AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Headphones (https://www.avsforum.com/forum/378-headphones/)
-   -   Headphone Surround Sound (https://www.avsforum.com/forum/378-headphones/3034902-headphone-surround-sound.html)
bdht 12-14-2018 07:25 PM
30 Attachment(s)
I'd like to share my experience in building a virtual surround sound system. There's constantly questions about what headphones to use for movies, and everything save for one expensive device that isn't out yet seems rather lackluster. I've used lots of software and equipment and the end result of being able to put on a pair of headphones and have such natural sounding high fidelity external virtualization of a 7.1 loudspeaker system is truly marvelous. A front soundstage anchored to the display, clearly rendered and discrete side and rear surround channels, long resolved pans, every bit of the most complex surround movie mixes(looking at you Ready Player One race scene) rendered in full detail over 2 tiny headphone drivers. With the added benefit of providing a virtual 2 channel loudspeaker system for music listening, as well as being able to change the room you're in with the push of the button, no phoney reverb effect, this is the real deal, treated studios, untreated listening rooms, home theaters, huge movie theaters.
Research and development of room impulse responses and binaural synthesis has been done for decades, and is finally cultivating in consumer products. So if you see anyone claiming headphone surround sound is a gimmick based soley on a budget gaming headset, point them to the plethora of scholarly articles over the past 20 years on the subject.
The following are all modeled and not using measurements:
Dolby Headphone / Atmos for Headphones
Windows Sonic
Creative CMSS 3D / SBX
Razer Surround
DTS Headphone X
Toneboosters Isone
Flux Hear
Sennheiser GSX
Dspeaker headspeaker
Waves NX and the Audeze Mobius
1) Darin Fong's Out of Your Head is the only product aside from the Smyth Realisers which uses measured room impulse response applied to the binaural processing. The measurements of movie theaters, home theaters, recording studios, or hifi listening rooms were made using the Smyth Realiser A8.
Since the program is a stand alone piece of software, parts of the Realiser aren't used, like headphone correction. So this must be done manually using something like Equalizer APO, to equalize the headphones to have a flat response. This is very important and something I don't think alot of people do when they try OOYH or other HRTF based virtualization, and ends up sounding very bright/grating/noisy in the 2-6khz region due to double HRTF, but after the EQ, sounds very natural. Of course something with a relatively flat uncompensated response could be used without EQ, but anything that follows the Harman curve you'll want to bring 2-6khz down ~5-10db.
2) When using these programs, I've found headphones with more responsive drivers render the virtual rooms better. Planar magnetic and electrostatic drivers being the best. Anything with a fast response, little to no treble ringing(good imaging), and low distortion. Soundstage ability is important as well for better externalization of the virtual speakers. Open headphones are great, deep angled pads, etc. e.g. the Sennheiser HD800. I use a pair of Audeze EL-8s, MrSpeakers Alpha Primes, Stax SR-207, Hifiman HE-400i, Sennheiser HD650, and I also have a pair of Audeze Mobius. The EL8s work best for me with a pad mod(I use the Dekoni LCD Velour pads, they reduce a bit of treble ringing and push the drivers out further), the Alpha Primes muster a nice room size despite being closed, the Stax have scary realism but sound very close(less soundstage / small room size).
3) Lossless movie audio bitrate is 10-15mb/s, doubled for the binaural rendering and room reflections, crammed into a 48khz container. Due to the large amount of data and complex waveforms, the digital to analog conversion(more so the analog amplifiers and outputs) makes a huge difference in rendering the measurements of rooms. I have several devices I've tried, ranging from the standard motherboard Realtek chip, the dac and headphone out in a Denon X4200W, a JDS Labs ODAC/O2, an Audio-GD NFB-11, and an Audio-GD NFB-7. Using the computer motherboards headphone output results in a neat surround sound effect with little fidelity, scaling up to the NFB-7, which renders the virtual loudspeakers with incredible realism and accuracy, especially with the more reverberant rooms, due to the extremly short signal path of the non feedback current signal amplifiers.
