Any devices to display/view HDMI signal information and pass-through signal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-20-2019, 06:36 AM - Thread Starter
sofakng's Avatar
Quoted: 111 Post(s)
Are there any devices that can pass-through an HDMI signal with zero latency, but decode the signal information and output over TCP/IP or RS232?
Basically I'd like exactly the HDfury Vertex/Integral 2 does but I don't need any scaling/matrix, etc. (I also already have an HDfury Vertex that I use for other purposes in a different location)
The problem I'm trying to solve is that sometimes I don't get a signal on my TV and I have several components in the chain (PS4 -> Denon AVR [Zone 2] -> Gefen Matrix -> HDbaseT -> TV), and I was thinking it might be helpful to see if the device (PS4, etc) is actually outputting anything or if it's another device in the chain.
EDIT: I'm wondering if HDCP might be the cause for my intermittent problems?
sofakng is offline
post #2 of 2 Old 06-23-2019, 07:57 AM
HDfury's Avatar
Quoted: 4290 Post(s)
Liked: 1164
If you have Vertex already, just get special firmware and insert it betwwen PS4 and Denon to see if it helps your issue, you can send email for that.
You can also insert it anywhere in the chain to find out which device stop or break transmission.
Maestro: 4I/4O +4K HDR over HDBT +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
Diva: 4I/3O +Ambient Light +Lag Tester +4K HDR > 1080p SDR +HDMI/ARC/eARC sound to AVR input +autoswitch +webserver.
Vertex2: 4I/3O +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
HDfury is offline
Reply Video Processors
