Broadcast headset - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-24-2019, 04:45 AM - Thread Starter
paza's Avatar
Liked: 2
Broadcast headset
Hello,
On my job, I organize many webinars and online conferences so mic quality is essential. Since I also move from my chair (sometimes even standing), I cant use tabletop microphones.
Finally, the environment where I work is not always quiet which requires dynamic instead of the condenser mic.
I saw a couple of over the ear models which could be interesting please share your experience if you used any of them, or if you recommend any other model for broadcasting/podcasting.
I want to emphasize that this is going to be connected to my PC and I would need a separate audio interface (additional cost) and in the case of Sennheiser and Beyerdynamic even the main cable (sold separately from the headset). So which one of this bellow would you buy (or any other recommendation)?
1. Audio-Technica bphs1
2. Sennheiser HMD-300 Pro
3. Beyerdynamic DT-790
HTPC
Asrock Killer Sli Z370, 9900k (5 Ghz OC), EVGA RTX 2070 Super (OC 150 core,500 Memory), Yamaha active monitors 5
BenQ PD2700U 27 inch 4K UHD IPS Monitor
paza is offline
Reply Headphones