4) Digital and power conditioning improves realism further, improves fidelity substantially, and reduces listener fatigue. I use a device from Uptone Audio called the ISO regen, which isolates from the PC, regenerates and clocks the data, with ultra low noise voltage regulation, an Uptone Ultracap LPS powers the iso regen and the usb to i2s conversion board in the dac, as well as isolating both from the ac mains, and a Topaz Ultra-Isolator Line Noise Supressor, used to isolate the dac and amp from the ac mains, these were primarily used for scientific measuring equipment in labs. There are posts from the early 2000s on this forum of people using the isolation transformers as affordable power conditioning.
5) Add a bass shaker system, a small 20w shaker carefully attached to a chair frame really helps with immersion for special effects. I duplicate the audio with Voicemeter so the shaker system is separate from the headphone system. When properly dialed in sometimes between the shaker and headphones that can play low(20hz) I'll get shocking sub bass hits that feel suprisingly natural like actual subwoofers, chest hits and all.
So to some it up, I feel OOYH is the best headphone surround program out there at the moment, except of course for the Realiser. The measurements of rooms(PRIR, personal room impulse response) makes the biggest difference when compared to other options. The program scales very well with better equipment, but isn't necessary, just make sure the headphones you're using play flat(HPEQ, headphone equalization to avoid a double HRTF and harshness in the 2-6khz range). Using open headphones with fast responsive, low distortion drivers and good imaging as well as using hifi DACs, amps with ample power supplies to render all the data, and conditioning devices to greatly improve the realism of the virtual room presets, if that's what you're after.
The program is free to try, a "gaming" preset without room measurements has an unlimited demo for a week and costs $25 by itself, the remaining presets can be demod in 2 minute intervals(after 2 minutes you only need to select a different preset and go back to the same one). The license includes 1 preset for $150, and presets are $25, and often goes on sale twice a year for half off.
Unfortunately using a PC is necessary to get the best surround sound except for the Smyth Realiser A16.
The Dspeaker Headspeaker is no longer available, but you still may be able to find demo units or used units. This was the next best option to the Realiser for non pc use. It has an optical input so only lossy(dolby digital ac3 or dts) decoding though. It used modeled algorithms instead of measurements but included a head tracking device and was able to have much better externalization.
-Sony MDR-HW700DS, is a wireless device with hdmi input and can decode lossless audio but is limited to a single pair of headphones and has hdmi 1.4 ports so no full 4k passthrough, however, you can use something like the AVR Key to pass the audio separately to the 700ds' base. The surround sound is good but the externalization not as much. Theres also the optical based DS6500 which performs similar but with less fidelity due to the lossy audio.
-Some gaming sets and dac/amp units have an optical input, can accept dd/dts lossy 5.1, and built in surround processing, like SBX, dts headphone x, etc. With some of these you can at least use a better pair of headphones, however, they won't have the most external of virtual speakers but it will have more surround than a stereo headset.
-Creative is developing the SXFI TV and wireless headphones which should be a better option than what's available for non pc users. https://www.hardwarezone.com.sg/feat...eative-sxfi-tv
If youre more interested in headtracking and anchoring the virtual speakers than measured room imupulse, options include.
Redscape Audio
Waves NX
or the Audeze Mobius
Full system for reference:
Transport: Supra USB, Uptone ISO Regen, Uptone Ultracap LPS 1.2
DAC: Audio GD NFB 7, amanero usb to i2s board with isolator on i2s output.
Amp: Audio GD NFB-1AMP
Power: Topaz 91092-31 Ultra Line noise Isolator
Shaker system: duplicated signal with voicemeter, usb to dac, equalizer, crossover, amplifier, 2 shakers
Headphones: Mrspeakers Alpha Prime, Audeze EL-8, Sennheiser HD650, Hifiman HE-400i, Stax SR-207(with SRM252S energizer)
Additional commentary on equipment at post #100 :
https://www.avsforum.com/forum/378-h...l#post57949110
Melih Pekcan 12-27-2018 07:25 AM
This is a very interesting topic for surround headphone enthusiast.
although im not very familiar with some terms and devices , i subbed to the thread to track further developments.
thanks for sharing and keep up the good work.
bdht 12-27-2018 03:21 PM
If you have any questions feel free to ask.
gorman42 01-04-2019 04:33 AM
Hi! Trying now the free samples of OOYH I'm interested. The beginning of "Money" by Pink Floyd is impressive.
