked: 88
Ah dangit - apologize for the thread placement, was looking at both and didn't check.
post #4568 of 4945 Old 10-24-2019, 06:31 PM
Quoted: 49 Post(s)
Liked: 1
Hi,
I am really need your help!
have the Hdfury Integral2 with the Jvc x5000 projector.
I read about the jvc macros and really got interesting but not understand well how to use it so, I have few questions:
1. What the macros do? changes the picture mode depending to the contact to my pictures mode or to new picture mode that exists in the Hdfury?
2.I need to download some package that suitable to my projector?
3. There is some risks that can brick my projector?
Ty
liel is offline
post #4569 of 4945 Old 10-24-2019, 07:34 PM
HDfury's Avatar
Liked: 1702
Originally Posted by liel View Post
Hi,
Ty
If you have Integral2, then please use Integral2 thread.
I suggest you read about JVC macro here: https://www.avsforum.com/forum/24-di...l#post55408090
Refer to Manni post on this link. You can download his guide to have better understanding.
And no you cannot brick your PJ
post #4570 of 4945 Old 10-25-2019, 03:06 AM
Quoted: 49 Post(s)
Liked: 1
Hi,
Ty
And no you cannot brick your PJ [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG]
The Vertex and the Integral2 isn’t the same?
I read about Manni guide but not understand well if the package is also for my projector.
What I need to do with this package? Import the file to my projector with jvc software or the Hdfury do it automatically? I am really confused... 😐
liel is offline
post #4571 of 4945 Old 10-25-2019, 05:18 AM
HDfury's Avatar
Liked: 1702
Vertex and Integral2 have similar features, but they have different support thread to not confuse readers, so please since you say you are confused already, please do not add more to it and use the right thread for the product you have
For JVC, just ask help from JVC owners in JVC thread, they will help you out. nice community.
gsr likes this.
post #4572 of 4945 Old 10-26-2019, 10:57 PM
Kazz063's Avatar
Quoted: 107 Post(s)
Liked: 103
I now have a 4K OLED as well as my 4K JVC (so the Vertex doesn't need to do any scaling etc) and my Marantz won't play nicely with two 4K displays.
What are the necessary settings for using the Vertex as just a splitter, source being the Marantz to OLED &JVC PJ please?
Kazz063 is offline
post #4573 of 4945 Old 10-27-2019, 07:11 AM
HDfury's Avatar
Liked: 1702
Nothing special, splitter is default mode so it will work out of the box. if problem, send config export (usermanual p43)
post #4574 of 4945 Old 10-29-2019, 01:11 AM
Kazz063's Avatar
Quoted: 107 Post(s)
Liked: 103
Thanks I'll reset to factory default to get back to basics and go from there, what a bout the buttons on the side?
Kazz063 is offline
post #4575 of 4945 Old 10-29-2019, 06:11 AM
HDfury's Avatar
Liked: 1702
SCALING > AUTOSCALING
HDCP > MIDDLE/AUTO POSITION
EDID > MIDDLE for 4K HDR, AUTOMIX if you also need DV support for TV.
post #4576 of 4945 Old 10-29-2019, 02:54 PM
Kazz063's Avatar
Quoted: 107 Post(s)
Liked: 103
Smile
Thank you.
Kazz063 is offline
post #4577 of 4945 Old 11-02-2019, 07:16 PM
NXR
Quoted: 22 Post(s)
Liked: 0
Ive had my Vertex for a while however I have just changed computers (both running win 10 pro). Now the GUI doesnt seem to work on my new computer, when I plug it into my old computer it works fine. Now when I click the GUI it states 'USB device open error' and 'Hardware not found'. The GUI then opens blank. I have tried diff USB 2.0 and 3.0 ports and updated MCU and FPGA. Im running version 1.37.1.44 and i have removed the lock symbol and power cycled the device. I have also gone into properties and ticked 'Override high DPI scaling behaviour' and changed it to 'System-Enhanced'.
I am unsure what the issue with the GUI could be, I changed from an Intel to AMD however that shouldn't be a problem i hope.
Any advice would be appreciated.
NXR is offline
post #4578 of 4945 Old 11-02-2019, 08:53 PM
claw's Avatar
Quoted: 2933 Post(s)
Liked: 2821
Did you install the Silabs Driver that is available on the downloads page for the Vertex?
CJ
JVC RS500 | LG B7A OLED | Denon X6400H (7.2.4) | X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | Amazon Fire TV Stick 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #4579 of 4945 Old 11-02-2019, 09:42 PM
NXR
Quoted: 22 Post(s)
Liked: 0
Sorry left that one out, yes done that too, Version 4.
NXR is offline
post #4580 of 4945 Old 11-03-2019, 01:32 AM
Liked: 0
Hello there
i am having issues with my HD Vertex fury the audio keeps dropping out when ever playing a 4k video with either dts HD MA or True HD audio
i have made sure its a latest firmware and i have power cycled it twice already still no changes audio keeps dropping out. Please help
Amit Paliwal is offline
post #4581 of 4945 Old 11-03-2019, 04:27 AM
HDfury's Avatar
Liked: 1702
You probably connected the unit to computer before driver was installed and windows took them from internet which won't work, so just removed them, reboot, reinstall, reboot, connect ,wait for usb notification from windows and then proceed.
