HDFury Vertex2 - Owner's Thread - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 247Likes
post #1171 of 1443 Old 02-20-2020, 07:23 AM
ScottAvery's Avatar
Quoted: 856 Post(s)
Liked: 246
I tried using tx01 to a 1080p monitor last night and now see why I should have bought the Diva. It works with the scaler configured, but obviously HDR colors are just a little off. Can you remind me is there some feature I would have lost if I just got the Diva to begin with? Does Diva ALWAYS downscale on tx01 or is it optional like on Vertex 2?
ScottAvery is offline
post #1172 of 1443 Old 02-20-2020, 08:04 AM
HDfury's Avatar
Quoted: 5161 Post(s)
Liked: 1475
DIVA only have 1x 18Gbps output, the other is always 1080p but can convert HDR>SDR + Audio out
Vertex2 have 2x 18Gbps output and cannot convert HDR>SDR + Audio out
Maestro: 4I/4O +4K HDR over HDBT +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver. [Won Best Product Award]
Diva: 4I/3O +Ambient Light +Lag Tester +4K HDR > 1080p SDR +HDMI/ARC/eARC sound to AVR input +autoswitch +webserver.
Vertex2: 4I/3O +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
HDfury is online now
post #1173 of 1443 Old 02-20-2020, 08:37 AM
ScottAvery's Avatar
Quoted: 856 Post(s)
Liked: 246
Yeah, that must have been my deciding factor as you had said I could do a loopback to run my Oppo 203 through the Vertex for EDID after receiving input from tx0 for scaling. I did not manage to get that to work, but I didn't troubleshoot very aggressively. I had it set to Matrix mode so the tx0 and tx1 should not have interacted, but as soon as the 4th cable is connected all output was lost. I don't know if there is some sort of protection in the HDMI path to prevent that loopback. Is there some trick to getting a loopback to work? I can't give you configs as I have rewired everything already.
post #1174 of 1443 Old 02-20-2020, 08:50 AM
HDfury's Avatar
Liked: 1475
you need a device in between if you want to loopback, so Diva output > any device > Diva input.
This is something that worked without any device in between on earlier firmware but due to some people issue we had to rework it differently.
post #1175 of 1443 Old 02-20-2020, 09:20 AM
ScottAvery's Avatar
Quoted: 856 Post(s)
Liked: 246
Yes, I had a device in between, the Oppo 203 which I wanted to use as scaler for all other sources. It was matrixed this way:
ATV4k -> Onkyo 830 -> Vertex HDMI 0 / Tx0 -> Oppo203 -> Vertex HDMI 1 / Tx1 -> JVC rs540
I think I probably tried reversing it to Tx1 to Oppo then Tx0 to projector, but I cannot recall. Would that have been preferred?
I tested a number of ways with content on screen and watching the I/O readout on the Vertex screen, always the output ended and sinks went to standby when the last connection was made.
post #1176 of 1443 Old 02-20-2020, 10:00 AM
HDfury's Avatar
Liked: 1475
It does not matter if TX0 goes back to input or TX1
I think you should try without AVR and may be with special firmware (send me PM for that)
post #1177 of 1443 Old 02-20-2020, 11:28 AM
ScottAvery's Avatar
Quoted: 856 Post(s)
Liked: 246
Thanks, I will try it when I get a chance. Its working for now, but this would be a nice option as I cannot otherwise scale 4k60 sources with my current projector, which I understand may be an issue with some of the subscription streaming services.
post #1178 of 1443 Old 02-20-2020, 12:09 PM
Fredstwofeet's Avatar
Quoted: 29 Post(s)
Liked: 9
Send a message via AIM to Fredstwofeet
Little help please..
I want to use two different macros for DV. One for input 0 (Nvidia Shield) and the other for Input 3 (Sony Bluray). I don’t want to disable/prevent process of any versions of HDR.
Thanks all.
Vertex2 > JVC nx7 direct.
Fredstwofeet is offline
post #1179 of 1443 Old 02-20-2020, 12:13 PM
HDfury's Avatar
Liked: 1475
Thanks all.