I'm using Beyerdynamics DT-880 and I use the Equalizer APO with satisfaction for my PC desktop monitors (nothing special, some Audioengine small monitors). I own a Umik calibrated microphone but... I'm not sure how I could equalize the DT-880 to flat. How can I measure them?
Being a fan of surround music and a headphone enthusiast, I've always been interested in replicating the experience through headphones so... you have my attention. :)
Sooo... questions:
1) How to make headphones flat? Where do I get the measurements, since I can't use a regular microphone to do that through REW.
2) Does OOYH allow to pre-process sound? I ask this because of portable use. There are parametric equalizers for Android (the platform I use) but the program itself runs under either Windows or MacOS. If I could pre-process stuff, I could then transfer it on my smartphone and have proper multichannel playback on the go (this has been one of my wildest tech dreams since forever). In the FAQ I see they mention Android version coming, but there's no release date.
3) I don't understand if the program allows one to measure one's own room or if you are bound to use the presets provided with it. Which one is it? Reading the website it looks to be the latter, I guess.
Yeah, you are bound to use their presets. Some of them are quite good, though. I'm particularly fond of the Magico Q7 speakers.
4) Apart from the ability to measure one's room and head tracking, is this basically Realiser for $150? Do I get this right? Because having had a look at the presets available, that's the impression I get. Have you ever had the chance to test Realiser, if so how does this compare? Edit: further reading, there don't appear to be Atmos presets, so there's that.
5) Looking at presets, I'd be interested, for reasons expressed above, in buying a 7.1 preset. The question is: what happens when source is 2.0, 4.0 or 5.1? Unless I add extra DSP only the speakers with signal play back, correct? I hope it's like that.
It's like that, I tested with the trial.
bdht 01-04-2019 09:32 AM
Two ways.
1.) Listen to a frequency sweep, most likely the headphones will play fairly flat until 1-2khz, and then rise about 10db, this is the area you want to attenuate.
2.) Several sites have made measurements of headphones, I'm particularly fond of Innerfidelity's. All 3 880s have been measured.
https://www.innerfidelity.com/headphone-measurements
Yes you can use programs to capture the output of OOYH. I personally haven't tried this yet, but I was talking with someone recently who really enjoyed converting the track to DSD after running it through OOYH and playing it back on an Ibasso DX200 and Audeze LCDi4.
I believe the programs he used were IShowU for capture and Audacity, and Xivero XiSRC converter
The measurements for the presets were made using a Smyth Realiser A8.
Correct, it's basically just the convolution engine of the Realiser A8, the Realiser also employs the headphone correction(HPEQ) which is why I eq separately. I haven't had a chance to test the Realiser yet, expensive Dx. I'm hopeful that once the A16 comes out Darin will eventually update the program for Atmos use, the problem currently is that it would need to decode the Atmos track as well which would increase cost with licensing etc. If you can find it, test the Atmos Encounter Demo, height effects render suprisingly well.
Yup, I use this for virtual stereo loudspeaker music listening all the time when I'm at my desktop setups now. There are ways to upmix 2.0 and 5.1 to 7.1, some cheap and average, some complicated and expensive, I tried the matrixing in FFDShows audio filter but didnt find it to convincing.
gorman42 01-04-2019 10:55 AM
Thanks a lot for your replies.
As far as equalizing my DT-880, these are the measurements from the Inner Fidelity website. Problem is I really would not know what to input in APO Equalizer. It was "easy" through REW handling the measurements, as that allowed for outputting a text file that you could feed APO Equalizer. I don't know about going in blindly inputting frequencies and quality values :( Are there any tips for doing this? Sorry if I sound whining, it's not my intention but after listening to OOYH for a while... I'd really like to take advantage of it at its maximum level.
