HD FURY Question Video/Audio Split - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-16-2020, 01:43 PM - Thread Starter
woofer's Avatar
Quoted: 1794 Post(s)
Liked: 2771
I want to output HDMI Video/Audio from my HTPC to a HD Fury device .....then split the video to go straight to the Projector and the Audio to an AV Processor.
Is this possible, and if so wihch of the HD Fury device is best suited? I have the ..LINKER...INTEGRAL...VERTEX
Thanks..
woofer is online now
post #2 of 5 Old 04-16-2020, 05:48 PM
HDfury's Avatar
Quoted: 5447 Post(s)
Liked: 1585
Thanks..
Vertex !
Connection is based on PJ and AVR specs, so i can tell you more if you post brand/model or max supported res of each devices you want to connect at output.
Maestro: 4I/4O +4K HDR over HDBT +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver. [Won Best Product Award]
Diva: 4I/3O +Ambient Light +Lag Tester +4K HDR > 1080p SDR +HDMI/ARC/eARC sound to AVR input +autoswitch +webserver.
Vertex2: 4I/3O +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
HDfury is offline
post #3 of 5 Old 04-16-2020, 07:44 PM - Thread Starter
woofer's Avatar
Liked: 2771
Originally Posted by HDfury View Post
Vertex !
Thankyou for the reply
Projector is... JVC Z1/RS4500
AV Processor is .. NAD M17 V1
I wish to to run one HDMI cable from the 2080TI in my HTPC to the "Vertex" ( as you suggest).... then split the Video to go to the JVC Z1/RS4500 (1st output) and the Audio only to go to the NAD M17 V1 (2nd output)
Could you please advise setup
Thankyou
post #4 of 5 Old 04-17-2020, 05:28 AM
HDfury's Avatar
Liked: 1585
Thankyou
Ok so just connect JVC to bottom output and AVR to top output, put edid slide on default mid position and put scaling slide on autoscaling and you should be fine out of the box.
HDfury is offline
post #5 of 5 Old 04-17-2020, 02:00 PM - Thread Starter
woofer's Avatar
Liked: 2771
Thankyou...
Reply Video Processors
