HDFury Integral 2 - Owners Thread - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 69Likes
post #421 of 709 Old 03-24-2019, 08:05 AM
HDfury's Avatar
Quoted: 4509 Post(s)
Liked: 1241
Originally Posted by enricoclaudio View Post
@HDfury I have a question regarding the Integral 2 in my setup.
I'm running two processors (Emotiva XMC-1 + Denon X6500H).
The main HDMI out of each processor goes to a HDMI input in my Sony 295ES 4K projector. X6500H to HDMI 1 and XMC-1 to HDMI 2.
That is not a problem because I have activities setup in my Harmony Elite remote to switch inputs on the Sony projector at my discretion.
The reason of the Integral 2 is because I'm running a secondary display, a LG 27UK650 4K - HDR monitor which will be getting the signal from the Integral 2 4K output and the XMC-1 and X6500H secondary HDMI outs into Inputs 0 and 1 in the Integral 2.
Both processors are setup with Video Remains ON so the Integral 2 will be receiving two active signals all the time. I know there is an Auto signal function on the Integral 2 but that may not work (unless I'm missing something).
So I though about including the Integral 2 in my Harmony Elite activities and found that while I can add the Integral 2 to my Harmony database, when building the activity, Harmony does not ask me for the HDMI input on the Integral 2.
So I went to rerun activity start and I can add a steep that includes the Integral 2 but when adding the command, there is not input command listed. At this point I'm stuck and that is my question. What can I do to get this working?
you should write this in simple terms : SOURCE BRAND/MODEL > BRAND/MODEL > DISPLAY BRAND/MODEL
Anyway, if autoswitch and 2 active signals, Integral2 will autoswitch on the first one to sync. I'm not sure why you said there is no input commands listed, harmony IR codes list is included in any fw package, so just open the text file and look into it, below I added both inputsel codes taken from that file also you can use MATRIX THRU and MATRIX SWAP, should work equally well
inputsel1:
inputsel1: NEC 0x80 0x0f
0000 006e 0000 0022 0156 00ab 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 0015 0015 003f 0015 003f 0015 003f 0015 003f 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 003f 0015 05d5
inputsel2:
inputsel2: NEC 0x80 0x10
0000 006e 0000 0022 0156 00ab 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003f 0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 003f 0015 0015 0015 003f 0015 003f 0015 003f 0015 05d5
inputmathru:
inputmathru: NEC 0x80 0x11
0000 006e 0000 0022 0156 00ab 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 0015 0015 003f 0015 0015 0015 0015 0015 0015 0015 003f 0015 0015 0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 0015 0015 003f 0015 003f 0015 003f 0015 05d5
inputmatswap:
inputmatswap: NEC 0x80 0x12
0000 006e 0000 0022 0156 00ab 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 0015 0015 0015 0015 003f 0015 0015 0015 0015 0015 003f 0015 0015 0015 0015 0015 0015 0015 003f 0015 0015 0015 003f 0015 003f 0015 0015 0015 003f 0015 003f 0015 003f 0015 05d5
Maestro: 4I/4O +4K HDR over HDBT +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver. [Won Best Product Award]
Diva: 4I/3O +Ambient Light +Lag Tester +4K HDR > 1080p SDR +HDMI/ARC/eARC sound to AVR input +autoswitch +webserver.
Vertex2: 4I/3O +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
HDfury is online now
post #422 of 709 Old 03-26-2019, 03:53 PM
enricoclaudio's Avatar
Quoted: 3867 Post(s)
Liked: 4757
Hi @HDfury
Here is my connection diagram. I have everything setup and all is good when I select Port 1 (Denon X6500H). All sources connected to the Denon work perfectly. Then if I change to Port 0 (Emotiva XMC-1), 1080p sources like Xfinity Cable, work just fine. If I select Apple TV 4K (4K 60Hz/HDR) or Sony X700 Blue Ray Player (4K/60 SDR or HDR) I get black screen with info from Integral 2. If I bypass the Integral 2, then I get signal from all sources plugged into the XMC-1. I know the XMC-1 has some issues after the V3 HDMI Board upgrade but do you know of any solution or if I can do a custom EDID for the XMC-1 to work properly? BTW, I'm using 6' Monoprice Premium Certified HDMI Cables from XMC-1 and X6500H to Integral 2 and 25' Monoprice Premium Certified HDMI Cable from Integral 2 to the LG 27UK650 4K HDR Monitor.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #423 of 709 Old 03-26-2019, 04:10 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1957 Post(s)
Liked: 2370
^ I know it's off topic, but my curiosity is in high gear after seeing your diagram. Why 2 processors both connected to both displays?