I'll investigate about iShowU alternatives on Windows, no MacOS here. :)
Is Darin Fong connected to Smyth Research? From what you write about Atmos support I'm led to believe so but I might be mistaken in interpreting what you are writing.
I'm perfectly fine with listening 2.0 stuff in stereo, automatic upmixing leaves a lot to be desired. And I have a collection of over 200 albums in real surround to listen to, so I'm ok with this. :)
Just one downside in finding out about this now. I've missed the Black Friday sale. :D
bdht 01-04-2019 11:52 AM
You're welcome! I really enjoy the program and want to share, I always see people asking about headphone surround for movies and this is hands down the best option next to the Realiser.
Not at all. You dont know something until you know it ;] I'd be more than happy to write a couple filters later tonight that you can input and test. The simple jist is use the parametric peaking filters. So when you see the peak on the dt880s at 3.5 khz the filter would be:
Frequency: 3500hz; level: -5db; q factor 2
I tend to use a couple filters at the same level so I can easily turn them on and off to dial the levels in to where I want. So I'll have 2-3 filters every 1000hz starting at 2500hz of about 4db with a qfactor of about 2.5
The lower the q factor the wider the frequency range filtered, the higher the narrower.
I don't believe so, he just wrote(or had someone write) a convolution engine and used the PRIR taken from the Realiser.
In regards to Atmos support, what I mean is currently the only way of decoding Atmos is in an AVR with the built in decoders. On Windows for instance, there's no way of decoding the track and sending a 16 channel pcm track with all of the object data to ooyh, or anywhere else for that matter. The Realiser A16 will take atmos or dts x bitstreams and do all the decoding itself.
Just one downside in finding out about this now. I've mixed the Black Friday sale. :D
You know what, I don't think it happened this year, or I missed it too and there were a few presets I wanted. Dx
bdht 01-04-2019 12:47 PM
2 Attachment(s)
Here's the filters I use on a pair of HE-400is as well as the innerfidelity measurement, and what the EQ looks like after all the filters.
With EQAPO it's nice and easy to hit those power buttons for the filters on and off while listening to music and get it just right. These kind of filters are fairly similar for what I use for different headphones, just different combinations and q factors.
:::Peaking Filters:::
Frequency: 2500hz
Gain: -3db
Q Factor: 3
Frequency: 3500hz
Gain: -3db
Q Factor: 2
Frequency: 3500hz
Gain: -4db
Q Factor: 2.5
Frequency: 4500hz
Gain: -3db
Q Factor: 2
Frequency: 4500hz
Gain: -3db
Q Factor: 2
Frequency: 4500hz
Gain: -3db
Q Factor: 2
Frequency: 5000hz
Gain: -3db
Q Factor: 2
Frequency: 9000hz
Gain: -4db
Q Factor: 2
:::High Shelf:::
Frequency: 8000hz
Gain: -3db
Fixed
gorman42 01-04-2019 02:32 PM
I've already lost you here. Because if I look at the Innerfidelity chart for the DT-880 250ohm I see it doesn't peak at 3500Hz, it's actually down to -5db. It's flat from 400Hz till 1000Hz, then it starts going down, with some up and downs but always below 0db, until 7500 where it has a +3.5 (more or less) at 7500. Am I reading the graph wrong? Or is my reasoning wrong and I should not aim for 0db?
Oh. So he's got an A8 from Smyth and he's using that to create the different presets.
Yeah... as far as I understand it, Atmos does not have discrete channels. The sound is "distributed" among the channels according to speaker placement and calibration. So you are correct, the software should do the decoding and then distribute the sound throughout the "virtual" channels.
