Connection options on TV with no headphone jack - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-05-2017, 01:26 PM - Thread Starter
kihi.lind's Avatar
My TV (LG 32LN5300) doesn't have a jack for a headphone, but I want to connect my headphones to it. It has a bunch of outputs on the back (see attached spec sheet for connection options), including optical connections. Any advice on how I can do that?
kihi.lind is offline
post #2 of 9 Old 01-05-2017, 10:18 PM
Worf's Avatar
Quoted: 797 Post(s)
Liked: 521
You need a DAC/amp - the DAC to convert the optical to analog and the amp to drive the headphones. Prices vary - you can get cheap ones designed for games for $20 or less, or spend over $2000 for it.
Worf is offline
post #3 of 9 Old 01-06-2017, 09:28 AM - Thread Starter
kihi.lind's Avatar
Something like this? http://www.monoprice.com/product?p_id=6884
If that's it, the only other thing I need is an optical cable, right?
post #4 of 9 Old 01-06-2017, 11:02 AM - Thread Starter
kihi.lind's Avatar
If it helps, I use Sennheiser PXC 450 headphones: https://en-us.sennheiser.com/noise-c...travel-pxc-450
post #5 of 9 Old 01-06-2017, 12:30 PM
JohnFR's Avatar
Quoted: 17 Post(s)
JohnFR is offline
post #6 of 9 Old 01-06-2017, 01:08 PM - Thread Starter
kihi.lind's Avatar
Originally Posted by JohnFR View Post
That's what I thought as well, so I bought it, but it didn't work. I figure there must be another solution.
post #7 of 9 Old 01-06-2017, 02:20 PM
JohnFR's Avatar
Quoted: 17 Post(s)
I loooked up your set and it doesn't have RCA audio output but has digital optical output (Toslink). This digital to analog converter should work along with the splitter you have:
https://www.amazon.com/dp/B01H4XC3DC?psc=1
JohnFR is offline
post #8 of 9 Old 01-06-2017, 04:12 PM - Thread Starter
kihi.lind's Avatar
Thanks! I ended up getting this one because it had a ton of good reviews: https://www.amazon.com/gp/product/B0...ilpage_o01_s00. I hope it works as well as what you suggested :-)
post #9 of 9 Old 01-15-2017, 09:18 AM - Thread Starter
kihi.lind's Avatar
Problem fixed! I got one of these: https://www.amazon.com/gp/product/B0...ilpage_o05_s00. Thanks for everyone's help!
Reply Headphones
headphone jack , television , television:setup