Originally Posted by Amit Paliwal View Post
Hello there
You already asked same question on support server, please use ONE WAY to ask for support only, otherwise we delay others and repeat same thing for nothing.
you prolly need to use AUTOMIX with TOP OUT flag checked if AVR is at TOP OUT.
if that does not help, export your config (usermanual p43) and add it as attachment in your post.
post #4582 of 4945 Old 11-04-2019, 07:12 AM
Bytehoven's Avatar
Quoted: 1612 Post(s)
Liked: 1277
@HDfury
Are there other LLDV EDIDs I could try with the Vertex besides the Sony A1 LLDV v2 EDID which came with the 1.32 update? I have the lastest 1.37 flash installed.
I've had success testing this setup...
Sony x800m2 4k hdr/dv player -> Vertex -> JVC x990 (rs640) projector
... but I'm curious if any other player led protocols are available to test.
JVC DLA-X990 - 128" 2.35 1.3 Gain Screen - Vertex2 - X800M2 - UB820 - ATV4K64 - ROKU Ultra - PS4 - XBone
7.1.4 Atmos - Denon X4300H + Denon 3806(LCR) - JBL Control 5 - BIC Sub - Dayton
Bytehoven is offline
post #4583 of 4945 Old 11-04-2019, 07:18 AM
HDfury's Avatar
Liked: 1702
Originally Posted by Bytehoven View Post
@HDfury
No, if you have Sony Player, then A1 should give best possible results, or ask EDID dump from people who have latest A9 and such, may be its a bit different but I don't think so.
EDID.tv also have some TV EDID available.
Bytehoven likes this.
post #4584 of 4945 Old 11-04-2019, 07:23 AM
Bytehoven's Avatar
Liked: 1277
Gracias ... can you comment on what benefit I might gain from the more robust LLDV support in the Vertex2, Diva or Maestro?
I noticed the ability to better automate some functionality like turning LLDV on/off depending on the source material.
post #4585 of 4945 Old 11-04-2019, 10:16 AM
claw's Avatar
Liked: 2821
@HDfury
If you download the HDfury EDID Collection zip file from the Download page of any of the products, in the Diva EDID Tables folder there is an LG C8 LLDV EDID that you can load.
LGC8-CUSTOM8-DIVA-FULLAUDIO-LLDV.bin
It is included in my Diva's list of custom EDIDs, but not in other products it seems.
I could be wrong, but it is my impression that the LLDV output from either my Oppo and ATV4K differs when using the Sony A1 vs the LG C8 LLDV EDID. This is when playing Dolby Vision UHD discs in my Oppo and Dolby Vision titles from Apple TV+.
CJ
claw is offline
post #4586 of 4945 Old 11-04-2019, 11:43 AM
Bytehoven's Avatar
Liked: 1277
Hi Claw...
The image from the Sony A1 LLDV and the LG C8 LLDV are different. I assigned that LG EDID to one of the open custom tabs (#8 which previously did not operate at all, giving me only snow). The Sony EDID looks better to me, as far as what I have reported in my observations, like the Endgame Open with Tony and Nebula playing "football", where the peak white lumens from the bright scene objects like the table, sparks and star fields, look much better, brighter, natural with the Sony EDID. This probably reflects @HDfury 's comment regarding what might be the best match for the x800m2 and the x990.
post #4587 of 4945 Old 11-04-2019, 05:43 PM
claw's Avatar
Liked: 2821
Hi Claw...
As I mentioned in another thread I get better results using the LG EDID in combination with my Oppo and JVC RS500.
CJ
claw is offline
post #4588 of 4945 Old 11-05-2019, 05:25 AM
HDfury's Avatar
Liked: 1702
Hi Claw...
The image from the Sony A1 LLDV and the LG C8 LLDV are different. I assigned that LG EDID to one of the open custom tabs (#8 which previously did not operate at all, giving me only snow). The Sony EDID looks better to me, as far as what I have reported in my observations, like the Endgame Open with Tony and Nebula playing "football", where the peak white lumens from the bright scene objects like the table, sparks and star fields, look much better, brighter, natural with the Sony EDID. This probably reflects @HDfury's comment regarding what might be the best match for the x800m2 and the x990.
LLDV will make more processing done on player when using A1 edid than any other brand.
so LG C8 LLDV will make more processing on display end.
That's why I think only variations of Sony EDID can prolly change something if user have good results with A1 already, but I do not think there is much difference between newer Sony TV and A1 and if there is any, there should be difference toward a similar state than LG (where display can accept more processing load than currently sony A1 can)
post #4589 of 4945 Old 11-05-2019, 07:45 AM
Bytehoven's Avatar
Liked: 1277
@HDfury
You may not know this, but does the use of an LLDV EDID on the Oppo 203/205 work with HDR10 coming in thru the player HDMI input?
post #4590 of 4945 Old 11-05-2019, 10:37 AM
HDfury's Avatar
Liked: 1702
@HDfury
Not sure I got the question right at all...
If you mean, does LLDV edid also advertise HDR10 support, then answer is yes and oppo should be able to deliver HDR10 or LLDV regardless (depending if content is HDR10 or LLDV ofc)
Now does OPPO203/205 allow LLDV from it's input, I'm not sure. 203/205 owners should be able to answer that.
Reply Video Processors
avr-sound