You're right. It happened in 2017. In 2018 he did it for CanJam SoCal.
bdht 01-04-2019 03:30 PM
The red graph is compensated . Grey is uncompensated and I find that easier to work with. Mind me asking what they're plugged into? Pc, dac/amp, avr, etc.
gorman42 01-04-2019 04:20 PM
Usually they're connected to the AVR in my signature. RX-A3010, Yamaha. I used to listen to them on a dedicated amp in my office but now that I've moved to home office I've opted for desktop monitors for PC use.
gorman42 01-05-2019 09:21 AM
I hope not to be straying too much offtopic in turning this into a "Equalizer APO How To" but... on desktop I'm more likely to use my run of the mill AKG K450. Experimenting with the Inner Fidelity measurements and Peter's Equalizer APO Configuration Extension (Peace) I "inverted" the frequency response chart from Inner Fidelity and came up with this equalization. I screengrabbed them one on top of the other for your evaluation.
https://imgur.com/oAoiosShttps://i.imgur.com/oAoiosS.jpg
Do point out all the tremendous mistakes I surely must have done. After uploading the picture I realized that I had two 1.000 Hz bands and I eliminated one, while working on the other to come up with a similar result.
What do you think?
https://imgur.com/a/0sgvZwR
bdht 01-05-2019 09:39 AM
Originally Posted by gorman42 (Post 57382122)
What do you think?
It's an interesting thought, but you're boosting the frequencies I'd recommend you reduce. Try just a single peaking filter, 3500hz, -10db, q factor 3.5 to 4.
Or if you're using a graphic eq, you would reduce 3500 hz by 10db, 3000hz and 4000hz by 7db,and 2500hz and 4500hz by 4db.
You typically want to avoid boosting when eqing because it can cause clipping and/or increased distortion. Looking at the grey graph of the K450, the main thing you want to adjust when using OOYH is the peak at 3.5khz.
gorman42 01-05-2019 10:36 AM
Yeah, I have a -16db preamplification applied, to avoid clipping. I'll try your suggestion, I use APO so it's no problem implementing the single filter at 3.500 you suggest.
Tried, as it's fast enough to do. Obviously it sounds a lot different, muddier I'd say... but it's better if I take a break and come back to it later. With the above filters I tried approximating the ideal curve explained on Inner Fidelity as much as possible but maybe I went it the wrong way. Actually, what you kindly define as an "interesting thought" might be an idiotic thing to do. Don't restrain yourself, tell it as it is! I'm here to learn. :)
Actually, if you feel this is too specific or offtopic, don't hesitate to tell me so. Thanks for all the help so far. :)
bdht 01-05-2019 10:56 AM
Originally Posted by gorman42 (Post 57382588)
Yeah, I have a -16db preamplification applied, to avoid clipping. I'll try your suggestion, I use APO so it's no problem implementing the single filter at 3.500 you suggest. Tried, as it's fast enough to do. Obviously it sounds a lot different, muddier I'd say.
The single filter sounded muddier? Muddy usually doesn't refer to that frequency range, darker would be a better description. Just to clarify, the preamp and the other eq were all off and you were using ooyh?
bdht 01-05-2019 10:57 AM
And this might sound silly, but its happened before, did you turn the volume back up to a comfortable level? After eqing 3-4khz down so much its much quieter and you can increase the volume.
gorman42 01-05-2019 11:12 AM
Yeah, sorry. I'm Italian, English is not my first language. So darker might be more appropriate. Yes, I did raise the volume. But no, I wasn't evaluating it with OOYH, just with regular stereo music. I'll experiment some more and come back to you. Thanks again.
bdht 01-05-2019 11:37 AM
Ah k, using that eq without ooyh will sound awful. ;]
gorman42 01-06-2019 06:28 AM
What I'd like to understand is toward what one is supposed to equalize to. I see you state that the Harmon curve shouldn't be followed. Correct? To the Harmon curve one should apply approximately -10db of correction in the area between 2kHz and 4kHz, right?
So for regular "musical" use one should equalize toward the Harmon curve and then have a different APO profile with -10db approximately applied between 2kHz and 4kHz to the regular "musical" profile. Is that what you meant?
bdht 01-06-2019 10:41 AM
Only when using Out of Your Head do I find it necessary to flatten out that 2-5khz peak.