gsr is offline
post #424 of 709 Old 03-26-2019, 04:23 PM
Liked: 4757
To be honest, I don't need the Denon connected to the LG monitor as I use the XMC-1 only for music and that is the one that I need connected to the LG. I just wanted to have both processors connected to both displays but if I cannot make it work with the Integral 2 then I'll be returning it and connect the LG monitor directly to the XMC-1 and be done. I have the XMC-1 connected to the projector because sometimes I watch multichannel concerts and I want to watch them on the Sony projector. Also, it's not a big deal as my projector is mounted on top of the AV rack so the cable run from both processors to the projector is only 6' and the Sony projector has 2 x HDMI inputs.
post #425 of 709 Old 03-27-2019, 06:18 AM
Liked: 0
Question Is it possible to extract just the X.X.4 Sound (Height-Channels)?
Hi there,
does anyone know, if it's possible to extract the "Height-Sound-Channels" from e.g. Atmos-Soundtracks with the Integral2? (the X.X.2 or X.X.4 Channels)
Or is it possible to do this with any other HDfury-Tool?
Or perhaps could an alternative firmware (technically) do this? Or is such feature impossible to do (independently of the vendor)?
I'd much appreciate your help.
Thank you in advance,
SchwarzerRiese
SchwarzerRiese is offline
post #426 of 709 Old 03-27-2019, 06:51 AM
Viscious82's Avatar
Quoted: 171 Post(s)
Liked: 47
Has anyone been able to get 1440p 120 hz to work with lpcm (5.1 or 7.1) or Bitstream audio on their Xbone x? I have a Samsung q8fn and got 1440p and Allm working by setting up a custom edid based on my tv but I can't get audio above stereo pcm. Is it possible to mainting the video setting but improve the audio side? Thanks.
Sent from my SM-G960U using Tapatalk
Viscious82 is online now
post #427 of 709 Old 03-27-2019, 08:16 AM
HDfury's Avatar
Liked: 1241
Hi @HDfury
Export config when it works with Denon X6500H and then export config when it fails with Emotiva XMC-1.
You might need kabledirekt, bluejeanscable or our cables if its cable issue. some simple test will help to determine if it's the case but first send both configs as asked.
Originally Posted by SchwarzerRiese View Post
Hi there,
SchwarzerRiese
Not sure I got your question right or what you mean by "extract" exactly... Anyway what I can tell is that we do NOT manipulate audio, what comes in, goes out.
Any device manipulating audio need expensive dolby licenses so there is nothing like that available at the Integral2 price tag.
If you use a custom EDID based on your TV, then it's prolly stereo because the TV is prolly stereo. just change audio capabilities in the custom EDID from stereo to whatever you need/want.
post #428 of 709 Old 03-27-2019, 09:55 AM
Viscious82's Avatar
Quoted: 171 Post(s)
Liked: 47
How can I change the audio options for custom edid and still maintain access to 1440p? I couldn't figure it out. Do I have to edid the edid in some sort of editor? I've trying using automix for sound and the different edid I options for video but I loose 1440p evertime when I have the sound that I want. I couldn't find. a combination that gave me both. There is a custom edid for the Samsung q8fn but it doesn't retain the ability to have 1440p. Any suggestions?
post #429 of 709 Old 03-27-2019, 11:36 AM
HDfury's Avatar
Liked: 1241
You wrote you was using a custom EDID, so in reality it wasn't a custom edid, just automix edid ?
I don't see why you would lose 1440p support except may be if there is no space left, in this case then yes, you need to manually edit the EDID.
Also what do you mean by it "doesn't retain the ability to have 1440p" ? do you mean, after you change EDID you lose 1440p or after you restart the source and set it back to 1440p then 1440p option doesn't appear anymore.
Try to be accurate on the exact step you are taking and how you describe it.
post #430 of 709 Old 03-27-2019, 11:59 AM
Viscious82's Avatar
Quoted: 171 Post(s)
Liked: 47
I'm using the custom edid feature of the integral 2. I first copied the edid from the tv, saved the file to my laptop, and reuploaded it to the integral under custom edid profile 8. When I do that it enables 1440p in the xbox but I can't select anything other than stereo sound. If I set the ibtrmegrsl to automix I get all sound options but lose the ability to select 1440p video output. I want to know if there is any way to setup integral 2 with an edid that allows access to 1440p and all sound options. I hope that's clearer.
post #431 of 709 Old 03-27-2019, 12:23 PM
HDfury's Avatar
Liked: 1241
Ok, export your config when having signal going thru when using custom EDID 8 with the bin file you uploaded to it and then another export when using automix.
