Finding the right pair of Bluetooth Headphones - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Worf
  • 1 Post By MIX_MASTER_ICE
post #1 of 9 Old 09-13-2019, 07:00 AM - Thread Starter
Liked: 0
I need help finding some Bluetooth headphones and the last pair I was using would skip out on the music ever so often on my IPhone 6 and skipped using the noise canceling also and I am looking for a pair that is under 100 dollars and has noise canceling and connects by Bluetooth. What do you recommend
Steven Cooley is offline
post #2 of 9 Old 09-15-2019, 08:20 AM - Thread Starter
Liked: 0
Does anybody have any recommendations and I don’t understand how does 40 people view but none comment at all
post #3 of 9 Old 09-15-2019, 10:33 AM
bdht's Avatar
Quoted: 277 Post(s)
Liked: 107
In ear, on ear, or over ear? Music preference, sound signature preference, i.e., bassy, natural, or boosted treble?
bdht is offline
post #4 of 9 Old 09-15-2019, 10:55 AM
bdht's Avatar
Quoted: 277 Post(s)
Liked: 107
what do you need the noise cancelling for? for very good noise cancelling you usually need to go up to the sony and bose, you may be able to find used or refurbed pairs for under 100
bdht is offline
post #5 of 9 Old 09-16-2019, 12:19 AM
Worf's Avatar
Quoted: 838 Post(s)
Liked: 567
If you wanted stupid recommendations then say so. If you want intelligent recommendations then people will see your post, decide they cannot contribute anyone useful and close it. Others are reading because they may have the same question and see what people have responded.
Lots of reasonable reasons why people view a thread but not comment.
rahman tutul likes this.
Worf is offline
post #6 of 9 Old 09-16-2019, 11:50 AM
Liked: 1
Send a message via Skype™ to rahman tutul
Just type in google "under $100 headphone" you will get a lot of recommended. Also, you can check Mpow brands.
rahman tutul is offline
post #7 of 9 Old 09-18-2019, 02:34 PM
MIX_MASTER_ICE's Avatar
Quoted: 2668 Post(s)
Liked: 2477
Most ANC headphones under 100 bones don't fare too well at this feature. One headphone I have tried that actually does ANC fairly well for a low price is the MPow H12. The headphones actually sound a little better with ANC on, which is usually not the case for budget headphones. These go for around $40 on Amazon and I would recommend them. The negatives, which you know there have to be some, would be they don't go as loud as some similar headphones and the bass isn't the strongest. I've yet to have any Bluetooth issues with the H12, but I use an Android phone.
https://www.amazon.com/Mpow-Cancelli...gateway&sr=8-3
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB32,XB31. Sennheiser HD58X, HD4.50, PC37X. Philips SHP9500. SIVGA SV004. Status Audio HDTwo. HyperX Cloud PS4. TB Elite Atlas Aero. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
MIX_MASTER_ICE is offline
post #8 of 9 Old 09-18-2019, 07:51 PM
Liked: 1
Mpow H10 updated version and nice ANC https://bestwirelessbluetoothheadpho...udio/mpow-h10/
post #9 of 9 Old 09-19-2019, 06:36 PM
Quoted: 112 Post(s)
Liked: 68
I would ignore ANC at that price point. Go with a pair of AKG YT50BT. I use these on flights every week. No issues with plane noise or crying babies.
https://www.whathifi.com/akg/y50bt/review
They are on-ear, comfy for about 3 hrs and then a little less so for the rest if you’re on a long stretch, but I have small ears so depending on fit, you mind find them comfy for longer.
Music sounds great, movies sound unreal. Good balance of clarity and bass, not clinical at all and not muddy.
Main 7.1 HT: Dali Zensor (7s, Vokal, and 1s), Emotiva E2s, HSU ULS-15 MK2, Emotiva BasX preamp/amps (MC-700, A-300, A-500)
Kid’s 5.1 HT: Dali Oberon (5s, Vokal), RSL C34Es, HSU VTF-2 MK5, Denon X2400H
7-Zone CCA/Spotify WHA: Paradigm (E-80Rs x6, P-80SM), Def Tech AW6500s, Polk MC-80, Emotiva BasX amps (A-700, A-500), FiiO D3 DACs
Spectah is offline
Reply Headphones