For eqing for normal listening its entirely up to you how to eq the headphones, theres no right or wrong. If you find them to be to bright, try pulling down that same area around 2-4khz by 2-5db, if you find them bass light use a low shelf under 100hz, if you find them piercing/sharp use a high shelf over 8khz.
gihayes 01-11-2019 12:05 PM
Great topic! Subscribing.
Alexious 01-16-2019 07:02 AM
Originally Posted by bdht (Post 57274384)
I'd like to share my experience in building a virtual theater. There's constantly questions about what headphones to use for movies, and everything save for one expensive device that isn't out yet seems rather lackluster. I've used lots of software and equipment and the end result of being able to put on a pair of headphones and have such natural sounding high fidelity external virtualization of a 7.1 loudspeaker is truly marvelous. A front soundstage anchored to the display, clearly rendered and discrete side and rear surround channels, long resolved pans, every bit of the most complex surround movie mixes(looking at you Ready Player One race scene) rendered in full detail over 2 tiny headphone drivers.
For reference, I've tried:
Windows Sonic
Waves NX
Razer Surround
DTS Headphone X
Toneboosters Isone
Flux Hear
Sennheiser GSX
And the Audeze Mobius
1) Using a windows PC, a program called Darin Fong's Out of Your Head, does the surround processing. This program uses a binaural processing engine to convert up to a 7.1 pcm signal to 2.0 binaural stereo, and applies measurements of movie theaters, home theaters, or hifi listening rooms, made using the Smyth Realiser A8.
Since the program is a stand alone piece of software, parts of the Realiser aren't used, like headphone correction. So this must be done manually using something like Equalizer APO, to equalize the headphones to have a flat response. This is very important and something I don't think alot of people do when they try OOYH, and ends up sounding very bright/grating/noisy, but after the EQ, sounds very natural. Of course something like the Audioquest Nighthawks could probably be used without EQ, but anything that follows the harmon curve you'll want to bring 2-4khz down ~10db in some cases and probably roll off over that a bit too.
2) When using these programs, I've found headphones with more responsive drivers render the virtual rooms better. Planar magnetic and electrostatic drivers being the best. Anything with a fast impulse response, little to no treble ringing(good imaging), and low distortion. Open headphones are great in this case for a bigger virtual room size, the HD800 might be the best pair you can use. I personally use a pair of Audeze EL-8s, MrSpeakers Alpha Primes, Stax SR-207, Hifiman HE-400i, Sennheiser HD650, and I also have a pair of Audeze Mobius. The EL8s work best for me with a pad mod(I use the Dekoni LCD Velour pads, they reduce a bit of treble ringing and push the drivers out further), the Alpha Primes muster a nice room size despite being closed, the Stax have scary realism but sound very close(small room size).
3) The digital to analog conversion makes a huge difference in rendering the measurements of rooms. I have several devices I've tried, ranging from the standard motherboard Realtek chip, the dac and headphone out in a Denon X4200W, a JDS Labs ODAC, an Audio-GD NFB-11, and an Audio-GD NFB-7. The NFB-7 is the best, something about the big power supplies are able to render the virtual rooms with size and realism not found in the other equipment.
4) This one seems to be a stretch for some people, and it's not necessary... but digital and power conditioning for devices that don't have it, improves realism further, improves fidelity substantially, and reduces listener fatigue. I use a device from Uptone Audio called the ISO regen, which isolates from the PC, regenerates and clocks the data, an Ultracap LPS which powers the iso regen and the usb to i2s conversion board in the dac, as well as isolating both from the ac mains, and a Topaz Ultra Line Noise Isolator, used to isolate the dac and amp from the ac mains, these were primarily used for scientific measuring equipment in labs. I'll just add in regard to this that before adding these devices I never enjoyed music through OOYH as much as I did listening to the headphones by themselves, but after adding them I use OOYH 100% of the time for music.
5) Add a bass shaker system, a small 20w shaker carefully attached to a chair frame really helps with immersion for special effects. I split the signal coming out of my dac. When properly dialed in sometimes between the shaker and headphones that can play low(20hz) I'll get shocking sub bass hits that feel supringsly natural like actual subwoofers, chest hits and all.
