Originally Posted by
HDfury
Look, if you use matrix, then you have to make sure you select the right input, if you want to turn on the unit and have the unit switch to active input, then you need to use autoswitch.
Yes, I am definitely selecting the correct input. I've verified using the web gui that the correct input is routed to the correct output. I do not want auto-switch because I am sending RS232 commands every time I select a different input.
HDfury
If you are sure you are sending the right command at the right time and have black screen, then next time you see it, just go to gefen and remove/reconnect power from it and tell us what happens.
I think I tried what you are asking. The last time it happened, I unplugged the HDbaseT receiver. I also unplugged the HDMI cable at the HDbaseT transmitter.
HDfury
I just spent 3H trying to reproduce any of that, could not, picture came on perfectly all the time, so there is something in your setup and we have to find out what exactly is making issue cause as long as we cannot reproduce it, then we cannot fix it.
I really do appreciate all of your effort in helping me. Are you changing inputs using RS232 in your testing or the web gui? I'm almost always using RS232. I think I send the command even if the input is already routed correctly. (ie. every time my home automation system turns on my TV, it will issue the 'input change' command regardless of the current input)
Here is the command:
Code:
#vertex2 set inseltx1 0
HDfury
Also since you use RS232, then turn OFF CEC on every device in the chain and see if something differs, may be you send manual RS232 commands but CEC switching over rides your instructions
OK - I'll turn off CEC on my devices. I don't think CEC is overriding my commands because I see the correct input on my TV and AVR so it doesn't look like CEC is changing any inputs.
What is happening when the Vertex2 is rebooted? I would think it would have a similar effect to [ISSUE HOTPLUG]?
