Seeking 4X4 or 6X4 hdmi 4k hdr 18 ghz switcher - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-23-2019, 12:30 AM - Thread Starter
audvid's Avatar
Quoted: 543 Post(s)
Liked: 161
Seeking 4X4 or 6X4 hdmi 4k HDR 18 ghz switcher. Matrix or non matrix - either would work.
Please suggest.
audvid is offline
post #2 of 8 Old 03-28-2019, 09:58 AM
Seraphic-'s Avatar
Quoted: 53 Post(s)
Seraphic- is offline
post #3 of 8 Old 03-28-2019, 04:40 PM
Willie's Avatar
Quoted: 177 Post(s)
Liked: 247
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This has worked flawlessly for me; I often use the matrix function. Passes 4k 60 Amazon Prime etc. And since the vendor is Amazon, if it doesn't work you can send it back.
Willie
Willie is offline
post #4 of 8 Old 03-28-2019, 05:17 PM - Thread Starter
audvid's Avatar
Quoted: 543 Post(s)
Liked: 161
Willie
thanks. Have you verified that it works well with HDR?
audvid is offline
post #5 of 8 Old 03-29-2019, 04:51 AM
Willie's Avatar
Quoted: 177 Post(s)
Liked: 247
Passes HDR10 and HLG just fine. I have not bothered with DV because I am using a JVC RS1000 currently.
Willie is offline
post #6 of 8 Old 03-31-2019, 10:15 AM
kwk2293's Avatar
Quoted: 87 Post(s)
Liked: 35
the one i have wont pass hlg hdr nor is it suppose to iv talked to customer support doesn’t sound like it will be added either do u have 4x4 or 8x8. i wouldn’t recommend it . it has problems
kwk2293 is offline
post #7 of 8 Old 03-31-2019, 06:40 PM
Willie's Avatar
Quoted: 177 Post(s)
Liked: 247
Mine works as I previously stated. Passes HDR10 and HLG just fine. It is a 4X4. Perhaps you have cable issue. Unclear.
Willie is offline
post #8 of 8 Old 05-28-2019, 07:17 AM
12B4A's Avatar
Quoted: 595 Post(s)
Liked: 514
Willie
Forum link skimmer is malfunctioning. Can you provide a product name?
I've been looking for a seamless switcher for UHD (do not need matrixing) but I haven't found anything priced at the consumer level like a Sewell Crossbow is for HD. Any ideas?
Life is Lambertian
12B4A is offline
Reply Video Processors
