4k HDMI splitter question - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By jaredmwright
  • 1 Post By HDfury
  • 1 Post By HDfury
  • 1 Post By HDfury
post #1 of 10 Old 04-16-2020, 05:39 PM - Thread Starter
Toe
Toe's Avatar
Quoted: 2819 Post(s)
Liked: 3773
Looking for a 4k HDMI splitter with 1 in and 2 outs so I can get lossless audio to my older preamp (which won't pass a 4k signal) with one of the HDMI outs and 4k/HDR video with the other HDMI out to my JVC projector. Need for both outputs on the splitter to work at the same time obviously. Are there any splitters that can do this?
Toe is online now
post #2 of 10 Old 04-16-2020, 05:40 PM
jaredmwright's Avatar
Quoted: 56 Post(s)
Liked: 33
Originally Posted by Toe View Post
Looking for a 4k HDMI splitter with 1 in and 2 outs so I can get lossless audio to my older preamp with one of the HDMI outs (which wont pass a 4k signal) and 4k/HDR video with the other HDMI out to my JVC projector. Need for both outputs on the splitter to work at the same time obviously. Are there any splitters that can do this?
Look at the Gofanco Prophecy, I had good luck with it.
Sent from my SM-G986U using Tapatalk
Toe likes this.
jaredmwright is offline
post #3 of 10 Old 04-16-2020, 06:01 PM
HDfury's Avatar
Quoted: 5437 Post(s)
Liked: 1578
Product page of this device quoted mention: "Does NOT support resolution downscaling from 4K2K @60Hz 4:2:2 to 1080P"
So it won't work for any such signal which is what HDR games use and DV/LLDV
Important to consider depending on your source.
If you need device that work with everything and support anything : Integral2 or Vertex.
Toe likes this.
Maestro: 4I/4O +4K HDR over HDBT +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver. [Won Best Product Award]
Diva: 4I/3O +Ambient Light +Lag Tester +4K HDR > 1080p SDR +HDMI/ARC/eARC sound to AVR input +autoswitch +webserver.
Vertex2: 4I/3O +Autoswitch any sources +HDMI/ARC/eARC sound to AVR input +webserver.
HDfury is offline
post #4 of 10 Old 04-16-2020, 06:26 PM
Quoted: 56 Post(s)
Liked: 33
Good point, make sure your resolutions are supported. I used it with a 1080P projector 5030ub and didn't use those listed.
Toe likes this.
post #5 of 10 Old 04-16-2020, 06:40 PM - Thread Starter
Toe
Toe's Avatar
Liked: 3773
Very much appreciate the info. So with the Integral2 both HDMI outs can be used at the same time to accomplish what I want to do from my original post?
Toe is online now
post #6 of 10 Old 04-16-2020, 07:21 PM
HDfury's Avatar
Liked: 1578
Yes. and if you give details about the devices you want to connect at output, their max supported res or link to their usermanual in PDF, i can tell you how to connect it and set it.
Toe likes this.
HDfury is offline
post #7 of 10 Old 04-16-2020, 08:30 PM - Thread Starter
Toe
Toe's Avatar
Liked: 3773
Very cool and I appreciate the offer! I'll let you know if I decide to grab the Integral.
Was also just reading the Integral only adds less than 1ms of lag? That's impressive and important for gaming of course!
Toe is online now
post #8 of 10 Old 04-17-2020, 05:27 AM
HDfury's Avatar
Liked: 1578
input lag is in nano seconds count, so not even 1ms
Make sure you use Vertex or Integral2 (and not Integral1 which is not suitable for what you need to do here)
Toe likes this.
HDfury is offline
post #9 of 10 Old 04-23-2020, 07:50 AM
Liked: 0
From my understanding its currently not possible to downscale 4K HDR to 1080p non-HDR. Only downscaling 4K non-HDR to 1080 non-HDR is possible
Ethan07 is offline
post #10 of 10 Old 04-23-2020, 09:45 AM
HDfury's Avatar
Liked: 1578
4K HDR to 1080p SDR is possible with HDfury Diva (1 unit solution)
Or buy using Vertex1 or Integral2 with HDfury X4 (needs 2 units)
HDfury is offline
Reply Video Processors
