HDfury Dr HDMI 4k - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #61 of 83 Old 02-10-2020, 06:19 AM
blub-blub's Avatar
Quoted: 12 Post(s)
OK, thx a lot
blub-blub is online now
post #62 of 83 Old 02-28-2020, 07:25 AM
Mastiff's Avatar
Quoted: 94 Post(s)
@HDfury , This device is rock solid. Not one wrong move in the month I've had it! Out of pure interest, is the HTPC mode simply blocking the signal to pin 19 on the HDMI plug to avoid hot pluggin detection? If you can answer and it isn't a business secret, that is.
11.4/7.4.4 Wharfedale E-series, Wharfedale Topaz 12" and 15" subwoofers, B&W ceiling speakers for Atmos/DTS:X use, Yamaha RX-A3070 for 7.2.4 and RX-A2070 for 0.2.4 in a Frankenstein presence setup, with RX-V3067 as a pure power amp for ceiling speakers for Atmos/DTS:X use, JVC DLA-X500 projector
Mastiff is offline
post #63 of 83 Old 02-28-2020, 08:45 AM
HDfury's Avatar
Quoted: 5447 Post(s)
Liked: 1585
Yes that's it mainly (hotplug not propagated to the source from the sink), just keep in mind that such mode cannot work with hdcp protected content, so only use it with source that does not use or need hdcp.
Maestro: 4I/4O +4K HDR over HDBT +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver. [Won Best Product Award]
Diva: 4I/3O +Ambient Light +Lag Tester +4K HDR > 1080p SDR +HDMI/ARC/eARC sound to AVR input +autoswitch +webserver.
Vertex2: 4I/3O +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
HDfury is offline
post #64 of 83 Old 02-28-2020, 11:33 AM
Mastiff's Avatar
Quoted: 94 Post(s)
I thought so, thanks for satisfying my curiosity. And I know, I almost exclusively watch ISO ripped stuff, so the HDCP is already stripped.
HDfury likes this.
Mastiff is offline
post #65 of 83 Old 03-03-2020, 12:20 PM
JonStatt's Avatar
Quoted: 67 Post(s)
Liked: 54
I have a 4 way HDMI switch with an optical output that supports bitstream from the HDMI source. However because the output device is an RS2000 projector, the PS4 pro and Xbox one X refuse to go into bitstream output and only output stereo.
Can I download the EDID from the projector and then easily modify it to enable dolby digital 5.1 bitstream?
JonStatt is offline
post #66 of 83 Old 03-03-2020, 02:11 PM
HDfury's Avatar
Liked: 1585
You don't need to modify PJ EDID, you can use one of the available edid banks in Dr.HMDI 4K, way easier than starting to modify EDID if you don't have experience on that.
HDfury is offline
post #67 of 83 Old 03-13-2020, 01:28 PM
HDfury's Avatar
Liked: 1585
Arrow Dr.HDMI 4K - FW0.8
This update is mandatory in case of issue.
Anyone willing to update and provide feedback is welcome.
######### What's new on FW 0.8 #########
1. minor EDID improvements
2. stability improved under heavy use condition
Download link: http://www.hdfury.com/tools/Dr.HDMI4K_v0.8.zip
HDfury is offline
post #68 of 83 Old 03-20-2020, 09:07 AM
schorman's Avatar
Hello,
I would like to determine if the DrHDMI will work for my use case. I have an Oppo UDP-203, run to a Pioneer SC-99 AVR, outputting to an LG OLED 65E6.
The problem I'm having is that the SC-99 EDID doesn't officially support DV passthrough. However, I've been able to get it to pass the metadata.
I've used another EDID emulator (Atlona Etude) in between the Oppo and the Pioneer. I copied the EDID from the LG E6, which allowed the Oppo to output Dolby Vision. The Pioneer SC-99 successfully passes the DV metadata to my TV in this configuration. However, since the EDID for the LG TV does not report that it can handle Dolby TrueHD/DTS HD-MA, I'm only getting standard Dolby Digital output to the receiver.
Would it be possible to use a similar setup with the DrHDMI 4K to achieve Dolby Vision and use lossless codecs or 8 channel pcm with the receiver?
Of note, I've tried copying the EDID from a newer OLED C9 without success. I think the Dolby Vision profile is different on the newer TVs, so it didn't end up working that way.
schorman is offline
post #69 of 83 Old 03-20-2020, 09:10 AM
HDfury's Avatar
Liked: 1585
Originally Posted by schorman View Post
Hello,
Yes sure, that will work just fine.
Our EDID are modded for full audio, so it will work with default custom EDID out of the box.
HDfury is offline
post #70 of 83 Old 03-20-2020, 09:16 AM
schorman's Avatar
Great! Thanks for the quick response.
schorman is offline
post #71 of 83 Old 04-13-2020, 06:03 PM
Liked: 0
Hello,
i have a Sony A9G Oled TV and in NetFlix build-in app i get Atmos sign when using TV's speakers, but when i connect my TV to my AV Receiver trought the eARC, NetFlix downgrades to 5.1. My AV supports Atmos but has ARC HDMI and not eARC. Can i make Sony "think" that is connected to an eARC device, and enable Atmos on NetFlix app, with HDFury Dr 4K ?
xstef75 is offline
post #72 of 83 Old 04-14-2020, 01:36 AM
HDfury's Avatar
Liked: 1585
Originally Posted by xstef75 View Post
Hello,
No you need HDfury Vertex2/Diva or Maestro to extract eARC from your TV and forward to your AVR INPUT !
