HDFury Diva - Owners thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 204Likes
post #991 of 1032 Old 01-10-2020, 10:32 AM
HDfury's Avatar
Quoted: 4840 Post(s)
Liked: 1334
Originally Posted by tenzingnorgay View Post
I upgraded to 0.60.0.12 last night and ended up revving back to 0.58.0.12. How do I force LLDV like the old checkbox "DV FORCE LLDV" did? That seemed to be the right combination for me to be able to use the ambient lighting with DV sources. I have a LG B7 OLED if that helps.
(I'm not very technically proficient with this tech so if there's a better way for me to do this under 0.60, please let me know.)
Just click DV custom string or read claw post just above, he mentioned that there will be such questions.
Maestro: 4I/4O +4K HDR over HDBT +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver. [Won Best Product Award]
Diva: 4I/3O +Ambient Light +Lag Tester +4K HDR > 1080p SDR +HDMI/ARC/eARC sound to AVR input +autoswitch +webserver.
Vertex2: 4I/3O +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
HDfury is offline
post #992 of 1032 Old 01-10-2020, 10:34 AM
HDfury's Avatar
Liked: 1334
Originally Posted by Nillaz View Post
I know this is not currently supported, but can you tell me if the Diva hardware (or any HDFURY device for that matter) has the capability to handle 4K120 4:2:0?
I'm not holding my breath that this is possible, but it would be convenient for me to use this in conjuntion with my television and PC.
Yes as long as it is within 18Gbps bandwidth then it's possible, such as 4K120 4:2:0 or 8K30 4:2:0, yet, you must have a source capable of sending this out and then of course, no scaling or operation possible on such signal, they just pass thru, yet audio out would still be able to extract sound from it. (as far as I recall)
HDfury is offline
post #993 of 1032 Old 01-10-2020, 10:41 AM
HDfury's Avatar
Liked: 1334
Originally Posted by claw View Post
Regarding the AUTOMIX change for Dolby Vision. I expect you might get some questions about the removal of the Force DV flag and its CUSTOM STRING replacement.
If I understand it correctly, marking DV FLAGS: CUSTOM STRINGS on the EDID page will use the factory default Sony A1 LLDV string from the CUSTOM DOLBY VISION DATA BLOCK on the HDR/DV page. And thus should function exactly as it did with the previous Force DV check box.
Hi Claw,
About the update in general: yes it' s a serious update and it have lot of new values in export, especially various status for input/output that should allow us to understand and solve tough issue more easily, actually it is getting close to signal analyzer
About the above, yes before LLDV forced A1 string, but guys here wanted to play with the string values, so now the DV string is fully exposed, default is same as before LLDV from Sony A1, but now anyone can play with values, or force any other LLDV or normal DV from any DV TV just by copying the string in it, so you can just connect your DV TV, see the string on the DV page and copy it to be used while applying some changes... of course that is for advanced users only, so normal user should just use Automix normally and it will use their TV DV string or check DV custom string and it will use Sony A1 LLDV.
Of course, no need to ask us which bytes does what or what represent what in that string, no one actually knows unless you pay Dolby fee and they of course do not allow small company like us in their paid membership club, so one needs to have some skills and patience and try to figure it on its own, that is what we made possible here, people can now try to deduct what does what.
claw and JGrana like this.
HDfury is offline
post #994 of 1032 Old 01-10-2020, 11:48 AM
claw's Avatar
Quoted: 2537 Post(s)
Liked: 2384
Regarding my previous note about the Disable output HDR when HDR10 checkbox setting not restored on import;
I found that if I enable all of the check boxes:
Use custom HDR for TX0 and TX1 [ignore RX HDR]
Use custom HDR for TX0 and TX1 when input is HDR10 [ignore RX HDR10]
Use custom HDR for TX0 and TX1 when input is HLG [ignore RX HLG]
Use custom HDR for TX0 and TX1 when input is HLG and display has no HLG support
Use custom HDR for TX0 and TX1 when input is LLDV (for ATV only)
Disable output HDR for TX0 and TX1 when input is HDR10
Disable output HDR for TX0 and TX1 when input is HLG
Disable output LLDV for TX0 and TX1 when input is LLDV (for ATV only)
Disable all output HDR/HLG [keep LLDV]
Then perform an export, followed by an import, all of the check box settings are imported correctly.
But if I only mark the one setting:
Then perform an export followed by import, the check box setting is not imported and is unchecked.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #995 of 1032 Old 01-10-2020, 01:38 PM
HDfury's Avatar
Liked: 1334
Ok thanx Claw, i'll tell devs about it.