Please elaborate a bit on what you would like to achieve, it is not clear to me.
post #1180 of 1443 Old 02-20-2020, 01:24 PM
Quoted: 29 Post(s)
Liked: 9
Sure...so when I watch DV content from the Shield TV I want my JVC to auto switch to “User1”. Likewise when I watch a Blu-ray DV I want the JVC to auto switch to “User4”. I have been sending macros for similar applications however I need some help getting the two different DV signals to trigger my selected User profiles without interfering with other formats.
post #1181 of 1443 Old 02-20-2020, 01:53 PM
claw's Avatar
Quoted: 2735 Post(s)
Liked: 2578
There is only one LLDV macro that is executed when the Vertex sees LLDV from any input. You can only configure one user mode for all LLDV input. Unlike HDR10 input where you can configure a macro based on HDR10 metadata values, you can't do this with LLDV input.
HDfury likes this.
CJ
JVC RS500 | LG B7A OLED | Denon X6400H/X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #1182 of 1443 Old 02-20-2020, 02:13 PM
Quoted: 29 Post(s)
Liked: 9
What if I were to copy the “captured input DV from source” and then paste that into one of the custom hex profiles associated with any of the macros, and then tag that with “User4?”
post #1183 of 1443 Old 02-20-2020, 04:28 PM
claw's Avatar
Liked: 2578
No, the custom hex fields are used to specify a custom RS-232 command to send to the display instead of the default JVC command. The field is not used as macro selection criteria.
HDfury likes this.
CJ
claw is offline
post #1184 of 1443 Old 02-20-2020, 05:50 PM
Quoted: 29 Post(s)
Liked: 9
Yeah, I kinda doubted that criteria was relevant. I’m still very new to all this and throwing darts. Thanks for taking the time to respond!
post #1185 of 1443 Old 02-23-2020, 02:14 PM
Lush78's Avatar
Quoted: 40 Post(s)
I email Logitech the new IR codes a week ago with still no reply. How long does this request typically take? Is HDFury able to add these new codes to the public database to resolve the issue with phones using face recognition (pixel 4, iPhone 11, etc). This will be a bigger problem going forward as other phone manufacturers implement this technology...
Lush78 is offline
post #1186 of 1443 Old 02-23-2020, 03:25 PM
HDfury's Avatar
Liked: 1475
make sure you sent to datasupport at Logitech.com, and verify that they are not yet online already since others users might have done that already.
Time depends if you ask them to add to your account or publicly, publicly takes a bit longer and of course, you need to send them MAX 100 IR codes.
post #1187 of 1443 Old 02-23-2020, 03:57 PM
Lush78's Avatar
Quoted: 40 Post(s)
I attached the three TXT files packed with the firmware updates and sent them to that datasupport email. Was this the correct way to make this request? I've asked them to be added to my personal account and also publicly if possible to help others having the same issue. I did add the vertex2 on a separate harmony hub to check to see if it already had the codes, but unfortunately they are not included in the public device profile.
Lush78 is offline
post #1188 of 1443 Old 02-23-2020, 05:15 PM
mombasa123's Avatar
Quoted: 189 Post(s)
Liked: 54
I can't seem to get the HDR metadata injection to work correctly. The picture looks awful. What am I missing please? TV is Samsung QLED Q9FN. It reports 4K HDR but the picture is totally off.
Not sure I need the AVIFrame settings but makes no difference with or without.
Scaling is set to Auto with 'TX0 No Scaling' disabled
PS for context, I am trying to inject HDR metadata into the output of the RPi PGenerator so I can try out a Calman HDR autocal but as per above.
https://www.avsforum.com/forum/139-d...l#post58777508
Name:	HDR Config.jpg
ID:	2689204   Click image for larger version
Name:	HDR Video.jpg
mombasa123 is offline
post #1189 of 1443 Old 02-24-2020, 04:40 AM
Archibald1's Avatar
Quoted: 2471 Post(s)
Liked: 1357
Exporting my config
Okay, so I must be missing something basic, but when I go to the CONFIG tab of my Vertex2 and select the EXPORT button to export my config, nothing seems to happen.
How do I know it has exported anything as there is no indication that anything has happened. Moreover, where would it save the file?
Please can someone tell me what I have missed?
