HDFury Maestro HDBaseT owner's thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 176Likes
post #31 of 423 Old 11-27-2018, 12:06 AM - Thread Starter
aka jfinnie
Quoted: 2810 Post(s)
Liked: 1945
Originally Posted by gsr View Post
@HDfury - is it yet known what the requirements will be for the cable between the HDBaseT transmitter and receiver? As in will CAT6 be required or will CAT5e be fine and will the cable need to be shielded or is a standard unshielded cable fine? I'm on a stay at home vacation this week, so it would be a good opportunity to run a new cable if what I currently have isn't sufficient.
I can't see any reason why it would be different to any other HDBT solution as they all use the same chipset families from Valens. There are two different grades of chip which vary in the distance achievable on a particular cable type - @HDfury are you in a position to tell us which HDBT variant you are using and what is the cable type / distance matrix for this solution? HDBT.org say 5E is supported, but recommend CAT6 shielded for high resolution / electrically harsh environments / long distance. Performance can also be affected by proximity to other cabling.
For what is is worth with my Atlona kit I'm using a 15m run of CAT6 unshielded which wasn't kept separate from other cables by the installer, and that seems fine at full rate (4K60 10 bit with VESA DSC compression to bring it under the ~10G HDBT hard physical layer limit). However if I was doing it again for peace of mind I'd run shielded and keep it away from the other cables.
bobof is offline
post #32 of 423 Old 11-27-2018, 08:06 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1979 Post(s)
Liked: 2384
^ Yeah, I'm somewhat familiar with the limited number of HDBaseT chipsets. I'm currently using Crestron's custom HDBaseT implementation (they add some extra payload, such as IR, RS-232, and integration with their control systems) with standard unshielded CAT6 cables, but the Crestron gear I have is currently limited to 4K30. I'm seriously considering the Maestro because it would be a LOT less expensive than upgrading to Crestron's newer gear that supports 4K60. The cable run in question is approximately 75 feet in length.
gsr is offline
post #33 of 423 Old 11-27-2018, 09:28 AM
HDfury's Avatar
Quoted: 4636 Post(s)
Liked: 1270
150M (500ft) on up to 1080P 8b, 100M (328ft) on 1080P 12b (Cat6a), Up to 70m (230ft) on 4K60 4:4:4 HDR (Cat6a)
gsr and giomania like this.
Maestro: 4I/4O +4K HDR over HDBT +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver. [Won Best Product Award]
Diva: 4I/3O +Ambient Light +Lag Tester +4K HDR > 1080p SDR +HDMI/ARC/eARC sound to AVR input +autoswitch +webserver.
Vertex2: 4I/3O +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
HDfury is offline
post #34 of 423 Old 11-28-2018, 11:53 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 690 Post(s)
Liked: 434
So what happens when you have Cat 5e?
Sent from my iPhone using Tapatalk Pro
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is offline
post #35 of 423 Old 11-28-2018, 01:51 PM
HDfury's Avatar
Liked: 1270
Probably a shorter working length.
HDfury is offline
post #36 of 423 Old 11-30-2018, 05:11 PM
HDfury's Avatar
Liked: 1270
Maestro / Diva HDR Fixer
Current HDR Fixer section of Maestro / Diva and upcoming... already more advanced than Vertex (which is yet limited by memory usage)
It have all the latest requested by the community.
Jeroen1000 likes this.
HDfury is offline
post #37 of 423 Old 12-01-2018, 03:41 AM
Jeroen1000's Avatar
Quoted: 92 Post(s)
Where can I pre-order Diva. I'm impressed! I've been searching for such a device for a long time. Closest I can find is a Lumagen pro (superb product but way too expensive, don't need all its features) and Athlona 4K switchers.
Please don't put large leds on the front unless I can disable them permanently or with a time-out
My gear: Panasonic TH-42PF11EK pro plasma display + TX-P55VT60E -- Iscan Duo video processor -- i1 display 3 colorimeter -- i1 pro 2 spectrometer -- Apple TV 4K -- WD LIVE TV gen 3.
Jeroen1000 is offline
post #38 of 423 Old 12-01-2018, 04:55 AM
HDfury's Avatar
Liked: 1270
We will unveil product page and product picture for Maestro and Diva next week.
There is no large led, just an OLED screen you can turn on/off at will or set a timer for. Same for OSD.
gsr, giomania, jruhnke and 4 others like this.