HDfury is offline
post #996 of 1032 Old 01-10-2020, 01:55 PM
Nillaz's Avatar
Quoted: 575 Post(s)
Liked: 377
Thanks for the info, that is exactly the problem I am trying to solve.
I have the source (my PC) and I have the sink (HDMI 4 on a Samsung Q90R). What I didn't know is if the Diva can pass this signal yet also extract the audio in order to send it to my receiver.
82Q90R / Denon X6400H / Polk Audio LSI 7.1.4 / Nvidia Shield Pro 2019 / Panasonic DP-UB820 4K BluRay / Xbox One X / PS4 Pro / Nintendo Switch / Custom Gaming PC / Custom VR PC / HTC Vive Pro HMD (Wireless)
Nillaz is offline
post #997 of 1032 Old 01-10-2020, 02:27 PM
HDfury's Avatar
Liked: 1334
What GPU are you using for 4K120 on Q90R ?
HDfury is offline
post #998 of 1032 Old 01-10-2020, 02:36 PM
Nillaz's Avatar
Quoted: 575 Post(s)
Liked: 377
2080ti.
Nillaz is offline
post #999 of 1032 Old 01-10-2020, 02:43 PM
HDfury's Avatar
Liked: 1334
2080ti.
You mean you are getting 4K120 from 2080Ti via HDMI output and it works fine ? is that due to recent fw or driver update for 2080ti ? I remember having read only failure story for 2080ti and 4K120
HDfury is offline
post #1000 of 1032 Old 01-10-2020, 04:26 PM
Quoted: 13 Post(s)
Liked: 1
I do have a Diva now but I cannot get ARC to work - my setting:
- LG OLED55B7D [HDMI 2 (ARC)] --> Diva (TX0)
- DIVA (TX1) --> HDMI to USB3 Grabber (Ambilight) with Rapsberry Pi4
- Diva - Audio Out (HDMI) --> AVR (Yamaha RX-V685) - HDMI Out 1 (ARC)
- Diva (HDMI Input 0) <--> AVR (Yamaha RX-V685) - HDMI Out 2
Eyerything works fine with other sources, but ARC does not work at all. Any hints? DIVA is configured as CEC audio processor. The LG does not play any sound with integrated TV apps.
fir3drag0n is offline
post #1001 of 1032 Old 01-10-2020, 05:25 PM
HDfury's Avatar
Liked: 1334
You cannot connect an OUTPUT to another OUTPUT !!!
AUDIO OUT must go to AVR INPUT !
HDfury is offline
post #1002 of 1032 Old 01-10-2020, 05:47 PM
Quoted: 13 Post(s)
Liked: 1
But usually this output is used for arc, so why it is not possible in this case?
Gesendet von meinem Pixel 3 mit Tapatalk
post #1003 of 1032 Old 01-10-2020, 08:32 PM
HDfury's Avatar
Liked: 1334
First of all because an output connect to an input, you cannot connect output to output or input to input, that does not exist.
Second because of nature of how ARC/CEC works, you have not yet realized that ARC is just a single wire (or two) in a hdmi cable between a TV input and AVR ouput.
Third and most important, what would be the point to extract eARC FULL sound from eARC TV and send it to an AVR ARC output that only support 5.1 or DD+ at best > cannot work and stupid isn't it ?
HDfury is offline
post #1004 of 1032 Old 01-10-2020, 09:29 PM
Nillaz's Avatar
Quoted: 575 Post(s)
Liked: 377
Sorry it took so long to reply. I'm having some annoyances with this right now due to a change in my setup that requires me to now use a long fiber optic HDMI that I am finding is of marginal quality (I'm occasionally dropping the signal). Prior to this using a high quality 4' standard HDMI cable things worked as expected. I wasn't aware that there even was a problem with this in the first place but right now I'm reading about the issue you mentioned that people were having with the early Q90 firmwares. Glad I didn't jump into it months ago!
It's really not a big deal either way, but it would be convenient to have an easy way to reroute the audio to my receiver. My Denon will decidedly NOT allow 4K/120 to pass to the display under any circumstances.
Nillaz is offline
post #1005 of 1032 Old 01-11-2020, 12:33 AM
M8st3r0fd3s8st3r's Avatar
HDFury wall mount
Hi there,
for those who are interested. I designed a wall mount for the Diva to print with a 3D printer.
It can be installed both horizontally or vertically.
You can find it at the following link for free.
thingiverse.com/thing:4095760
Greetings, Cambridge
gsr, DesertDog, Nillaz and 4 others like this.
M8st3r0fd3s8st3r is offline
post #1006 of 1032 Old 01-11-2020, 07:26 AM
HDfury's Avatar
Liked: 1334
Best fiber are Celerity Tek but very expensive, otherwise Moshou seems reliable at affordable cost.