Make sure you play EXACTLY the same content from source when you do the export and make sure you fully restart the source between edid mode change.
post #432 of 709 Old 03-27-2019, 12:27 PM
Viscious82's Avatar
Quoted: 171 Post(s)
Liked: 47
Ok. I'll try that tonight. Thank you.
post #433 of 709 Old 03-27-2019, 09:00 PM
Viscious82's Avatar
Quoted: 171 Post(s)
Liked: 47
Attached are my configurations as requested. Thank you very much. Config Samsung q8fn.txtConfig automix.txt
post #434 of 709 Old 03-28-2019, 09:16 AM
HDfury's Avatar
Liked: 1241
Attached are my configurations as requested. Thank you very much. Attachment 2545242Attachment 2545244
Ok I can see 1440p is done with a full custom timing setup line, in automix since its a combo of two there is no room for that timing line.
the automix edid fills up with custom capabilities from both sinks. there is actually no custom timing lines at all in the automix. which is typically not an issue of course.
but since 1440p is not a CEA format it requires a full custom timing model.
Using a simpler second sink would work in automix as the parameters wouldn't fill the entire table and there would be room for the custom timing line which would then get picked up by our automix routines
Anyway, attached is a custom edid that should give you all what you need, we will add similar EDID as a custom EDID in next generation hardware and add it to the EDID collection archive as well.
Just unzip it and you will have the BIN file.
FYI we removed SACD support from audio caps to fit it all in. Every byte is in use.
File Type: zip 1440p-fullaudio-SAMSUNG EDID.zip (454 Bytes, 5 views)
post #435 of 709 Old 03-28-2019, 10:20 AM
Viscious82's Avatar
Quoted: 171 Post(s)
Liked: 47
Thank you very much! I will report once I get a chance to test.
post #436 of 709 Old 03-28-2019, 04:52 PM
Viscious82's Avatar
Quoted: 171 Post(s)
Liked: 47
I want to report that the custom eidi that you provided is working. Thank you very much.
gsr and HDfury like this.
post #437 of 709 Old 03-29-2019, 12:36 PM
Liked: 0
Hi,
I am having trouble getting DV to come through, but am able to get Dolby atmos to go through to the soundbar.
Equipment:
Vizio PQ65 F1
LG SKC9 Soundbar
Xbox One X
Currently the set up is:
Xbox (Port 1) --> Integral -->PQ65 (TX0)
Xbox (Port 1) --> Integral --> SKC9 (TX1)
At first I used had all the settings on Automix, but neither atmos nor dv was working. Then I changed it to custom select, and chose Custom Default [FULL + Vizio DV] for port 0 and 4k60-420 12bit BT2020 All Surround for port 1. At this point I am able to get atmos to come through but DV does not.
I apologize if my formatting is incorrect or I am not explaining thoroughly enough, please let me know if I can supply more information.
if anyone can help, I will be eternally grateful.
James Ly is offline
post #438 of 709 Old 03-29-2019, 02:10 PM
claw's Avatar
Quoted: 2372 Post(s)
Liked: 2235
Originally Posted by James Ly View Post
Hi,
Equipment:
Vizio PQ65 F1
LG SKC9 Soundbar
Xbox One X
The custom EDIDs are to present capabilities to the player, not to control what is output. Since you have the XBox connected to Port 1, you would need to select the [FULL + Vizio DV] EDID for Port 1 in order to get Dolby Vision to your Vizio.
Are you certain that your SKC9 sound bar will accept a Dolby Vision signal?
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #439 of 709 Old 03-29-2019, 03:13 PM
Liked: 0
So the skc9 will not accept dv signal, which is kind of the reason why I purchased the hdfury.
So you are saying I should have had the custom edid for vizio the opposite way?
James Ly is offline
post #440 of 709 Old 03-29-2019, 03:54 PM
Liked: 0
Nevermind. I found out why. I found that Xbox has a list of Dolby vision compatible TV's, and the PQ65F1 is not one that has Dolby vision up to date in their firmware.
James Ly is offline
post #441 of 709 Old 03-30-2019, 12:51 AM
Liked: 0
Hi @HDfury ,
Need some help with my connection. My YSP-5600 has an OSD menu that is displayed on the projector output when I used to connect it via ARC directly. Now when I have the Integral2 in between the OSD menu of my ysp-5600 is not visible. This menu is needed for calibrating sound settings as there is no other way for me to view the settings info.
Past connection diagram
HTPC -> YAMAHA YSP-5600 -> 4K Projector (via ARC)
YSP-5600 OSD would show up as overlay on projector
Present connection
HTPC(INP0) -> HDFury Integral2 => TOPOUT (YSP-5600) & BOTOUT (4K Projector)
All devices work fine here except for the fact the OSD for the YSP-5600 is not viewable
Any ideas?
chaitanya k is offline
post #442 of 709 Old 03-30-2019, 07:05 AM
Quoted: 98 Post(s)
Liked: 40
Originally Posted by chaitanya k View Post
Hi @HDfury ,
Present connection
Any ideas?
