The Difference Between Cheap And Expensive Earphones - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-29-2019, 12:49 PM - Thread Starter
Liked: 1
Send a message via Skype™ to rahman tutul
Whether there is any difference between cheap and expensive earphones is actually a very tricky question to ask. Tricky because some might say that there is no difference between the two at all while for some the difference might be remarkable. As is obvious from the question itself, the one big difference between the two is surely the amount that is needed to own them. But apart from that, here, it is important to understand and analyze the other points on the basis of which the earphones can be differentiated and are priced differently.
Sound Created:
It is obvious that the earphones that cost more produce high-end audio quality as compared to the other budget and cheap earphones that are available in the market. The expensive earphones will have crisp and exact sound with a high level of clarity. They reflect the true soul of the music in its most natural form. Their higher resolution allows the audio to exhibit rich, excellent tone. While listening to music in these expensive earphones, you may have the feeling of sitting through a real live orchestra; such is the audio quality of these earphones. Once getting used to listening to your favorite numbers in a superior earphone, it might not be possible to switch to an inferior quality earphone. But, of course, low cost always doesn’t necessarily mean low audio quality. There are many earphones that are known for their good audio quality and are also affordable. So, it is important to know your taste and budget before finalizing on an earphone.
Design, Comfort, and Durability:
The high-end earphones are engineered to display great precision and are driven to provide maximum comfort and pleasure to the listeners. Long-lasting durability is another added beneficial aspect of these high priced earphones. They are manufactured with great care and the best material goes in their making as the reputation of the manufacturers is extremely important. Also, their styling is done in great details to assure both sophistication and comfort for the users. Most of them are easily wearable with great ease and comes with round the neck handy wire to protect the device against fall. Also, some are foldable and easily packable so carrying them is very simple. They do offer great comfort to ears as their fit is perfect and provides for great noise cancellation. Thus, design-wise and in terms of other physical elements, the expensive ones offer much more as compared to the loose fitted easily damageable cheap ones that are available in the market. But here, it is possible that you can get very good cheap earphones with comparatively higher durability and better design as compared to the other earphones within the same price bracket. Thus, a little involved study and analysis are required before making the final purchase.
Other Factors:
The expensive earphones generally offer great compatibility and mobility and are ideal for wireless connectivity without any fall in the audio quality. While cheap earphones offering wireless connectivity is also available, but their frequency stability and variation might vary hugely when compared to the expensive one. Also, most of the expensive earphones come with great warranty and also are sweat and water-resistant. The accessories provided with the expensive earphones also speak of high quality and makes the overall experience more worthy. The manufacturers provide the best thoughtful accessories to help the customers indulge in the sheer pleasure of melody and sound. All these different factors actually help to differentiate a good earphone from a bad one and here price is sure to play a vital role.
However, it is important to say here that in spite of the obvious differences among the expensive and the ordinary earphones, the ultimate difference lies in the mind of the buyers. Because, it is very true that what might seem to be expensive to someone, might be cheap to others and vice versa. So, it is always required to understand the self-requirement and match it with the perfect price bracket to make the best purchase so far as earphones are concerned.
rahman tutul is offline
post #2 of 2 Old 09-01-2019, 01:58 PM
Liked: 0
It would be good to set the 'exepnsive earphones' line somewhere. What kind of money are we talking here?
Dave Grohl is offline
Reply Headphones