Other options for people not using a PC:
-The Smyth Realiser A16 when it comes out.(the best option)
-Dspeaker Headspeaker, has an optical input and a headtracking device, only lossy(dolby digital ac3 or dts) decoding though(great external virtualization)
-Sony MDR-HW700DS, is a wireless device with hdmi input and can decode lossless audio.(surround sound but not so external virtualization)
-Some gaming sets like the Turtle Beach X41 have an optical input and built in processing.(surround sound but not so external virtualization)
Shaker system: jensen xlr isomax transformers, equalizer, crossover, amplifier, 2 shakers
Great thread. I'm also looking into this very topic and will definitely try Out of Your Head and report back.
However, I wanted to point out another surround sound solution, Nahimic. The interesting part is that it also works with HDMI devices, for instance. The caveat, on the other hand, is that it can apparently be only enabled on MSI and soon Gigabyte motherboards and laptops.
Melih Pekcan 01-16-2019 07:12 AM
I used to have sony hw700ds but sold it ( now regret it ) due to bottleneck hdmi 1.4 hindering 4k hdr on tv and ps4pro.I even bought hdfury vertex but wife found the extra cable troublesome. ( also regret selling it )
Anyways im currently using apple tv 4k and ps4 pro with philips 8602 4k hdr tv.
My goal is to experience apple tv 4k dolby atmos properly , if possible with lossless sound , on a headphone.
Sony hw700ds was very good with dolby prologic ii with good surround sound but in time i found out the bass had been weakened.
I have just bought bluedio victory ( 12 driver bluetooth and optic cable headset ) just to try but on bluetooth it has subpar performance.
I have dolby dimension on my radar but havent got any satisfying review regarding dolby atmos performance on bluetooth.
A16 is not an option being damn expensive unfortunately.
Creative sxfi air comes to mind , sony is told to be working on a new 360 audio format ( coming late september 2019 )
So what options do i have for truly surround pinpoint experience on a headphone for apple tv and ps4pro , im open to suggestions..
bdht 01-16-2019 09:21 AM
Unfortunately, for actual Atmos the only option is the Realiser A16. And when not using a computer the options are very limited and most don't provide great externalization(the hw700ds, and various optical based gaming device). Id recommend the dspeaker headspeaker but since you're using the apple tv that doesnt have an optical out, though it will work with the ps4.
The dolby dimension and audeze mobius are only stereo over bluetooth. Actually as far as I could tell the dimension is stereo all the time and is more of a lifestyle device and not headphone surround sound.
The Creative sxfi uses usb so that wont work for you either.
So ya for the apple tv as far as I know the only option is the hw700ds, if you have an avr with 2 hdmi outputs it may be possible to passthrough the audio on the 2nd output, though I don't have experience with this.
Melih Pekcan 01-17-2019 02:59 AM
Thank you for swift reply.
I guess i will wait till next year to see what sony is planning maybe they update the hw700ds with an hdmi 2.1 headset , lets hope.
This 360 audio didnt seem promising to me tbh , with all binaural microphone and ear shape calculations , it seems really hard to standardise..
anyways i will be on follow , great thread and topic /cheers.
bdht 01-17-2019 09:01 AM
Actually, the personal measurements are more for 100% accurate placement. The most important thing for externalization and a natural sound is that an actual room is measured and the headphone is corrected, but it doesn't have to be with your own head. For instance Waves NX and the SXFI have values you can input for your head size or ear shape, and this provides accurate placement of the virtual speaker locations, which is most useful for gamers. When using OOYH, which uses someone elses PRIR, if say the center channel is rendering to the left a bit, you can correct this by loweing the left channel output volume and/or increasing the right. But Waves and other programs that use a first reflection algorithm don't sound as natural or spacious as OOYH.