Hi chaitanya K,
Based on your present connection, you can't expect the YSP's OSD to be displayed on the projector, since they are no longer connected together...
If you have a 2nd HDMI input on your projector you can connect it to the output of the YSP and switch for calibration.
Otherwise, you'll have to temporarily disconnect the projector from the Integral2 and plug it into the YSP for sound calbration.
W.
HDfury likes this.
TV: Samsung UE78JS9580 (4K HDR10) ; - - - - - - - - AUDIO: Denon AVR-X3100W (4K HDCP 1.4)
Media players: Minix U9-H (4K HDR), OpenHour Chameleon (4K SDR), PopcornHour C200 (HD)
Matrix switches: HDfury DIVA & Integral (rev. 1, 600 MHz)
Game consoles: Sony PlayStation 4, Nintendo Wii
Multimedia NAS: Qnap TVS-671 (4K30 SDR)
Walky is offline
post #443 of 709 Old 03-30-2019, 02:09 PM
Liked: 0
Originally Posted by Walky View Post
Hi chaitanya K,
W.
Thanks. I will attempt that.
post #444 of 709 Old 04-01-2019, 02:40 PM
Quoted: 14 Post(s)
TV to bot out, sound bar to TOP out, EDID slide on AUTOMIX for DV support and SCALE slide on AUTOSCALING, that will work out of the box. nothing special here.
I've had my Integral 2 for a couple of weeks now. It worked perfect right out of the box. However, last night the audio was significantly out of sync. I was able to fix by adjusting the audio delay on my YSP-5600 to 105 milliseconds. But I'm still not sure what could have caused the audio to start being out of sync to begin with. Nothing else changed from my previous uses. Anyone else have an issue like this? I'm using the HDMI cables I purchased from HDFury along with the Integral 2.
Randall Lotowycz is offline
post #445 of 709 Old 04-01-2019, 04:05 PM
HDfury's Avatar
Liked: 1241
This is caused by delay TV needs to process picture and delay audio device needs to decode and output audio, our devices is not in cause, since our input lags is less than 1ms, actually input lag is in nano second.
post #446 of 709 Old 04-01-2019, 05:38 PM
Quoted: 14 Post(s)
I didn't have the issue without the Integral 2 and like I said in my last message, it wasn't an issue for my first couple of weeks of frequent use of the Integral 2 with my setup. But without anything changing, I started to have the delay last night.
post #447 of 709 Old 04-02-2019, 07:34 AM
HDfury's Avatar
Liked: 1241
As I said, our devices CANNOT create any such delay so your issue have nothing to do with our devices, what comes in in our device, goes out in less than 1ms (it's NANO SECONDS), but if you want me to check your settings to confirm then just post your config export when you are having the issue.
You said before you did not have such issue, then think about how it was connected before SOURCES > YSP > DISPLAY, so display get picture after YSP process sound or SOURCES > TV > ARC TO YSP, so TV get picture before YSP get sound...
Now you have SOURCES > Split to both YSP and Display, so TV get picture at the same time than YSP process sound. so sure there could be some delay adjustment needed DEPENDING on the audio format or the display format that each device have to process.
post #448 of 709 Old 04-02-2019, 02:52 PM
Quoted: 14 Post(s)
I'm not trying to give you a hard time or complain about the device. I was genuinely curious about why a need for delay adjustment would come up after using the device for a couple of weeks (with a variety of audio and display formats). The adjustment wasn't necessary out of the box. Now it is. That's all.
post #449 of 709 Old 04-03-2019, 12:01 AM
HDfury's Avatar
Liked: 1241
And I'm not trying to give you hard time neither I'm just confident that what you are reporting here have nothing to do with our devices since our devices simply cannot produce such results by design.
May be your soundbar was reset or get update or may be tv get update, or you are using another input somewhere, new memory entry, etc...
Also even source can be responsible, when ATV added LLDV to DV formats that changed lipsync delay for every LG/Sony owners using LLDV.
However, as I say, if you really think there is something weird, just post your config and I can tell you if everything is at it should be or not.
post #450 of 709 Old 04-03-2019, 04:22 AM
Liked: 0
Decode HD audio for capture?
Hi, would this product be able to help me when capturing 4K game footage with multi channel sound?
I cap to a Atomos Ninja Inferno, and when I turn the audio to Dolby/DTS multi channel (5.1/7.1 etc.) the audio is just noise, I presume that this is because the audio track is encrypted?
For ref. I can only capture audio via HDMI, no optical inputs on capture device.
Any help would be greatly appreciated,
Regards
bobby73 is offline
Reply Video Processors