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is online now
post #1190 of 1443 Old 02-24-2020, 05:49 AM
HDfury's Avatar
Liked: 1475
Harmony only support 100 IR codes, so make sure you make a selection of 100 IR codes before sending any list to them !
post #1191 of 1443 Old 02-24-2020, 05:53 AM
HDfury's Avatar
Liked: 1475
If TV goes in HDR mode, then injecting HDR metadata is working just fine.
If you don't play any HDR content when doing that then its normal picture is off, not sure how it could be otherwise.
And please use config export instead of screenshot, way more useful and relevant.
post #1192 of 1443 Old 02-24-2020, 05:55 AM
HDfury's Avatar
Liked: 1475
There is a prompt dialog that open and ask you where you want to save the file (assuming you are doing that from a desktop computer)
If that does not happen, i can be a few things, i would first clear internet cache and re access webserver to retry, if still any issue, give us OS and browser you are trying, and try from known browser such as chrome if you haven't tried it yet.
post #1193 of 1443 Old 02-24-2020, 06:23 AM
Lush78's Avatar
Quoted: 40 Post(s)
Is the max 100 combined with all 3 presets or per preset? Either way, in my case I only need the 4 inputs per preset. I would like to get these updates included in the public profile though for all to use. I would have thought harmony could at least respond to my email indicating if there was a problem. Would it be possible to tailor these IR codes down to what is used most by the community so that we could have universal public profiles for all to use?
Lush78 is offline
post #1194 of 1443 Old 02-24-2020, 06:29 AM
HDfury's Avatar
Liked: 1475
100 ir codes per list, no matter how many code list you send, so 100 for each ir codeset. The whole difficulty is to filter them and keep what user would need but it is nearly impossible to satisfy all users because some will want a particular code for a particular custom edid and since there is already 100 custom EDID, it cannot match all, that's why we prefer people to send account request directly for Logitech with what they want/need.
post #1195 of 1443 Old 02-24-2020, 06:52 AM
Lush78's Avatar
Quoted: 40 Post(s)
Thanks. I guess I will just slim down the code list for my personal needs and try again. Do they typically respond to theses requests or do I just continually re-add the device and check for additional profiles?
Lush78 is offline
post #1196 of 1443 Old 02-24-2020, 07:07 AM
Archibald1's Avatar
Liked: 1357
Hi.
Thanks for the pointers.
I was using Edge, and I tried turning off the pop-up blocker but that didn't change anything.
I also checked my security software settings.
I then tried Firefox and that worked and the popup dialogue came up as expected.
Cheers.
HDfury likes this.
Stephen Hawking.
post #1197 of 1443 Old 02-24-2020, 08:00 AM
HDfury's Avatar
Liked: 1475
Not sure if they will email everyone or if any such policy have changed, usually it takes a couple of working days.
post #1198 of 1443 Old 02-24-2020, 05:25 PM
mombasa123's Avatar
Quoted: 189 Post(s)
Liked: 54
TV definitely goes into HDR but CS looks like its BT709 10bit SDR instead of 2020? At least that's what the OSD TX0 line states.
In the link I posted, it says click always to send REC 2020 but I can't see that option anywhere in the Vertex HDR page https://www.avsforum.com/forum/139-d...l#post58777508
Name:	HDR Video.jpg
post #1199 of 1443 Old 02-24-2020, 08:37 PM
claw's Avatar
Liked: 2578
I use the Chrome browser on either Windows 7, 8, or 10, and it never brings up a save file dialog. Instead it writes it to the downloads folder. I imagine I could go into Chrome settings for the file type and set it to ask what to do instead.
Todd G. and HDfury like this.
CJ
claw is offline
post #1200 of 1443 Old 02-25-2020, 07:27 AM
HDfury's Avatar
Liked: 1475
Not sure what you mean by "click always to send REC2020"
If you do not send HDR content, then forcing display in HDR will give wrong colors.
If your source is sending HDR content but for who knows which reason the AVI infoframe that comes with it is wrong, then you need to overwrite AVI infoframe, if you don't know what AVI infoframe is and don't know how to format it, then i suggest you do not try such thing at all, you are supposed to know what you are doing when you use advanced features as i already explained, i cannot explain all AV basics to all users (especially since all that is already covered many times in history and it is not a support issue), this is something you are supposed to learn and read about on your own before even trying or considering using our devices for such purpose.
mombasa123 likes this.
Reply Video Processors