HDfury is offline
post #39 of 423 Old 12-05-2018, 11:03 AM
MJ DOOM's Avatar
Quoted: 236 Post(s)
Liked: 82
Please don't put large leds on the front unless I can disable them permanently or with a time-out[IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG]
Any update?
I unfold the scroll, plant seeds to stampede the globe
When I'm deceased, by then the beast arise like yeast
to conquer peace leaving savages to roam in the streets.
MJ DOOM is online now
post #40 of 423 Old 12-05-2018, 04:50 PM
HDfury's Avatar
Liked: 1270
Originally Posted by MJ DOOM View Post
Any update?
Working hard, everything nearly ready...
If you wanna see something special, I can may be help ... otherwise, wait a bit.... it's a matter of a couple of days..
HDfury is offline
post #41 of 423 Old 12-06-2018, 12:27 AM
Jeroen1000's Avatar
Quoted: 92 Post(s)
An AVS sneak preview
post #42 of 423 Old 12-06-2018, 09:27 AM
HDfury's Avatar
Liked: 1270
I'll give you better high quality views shortly.
ID:	2492554   Click image for larger version
gsr, giomania, jruhnke and 2 others like this.
HDfury is offline
post #43 of 423 Old 12-08-2018, 08:46 AM
HDfury's Avatar
Liked: 1270
Cool Maestro TX Central & RX pictures
Please find attached pictures of both Maestro TX Central and Maestro RX.
Product page will soon be available.
Beta test will also start shortly.
Hardware-wise, you have the Maestro TX (Central) featuring 4 HDMI inputs, 1 HDMI video output with scaling option and 1 dedicated HDMI full audio output at 720p or 1080p, LAN Control, HDbaseT output, RS232, L/R stereo or Optical 5.1 output, IR TX, IR RX, IR sensor, IR window, OLED display and 4 buttons on the side allowing to enter/exit and perform change in the device system menu.
On the other end, the Maestro RX device self-powered by the TX-Central is featuring HDbaseT input, 2 LAN port to share Internet connection with game console, TV or media player, 2 HDMI outputs with scaling capabilities, RS232, L/R stereo or Optical 5.1 output, SPDIF input, IR sensor, IR TX, OLED display and 4 buttons on the side to enter/exit system menu and perform changes in settings.
All inputs are capable of 4K HDR/HLG/DV/HDR10+ up to 18Gbps for video and support any sound format in existence today, all video outputs are capable of outputting 18Gbps and all sound formats as well whether they are on the TX-Central or the RX one.
Both units are always running in a Matrix/Scaler mode ensuring your setup remains optimized at its best capabilities.
Software-wise, Maestro is the first device to provide you full control via the embedded and brand new HDfury webserver ! The need of a dedicated computer with special driver to run configuration software or update is now a thing of the past !
You can use any web browser based device such as any computer or smartphone to access, control and update Maestro TX Central and Maestro RX, the process is as easy as visiting a web page.
We went further than anything we ever made and full filled Maestro with revisited and improved HDR management feature. We also added some new features never seen before such as TMDS switching for all inputs.
All HDfury legacy features remain present, each input EDID can be set individually from a list of 100 EDID, HDCP conversion, Scaling and signal operations such as Chroma/Color depth/Color space, PJ&Display macro, Infoframes modes, CEC command, ARC, HTPC mode, special modes, sound extraction and more. All setup informations are visible at first sight via OLED, On Screen Display or Webserver.
Please note that some other unique and special features are planned and still under development
Simply the world most advanced point to point HDbaseT solution for long distance 4K HDR 18Gbps/600MHz transmission via Ethernet cable.
PS: Diva picture, info and product page are also in the making. should be live a week after Maestro page.
ID:	2493662   Click image for larger version
ID:	2493664   Click image for larger version
ID:	2493666   Click image for larger version
gsr, Manni01, bobof and 1 others like this.
HDfury is offline
post #44 of 423 Old 12-08-2018, 11:20 AM
claw's Avatar
Quoted: 2437 Post(s)
Liked: 2287
We do have other solution in the making that doesn't include HDbaseT, like we have a device with 4 inputs + 1 main output + 1080p SDR output (HDR>SDR on the fly) + Full HDMI Audio out on 720p/1080p + Ambient light + Lag tester + webserver, etc...