The problem you're running into and many others is that a PC is necessary or you have to spend $2-4,000
valley_nomad 01-22-2019 04:55 PM
Actually most of it is already standardized:
https://www.sofaconventions.org/medi...for_Acoustics)
FLIR 01-24-2019 06:47 AM
I'd like to share my experience in building a virtual theater. There's constantly questions about what headphones to use for movies, and everything save for one expensive device that isn't out yet seems rather lackluster. I've used lots of software and equipment and the end result of being able to put on a pair of headphones and have such natural sounding high fidelity external virtualization of a 7.1 loudspeaker system is truly marvelous.
Windows Sonic
Waves NX
Razer Surround
DTS Headphone X
Toneboosters Isone
Flux Hear
Sennheiser GSX
Audeze Mobius
A very good thread!
I have also tried most of the VSS software/devices you listed (except for the Dspeaker headspeaker, Flux Hear and TB Isone).
All those solutions have the same problem:
They do not use your personal HRFT. Other HRTFs and statistically averaged HRTF data can never sound correct over headphones.
OOYH has the same problem: the HRTF data is inherently contained within the PRIR loudspeaker measurement data. The PRIRs of OOYH contain the HRTFs of other people, not the HRTF of the user.
I have bought so many devices over the years (even a Beyerdynamic Headzone) and have come to one conclusion: I will never buy another VSS device, if it does not support "personal HRTFs".
The Realizer is too expensive at the moment and has too much pro features - hopefully they will release a home/entertainment version before the year 2030. :)
I will try the hybrid solution of the SXFI Amp soon (a photo based "personal" HRTF calculation)... but my expectations are not too high...
bdht 01-24-2019 10:41 AM
21 Attachment(s)
Actually! What you're experiencing I believe is a "double HRTF", as the Realiser puts it, when describing their HPEQ(Headphone Equalization). The lack of headphone correction causes harshness in the 2-6khz region, or a thin sound, is this correct? In tinkering with all these various hrtf convolution options, I've found that the personal measurements mostly affect accurate placement and I haven't experienced a colored response due to using someone elses PRIR, the headphone correction I use for a specific set of headphones ends up being the same through various HRTF on OOYH, Waves, etc. With the Mobius using Waves NX(with the head measurements set in the app) and the headtracking, I get extremely accurate placement of the virtual speakers, but it's a much smaller room and not as natural and spacious sounding as using OOYH, which may have the front stage shifted to the left a bit(this at least is easily corrected by resucing left channel volume) or the rear left surround is more towards the center(not so easily corrected but not distracting with movies). The Realiser is the only solution with built-in headphone correction.
I'd highly suggest giving OOYH another try and using Equalizer APO to flatten out the response. I've attached some examples of the EQs I use for various headphones.
FLIR 01-24-2019 11:46 AM
Originally Posted by bdht (Post 57492696)
Actually! What you're experiencing I believe is a "double HRTF", as the Realiser puts it, when describing their HPEQ(Headphone Equalization). (...)
Thank you for the detailed reply!
I have used OOYH a year ago and tested different presets in a computer game with good directional sounds at different distances. I liked the the sound quality and the low latency. But I always have the "feeling" that the VSS, the "externalization", could be better. I have heard some good binaural recordings years ago and since this moment I am kind of obsessed to get that kind of quality for movies and games.
At the moment I have a very simple setup: I use just the Equalizer APO and some settings to "real-time-convolve 7.1 input sounds down to binaural stereo audio for headphones" (see [1])
But I will try OOYH again with your setup: It looks very promising...
I ordered a SXFI Amp this week, and will try that next week. After all the VSS devices and software, I would really like to finally find something with very good sound quality and an easy setup for PC, PS4 and an UHD-Player...
[1]
https://sourceforge.net/p/equalizera...imit=25&page=0
It includes (you can instantly switch between):
Dolby Atmos Headphone
CMSS-3D
SBX Pro Studio Surround (also found in BlasterX Acoustic Engine & THX TruStudio Pro)
Dolby Headphone
Sennheiser GSX Binaural 7.1
DTS Headphone:X
Windows Sonic Headphone
Dolby Home Theater v4 Headphone Surround Virtualizer
Razer Surround
Out Of Your Head Preset
Flux HEar V3
There is a second solution but I did not try it yet: https://sourceforge.net/projects/hesuvi/
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
