SONY MDR-XD100 -- need amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-27-2019, 10:30 AM - Thread Starter
Liked: 0
So I have SONY MDR-XD100 headphones, which I use to listen to classical music on my PC. I just plug them straight into the audio jack. Question is whether the sound will be significantly improved by a headphone amplifier? If not, something else? Classical music tends to be pretty quiet, especially some of the old recordings, so I turn up the volume, and the sound often comes out distorted at the higher volumes.
What's recommended?
I didn't spend a lot for the headphones, so I don't want a high-end amplifier. I am looking for a budget-friendly way to improve (not perfect) my sound quality.
Suggestions are welcome, and if my quest is in vain, just say so...
Shmuel is offline
post #2 of 4 Old 11-27-2019, 10:45 AM
eljaycanuck's Avatar
Quoted: 1951 Post(s)
Liked: 2748
Sounds like there might be an issue with the headphones. Can you test with a different set?
If it's not the headphones but, say, the jack on the soundcard, you could try something like this mini-amp:
- digital audio out from PC to amp; and
- headphone out from amp to your ears.
eljaycanuck is offline
post #3 of 4 Old 11-27-2019, 01:40 PM - Thread Starter
Liked: 0
I tried with some cheap earbuds, and it's louder, but that's to be expected with earbuds, as opposed to over-the-ear headphones, as far as I know.
The low volume is typical of some of the old non-digital recordings of classical music performances from way back.
So what's the deal with DAC? I don't need it?
Shmuel is offline
post #4 of 4 Old 11-27-2019, 03:23 PM
Liked: 2748
Your PC's sound card has a built-in DAC (digital-to-analog(ue) converter). A better-quality DAC might improve the sound quality but it's unlikely to resolve the issue of distortion at higher volumes (unless that issue lies somewhere in the sound file --> DAC --> headphone jack path on your PC's sound card).
Reply Headphones
