HDfury Dr HDMI 4k - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-13-2019, 06:02 PM - Thread Starter
blu ray boy's Avatar
Quoted: 39 Post(s)
Liked: 27
HDfury Dr HDMI 4k
Hi I couldn't find any other threads on specifically on the HDfury Dr HDMI 4k with the info I was looking for so I thought I would start this one. Sorry if this has been posted before. I just ordered a Dr HDMI 4k (from now on I will refer to it as the dh4k) to solve what I believe is an edid issue between my NUC PC and my Samsung HDTV. My order has not even been processed yet so I don't have it yet. My specific question is this: how will the dh4k adjust to changes in the framerate from the NUC to the TV? For instance, when I watch something at 2160 at 60hz and then switch to a movie at 2160 24hz or even 1080 60hz, or similar, what happens? Normally when I change outputs from the NUC the tv switches from Standard PC mode to PC Movie mode depending on what the framerate is. (I may not be using the term "framerate" correctly in this example but you get the idea). IOW, when I switch from 60hz to 24hz, do I have adjust the setting on the dh4k? Or is this automatic? Does it even make a difference to the dh4k? Sorry for the long question, I don't know how else to get my point across.
-Jason
blu ray boy is offline
post #2 of 14 Old 03-14-2019, 06:05 AM
HDfury's Avatar
Quoted: 4399 Post(s)
Liked: 1203
-Jason
Sorry that make little sense to me, may be you should send email and explain issue better. Dr.HDMI 4K is a 18Gbps EDID manager, nothing else, so it cannot change frame rate I guess you understand that.
When using between ANY SOURCE and SINK, DR4K is fully transparent, whatever happened before when changing frame rate will still happen there (except if you load edid with different specs of course)
So really, as you wrote it above, there is nothing to say/answer or understand, you first need to explain exactly what you are trying to solve.
Maestro: 4I/4O +4K HDR over HDBT +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver. [Won Best Product Award]
Diva: 4I/3O +Ambient Light +Lag Tester +4K HDR > 1080p SDR +HDMI/ARC/eARC sound to AVR input +autoswitch +webserver.
Vertex2: 4I/3O +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
HDfury is offline
post #3 of 14 Old 03-14-2019, 10:49 AM - Thread Starter
Quoted: 39 Post(s)
Liked: 27
Sorry I didn't explain it better. My understanding of the subject is limited. I guess I will find out when I receive the product. Thanks for the response.
post #4 of 14 Old 03-14-2019, 11:07 AM
HDfury's Avatar
Liked: 1203
Np, feel free to try to explain it better, then I can prolly help.
HDfury is offline
post #5 of 14 Old 03-14-2019, 11:10 AM - Thread Starter
Quoted: 39 Post(s)
Liked: 27
I doubt I could explain it better.
post #6 of 14 Old 07-09-2019, 03:51 PM
Herve's Avatar
Quoted: 416 Post(s)
Liked: 78
I connected our Dell 5060 PC to our year-old Sony 900e TV. The system detected the Sony TV. When I investigated available sound settings, 5.1 channel audio was indeed available to be sent to the Sony.
The 5060 identifies our 11-year-old JVC DLA-RS1 projector as display type "ILAFPJ--XH", but, unlike the Sony TV, Windows settings is preventing 5.1-channel audio from being sent via display port. Only 2-channel audio can be selected and sent.
Older versions of windows on older PCs would somehow "assume" that the HDMI signal was going to go to some kind of receiver prior to going to the RS1 and they delivered 5.1 regardless of the fact that the projector couldn't play it. I know this is true because our old HP Slimline HTPC with Windows Vista used to output 5.1 audio to the RS1. Unfortunately, that PC's motherboard failed a couple of months ago and that is why I purchased the Dell 5060 to replace it. So far, the Dell is nowhere near the HTPC that the HP was.
Will the Dr HDMI "tell" Windows 10 in the Dell 5060 that it is connected to a device which can accept a 1080p 60Hz signal with 5.1 audio via display port? Put another way, can the Dr. HDMI tell the Dell that it is connected to a new Sony TV instead of an old RS1? (BTW, I use a male display port to male HDMI cable to connect the PC to an HDMI switch, which then connects to the RS1. The Dell correctly identifies the JVC RS1 THROUGH the switch.)
Is there a less expensive HD fury device that will solve this problem? Do you know of any way to trick Windows 10 into sending 5.1 audio to our RS1 projector without having to install an interface? Do you know if installing a sound card with optical spdif output would force Windows to make 5.1 audio available through the sound card?
Herve is offline
post #7 of 14 Old 07-10-2019, 07:06 AM
HDfury's Avatar
Liked: 1203
Yes Dr.HDMI 4K will tell your PC it is connected to FHD 5.1 device, however this will work ONLY if your current DP > HDMI Adapter does not override EDID, it should not as long as you can detect display EDID thru it which it seems you can from your report
If you only need FHD 5.1 then you can use normal Dr.HDMI which is a bit cheaper.
HDfury is offline
post #8 of 14 Old 07-10-2019, 08:47 AM
Herve's Avatar
Quoted: 416 Post(s)
Liked: 78
Is "ILAFPJ--XH" the RS1's EDID? If it is not, is it possible to obtain the RS1's EDID either from the computer or the RS1 itself (I can explore the RS1's owners manual in the latter case)? Regardless, I believe that the computer is indeed identifying the projector correctly. Because an interface would be installed between the cable out of the computer and the input of the switch, the cable could not override something that it never got the opportunity to "see" (interface with).
Thanks very much for your input.
Herve is offline
post #9 of 14 Old 07-10-2019, 09:59 AM
HDfury's Avatar
Liked: 1203
Yes it is JVC PJ EDID, you can copy sink EDID with Dr.HDMI as well. I was asking this because most DP > HDMI are active converter so you never know what they are doing exactly unless we have one in our lab and can test it.
HDfury is offline
post #10 of 14 Old 07-10-2019, 10:43 AM
Herve's Avatar
Quoted: 416 Post(s)
Liked: 78
What exactly is "sink" EDID?
Herve is offline
post #11 of 14 Old 07-10-2019, 01:20 PM
HDfury's Avatar
Liked: 1203
SOURCE is a device at input
SINK is a device at output
So if you have TV at output, then you can read/sniff it's EDID
HDfury is offline
post #12 of 14 Old 07-10-2019, 03:53 PM
Herve's Avatar
Quoted: 416 Post(s)
Liked: 78
So in my case, I know that Windows 10 will send 5.1 to our Sony 900e TV. Would it be possible for the Dr. HDMI to copy that TV's EDID and, if so, how would the DR HDMI to do that -- simply connect the computer's hdmi to the Dr HDMI; connect the Dr. HDMI to the TV via hdmi and then somhow tell the Dr HDMI to copy the TV's EDID, so that I can then use that EDID when connecting the computer to the RS1 projector?
Herve is offline
post #13 of 14 Old 07-10-2019, 05:31 PM
HDfury's Avatar
Liked: 1203
Just connect Dr HDMI output to TV and press a button and EDID is copied, yes you should do that if it doesn't work out of the box with supplied edid.
HDfury is offline
post #14 of 14 Old 07-10-2019, 06:14 PM
Herve's Avatar
Quoted: 416 Post(s)
Liked: 78
Herve is offline
Reply Video Processors