For 4K120 if 2080Ti can output it, then you can more likely extract sound from it via our AUDIO OUT. We might have to make an update for signal recognition first, that means we might have to get a 2080Ti first too.
Can you send a config export when you are trying to send 4K120 to Diva so we can check it.
HDfury is offline
post #1007 of 1032 Old 01-11-2020, 07:28 AM
HDfury's Avatar
Liked: 1334
Cool LG Demo at CES
Here you can quickly see HDfury Diva used at LG demo stand (around 4:40 on below video)
HDfury is offline
post #1008 of 1032 Old 01-11-2020, 02:16 PM
HDfury's Avatar
Liked: 1334
Originally Posted by M8st3r0fd3s8st3r View Post
Hi there,
Very good work you did there, congratz ! really a pleasure to have such community.
HDfury is offline
post #1009 of 1032 Old 01-11-2020, 08:54 PM
Nillaz's Avatar
Quoted: 575 Post(s)
Liked: 377
Can't do it tonight but I will have it for you by the end of the weekend. Thanks for taking a look!
Nillaz is offline
post #1010 of 1032 Old 01-11-2020, 08:57 PM
Nillaz's Avatar
Quoted: 575 Post(s)
Liked: 377
Hi there,
That is awesome, this will come in extremely handy in my AV rack. Much appreciated!
Nillaz is offline
post #1011 of 1032 Old 01-11-2020, 08:59 PM
Nillaz's Avatar
Quoted: 575 Post(s)
Liked: 377
https://youtu.be/zRhd2Wsy6L0?t=281
I saw this video shortly after they uploaded it and I noticed the Diva as soon as they cut to that shot lol
HDfury likes this.
Nillaz is offline
post #1012 of 1032 Old 01-13-2020, 01:02 PM
DesertDog's Avatar
Quoted: 907 Post(s)
Liked: 2386
Hi there,
Thanks! I printed one yesterday and it came out great. Any chance you've done one for a miniDSP 2x4HD too? I'm thinking of doing it and the wifi adapter now to match it and clean things up.
#IHateNalleh
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is offline
post #1013 of 1032 Old 01-13-2020, 06:18 PM
NeONGeneSAr's Avatar
Quoted: 34 Post(s)
The 112 leds version coming should be suitable then.
i forgot inquire...do y'all have a (tentative) release date for these?
NeONGeneSAr is online now
post #1014 of 1032 Old 01-14-2020, 12:48 AM
Nillaz's Avatar
Quoted: 575 Post(s)
Liked: 377
I've been trying to figure out how to do this but I've had no luck. When connected to Diva the Nvidia Control Panel does not expose 4K/120 as a valid option, which is what I expected. If you try to force it as a custom resolution the screen goes black and the PC becomes unresponsive, requiring a hard reboot. Diva reports no signal detected on the OLED screen. I have no idea if I am just choosing incorrect settings in the custom resolution screen or if there is something else at work. Only connecting the PC directly to the One Connect box allows for 4K/120 to be selected.
Nillaz is offline
post #1015 of 1032 Old 01-14-2020, 11:36 AM
HDfury's Avatar
Liked: 1334
If you use COPY TX0 EDID mode (if TV is at TX0) then it's same than a direct connection and you should have exact same option from your PC, so do this and export config, signal recognition is prolly something we need to add via update as stated previously, but EDID should work just fine as long as you copy your TV EDID.
HDfury is offline
post #1016 of 1032 Old 01-14-2020, 11:37 AM
HDfury's Avatar
Liked: 1334
I'll get you answer shortly on that, just guys are busy with others priority tasks atm, should not be long.
HDfury is offline
post #1017 of 1032 Old 01-14-2020, 04:15 PM
Nillaz's Avatar
Quoted: 575 Post(s)
Liked: 377
Thanks for the instructions this exposed the proper resolution in Nvidia Control Panel. As expected once enabled this signal does not pass but I have attached the requested export config.
Nillaz is offline
post #1018 of 1032 Old 01-14-2020, 06:15 PM
HDfury's Avatar
Liked: 1334
Can you please send config export using latest firmware, thanx.
HDfury is offline
post #1019 of 1032 Old 01-14-2020, 06:57 PM
Nillaz's Avatar
Quoted: 575 Post(s)
Liked: 377
Updated and resending.
Nillaz is offline
post #1020 of 1032 Old 01-15-2020, 01:33 AM
Hi,
Because I do not own a miniDSP 2x4HD, I took the dimensions from the manual as a reference and drew a wall bracket for you.
I hope it fits.
thingiverse.com/thing:4104135
gsr, DesertDog and HDfury like this.
Reply Video Processors
