Radiance XE stuck in standy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-13-2020, 10:31 PM - Thread Starter
Glen911's Avatar
Hey,
Has anyone ever had their Radiance XE just get stuck in standby? The red light is on but it won't seem to switch to on.. tried the remote and the rs-232 input. Wondering if it might just be the power supply needs replacing or is there some magic reset trick?
Glen911 is offline
post #2 of 3 Old 04-14-2020, 10:06 AM
Gordon Fraser's Avatar
Quoted: 259 Post(s)
Liked: 381
Most likely the power supply if it will not even come on from serial control. You can get them from amazon for not much if it's a 4 pin din version. If it's a normal barrel socket then Lumagen will likely sell you a current Radiance supply that will work.
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #3 of 3 Old 04-17-2020, 10:14 AM - Thread Starter
Glen911's Avatar
Thanks Gordon, managed to get one off amazon and it now turns on again. Can't seem to get any kind of video output from it though and there's a nasty hum from my speakers when connected to the prepro so maybe something got fried inside :-(
Glen911 is offline
Reply Video Processors