Because you mentioned Lumagen, just checking that you understood HDfury's post to mean that (HDR>SDR on the fly) is HDR to 1080p SDR output only. It can't do 4K HDR to 4K SDR.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is online now
post #45 of 423 Old 12-08-2018, 12:09 PM
Jeroen1000's Avatar
Quoted: 92 Post(s)
Hi claw I didn't know that good catch. I don't have a use for that though so no deal breaker
post #46 of 423 Old 12-08-2018, 01:02 PM - Thread Starter
aka jfinnie
Liked: 1945
Very cool. I just updated the first post. Very interested in testing this hanging off the output of my Lumagen Pro...
HDfury likes this.
bobof is offline
post #47 of 423 Old 12-09-2018, 04:35 AM
Jeroen1000's Avatar
Quoted: 92 Post(s)
@HDfury Since there is a beta test, Diva/Maestro will not go on sale this year? Better a good product than to rush things of course
post #48 of 423 Old 12-09-2018, 07:19 AM
jruhnke's Avatar
Quoted: 33 Post(s)
Will Diva be able to act as an HDMI splitter also (pass-through 4K HDR/DV input to both HDMI outputs simo) or will the second output always be 1080p only?
Also, will it be able to convert multichannel HDMI audio to 2-ch stereo for the second output?
jruhnke is offline
post #49 of 423 Old 12-09-2018, 07:50 AM
HDfury's Avatar
Liked: 1270
Yes we are delayed a bit, looking for end of January now.
Beta test should go well normally, apart from Webserver testing and TMDS switching new routine, most of other routines comes from Vertex and they are very solid already.
We never done any device that manipulate audio, Audio is always untouched in all our devices.
No Diva is not a splitter, but you can add Vertex or Integral2 at Diva output if you need to split main video out to 2x 18Gbps display.
Diva outputs are main video/full hdmi audio/1080p SDR
May be someone willing to maintain a first post can start a thread for it (we are not allowed), avoid mixing info with Maestro.
HDfury is offline
post #50 of 423 Old 12-09-2018, 08:07 AM
Jeroen1000's Avatar
Quoted: 92 Post(s)
I'll maintain a first post for Diva. I'll try to do it tonight or tomorrow.
for your information and entertainment: a separate thread for Diva
giomania and HDfury like this.
post #51 of 423 Old 12-09-2018, 12:25 PM
Jeroen1000's Avatar
Quoted: 92 Post(s)
LLDV 600MHz is supported, no DV 600MHz support currently but it can change with the release of public SDK from Dolby this month.
@HDfury what is DV 600 Mhz support anyway? What does this limitation mean?
post #52 of 423 Old 12-09-2018, 04:35 PM
HDfury's Avatar
Liked: 1270
Sorry, can you elaborate the question please
LLDV/HDR/HLG/HDR10+ are supported at 600MHz.
DV at 300MHz only currently might change in the future, still waiting their promised SDK (if you read previous pages)
DV at 300MHz means 4K24 4:2:2 12b and not 4K60 4:2:2 12b
However, LLDV works at 4K60 4:2:2 12b
HDfury is offline
post #53 of 423 Old 12-09-2018, 05:58 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 2384
I think the question was asking to explain what some of the abbreviations mean... "DV 600 mhz support" does seem a bit confusing or incomplete - obviously "DV" means Dolby Vision but what's the 600 mhz portion of it mean when combined with Dolby Vision? I'm assuming LLDV means Low Latency Dolby Vision (ie: the Sony version). Abbreviations are great and can save some typing, but they can also hopelessly confuse people too .
gsr is offline
post #54 of 423 Old 12-09-2018, 08:35 PM
HDfury's Avatar
Liked: 1270
I think I answered that already, but here it is again:
DV or DoVi is Dolby Vision
LLDV is Low Latency Dolby Vision (Sony and LG as sink and X1X, ATV4 and sony players as source)
300MHz = 10.2Gbps = best/max 4K24 4:2:2: 12b (for movies) or 4K24 4:4:4 8b (for pc/game)
600MHz = 18Gbps = best/max 4K60 4:2:2 12b (for movies) or 4K60 4:4:4 8b (for pc/game)
HDfury is offline
post #55 of 423 Old 12-10-2018, 12:07 AM
Jeroen1000's Avatar
Quoted: 92 Post(s)
@gsr @HDfury
My apologies for being unclear. Kudos for the excellent answer though! What I truly meant was, if you can do it at 300 Mhz, why not at 600 Mhz? Is it a processing limitation (not enough computing speed) in the FPGA? The SDK could alleviate this as you can just ask it for you want thus consuming far less resources?