HDfury is offline
post #73 of 83 Old 04-30-2020, 02:11 PM
Liked: 0
Hi I have a Apple TV 4K which goes to my LG C7 OLED, the problem is the Apple TV sends out the wrong Dolby Vision type, Player-led instead of TV-led. Will the Dr HDMI 4K fix my issue and be able to force TV-Led DV? As currently I have raises blacks and a dimmed picture.
chris2304 is offline
post #74 of 83 Old 04-30-2020, 04:42 PM
HDfury's Avatar
Liked: 1585
Yes it will by using EDID with DV mode 0 or mode 1
HDfury is offline
post #75 of 83 Old 05-01-2020, 06:24 AM
wuffzack's Avatar
Quoted: 13 Post(s)
Control via RS232
Is there a way to switch edid banks programatically? The device has an RS232 port, can this be used? If yes, how? Is there a manual or documentation for the required cable?
wuffzack is offline
post #76 of 83 Old 05-01-2020, 06:29 AM
HDfury's Avatar
Liked: 1585
Just read the RS232.txt that comes with any firmware update package.
Dr.HDMI 4K jack expects the following plug signals:
TIP = TX [sends data out from Dr HDMI 4K]
RING = RX [receives data to Dr HDMI 4K]
SLEEVE = GND
Parameters: 115200, n, 1, no handshake
DRHDMI2 version 0.8 (use #HELP on terminal to display it)
RS232 Commands [precede all commands with #-character ]
get version -- returns the current firmware version
get edid -- returns the current EDID mode and table number
get edidmode -- returns the current EDID mode
get edidtable -- returns the current EDID table number
get htpcmode -- returns htpcmode < on | off >
set hotplug -- issue RX hotplug
set edid < sink | custom | fhd | uhdfull | uhd51 | uhdstereo > < table # >
-- for < sink > no table # is defined, same as "edid custom 8"
-- for < custom > table # 1-8, #8 is the sink EDID
-- for < fhd | uhdfull | uhd51 | uhdstereo > table # 1-8
set htpcmode < on | off > -- set to ignore sink hotplugs
HDfury is offline
post #77 of 83 Old 05-01-2020, 06:45 AM
wuffzack's Avatar
Quoted: 13 Post(s)
Great, I have overlooked this. Exactly what I was looking for. Thanks a lot!
HDfury likes this.
wuffzack is offline
post #78 of 83 Old 05-11-2020, 08:26 PM
mhmercer's Avatar
Quoted: 209 Post(s)
Liked: 55
My prior Dr.HDMI4K failed a while ago. I have a used unit arriving soon. I do not know what version of firmware has been installed. Four questions: 1) How can I check for the current firmware version, so that I can update correctly; 2) what are the differences between v0.8, Driver 3.9.2 and v0.8, Driver 4.0.0; 3) is there an advantage in using Driver 4.0.0 over Driver 3.9.2; 4) how can I replace one driver version with another?
LG OLED55C9 | Denon AVR-X3400H | ATV 4K | Sony UBP-X700 | Hsu HC-1 MK2 (C) & HB-1 MK2 (LRSur), Sub VTF-15H MK2, ELAC Atmos | X-Rite i1D3 OEM | 2019 CalMAN Home for LG
mhmercer is offline
post #79 of 83 Old 05-12-2020, 05:28 AM
HDfury's Avatar
Liked: 1585
If you have WIN10, there is no driver to install anymore, just connect to WIN10 and windows will install driver from internet, once done you can proceed normally with 3.9.2 directory.
You can check FW version by running GUI utility.
There is no advantage in using one driver against another, some combo of OS and USB port might work better but if you are under WIN10, just connect unit and let windows install driver for you and proceed with 3.9.2.
If you need to remove driver and install another, just go in program files/installed program and remove any reference you see to "silicon laboratories", "silabs", "usbxpress" and restart your computer. There is help video on our discord server or on our youtube channel for that if you need.
HDfury is offline
post #80 of 83 Old 05-12-2020, 08:48 AM
mhmercer's Avatar
Quoted: 209 Post(s)
Liked: 55
If you have WIN10, there is no driver to install anymore, just connect to WIN10 and windows will install driver from internet, once done you can proceed normally with 3.9.2 directory.<snip>
HDfury likes this.
mhmercer is offline
post #81 of 83 Old 05-14-2020, 10:54 AM
mhmercer's Avatar
Quoted: 209 Post(s)
Liked: 55
<snip>
There is help video on our discord server <snip>
How does one access the "discord server"; I can't locate it from your website?
mhmercer is offline
post #82 of 83 Old 05-14-2020, 11:07 AM
HDfury's Avatar
Liked: 1585
Go on HDfury.com > support > 24/7
Or just go here: https://discord.gg/dkFtm9
HDfury is offline
post #83 of 83 Old 05-14-2020, 12:51 PM
mhmercer's Avatar
Quoted: 209 Post(s)
Liked: 55
mhmercer is offline
Reply Video Processors