post #56 of 423 Old 12-10-2018, 08:10 AM
HDfury's Avatar
Liked: 1270
@gsr @HDfury
Because to allow 4K60 HDR/HLG/HDR10+/LLDV such as 4K60 4:2:2 12b to go thru HDbaseT, there is some magic going on.. (which if you read since the beginning, I'm not allowed to comment on, devs words on it are: Feel free to compare our magic with anything else on the market)
Since DV source encrypt for DV display using DV string and travel in RGB container, we cannot perform the magic on the stream as we don't have direct access (if I got what Devs told me right.. it's new to me as well... be indulgent please)
So apparently DoVi SDK can may be help improve that .. or not, we don't know since we haven't see yet despite some promises... and for LG/SONY TV and ATV4K/X1X and other LLDV source, you can go thru LLDV mode instead and then you have 600MHz DV or LLDV to be exact.
This is the current state, everything we listed is how it is at the moment. We haven't listed anything that is not already operating well.
HDfury is offline
post #57 of 423 Old 12-10-2018, 09:02 AM
Jeroen1000's Avatar
Quoted: 92 Post(s)
@HDfury is this only applicable for Maestro since you specifically mention HDbaseT? Ergo, DV @600 Mhz will work fine for Diva and already works for Vertex. If so, I need to alter my first post for Diva as I currently state DV @600 Mhz is unsupported.
post #58 of 423 Old 12-10-2018, 09:17 AM
HDfury's Avatar
Liked: 1270
Yes of course, this is only relevant for HDbaseT, any others devices from us, including AVR-Key, Integral, Integral2, Vertex and even Linker (not all DV support for Linker) do support DV at 600MHz, Diva also support DV at 600MHz
And even for Maestro, you can have DV 600MHz from 4 inputs at TX central and using the video output of TX central. DV HDBaseT limitation is only applicable to Maestro RX output.
giomania and Jeroen1000 like this.
HDfury is offline
post #59 of 423 Old 12-10-2018, 01:46 PM - Thread Starter
aka jfinnie
Liked: 1945
The way I understand this; DV600MHz/18G (ie something like 60Hz menus at 4K on the AppleTV4K) isn't supported on any HDBT devices at the moment.
The reason is that all the video data has to pass completely untouched through the cable. HDBT can't do this because the physical layer has a hard limit of around 10G.
The solutions on the market for getting signals above 10G into HDBT all involve some kind of compromise. Either you convert the colourspace / bit depth (eg 10 bit becomes 8 bit) or you apply some compression like VESA's Visually Lossless compression. In both scenarios you don't get the exact same video stream at the other end, so anything that relied on the data making it in one piece (ie full DV 60Hz) would be broken.
I "guess" a potential solution if you have the DV SDK is that you can effectively extract the DV metadata from the video at the transmit end, compress just the video to fit, pass the DV metadata unadulterated, and then re-apply the DV metadata at the HDBT receive end.
Whatever you end up watching above 10G on any HDBT solution will involve something going on with the video behind the scenes. There isn't really much magic as far as I'm aware, just varying implementations of the same kind of ideas.
I'd actually really like to see someone come up with a device which did true 18G over HDBT, without compression. It is possible - you'd "just" have to split the 18G signal into two halves, and send both halves down separate HDBT links, and re-assemble at the other end. Would work great for me as I ran 3xCAT6 to the PJ, but I guess it is not for everyone.
Hopefully Valens will come up with something someday soon which can do real 18G. Still really excited by the Maestro.
giomania likes this.
bobof is offline
post #60 of 423 Old 12-10-2018, 05:44 PM
HDfury's Avatar
Liked: 1270
There is 2 ways presently, we have our own. a third/new/never saw otherwise we would not have tried or though about doing such product if we didn't have anything special in this regard. all welcome to compare as said. End of discussion on that.
Regarding 2 HDBaseT link, possible for 7000$ as you need to create 600MHz FPGA video buffer with lot of high speed ram otherwise you would have vertical/horizontal line in the middle.
You can easily test that using Integral Split screen feature, split horizontally or vertically, send each output to a HDBaseT solution and both HDBaseT RX back to another integral that will display the signal. That was tested back in 2016 if I recall well. you have horizontal or vertical line in the middle, because you need video buffer to avoid it and that would sky rocket the price. it's not our usual price range to do 7000$ device, here already Maestro is at a newer price level for us.
bobof likes this.
HDfury is offline
Reply Video Processors
