Tip Advice: FiiO F9 Pro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-29-2019, 01:12 PM - Thread Starter
Thrill Killer's Avatar
Quoted: 76 Post(s)
Question Tip Advice: FiiO F9 Pro
I have a pair of F9's. They're my Commute pair. But, the dang tips come off almost every time I take them out. So now I have to reach in and make sure I grab the tips as I remove my F9's.
Are there any After Market tips that will have a better fit on the sound tube.? And, offer a better sound isolation?
PS: I use the Foam Tips as I like as much isolation as possible.
McIntosh C34V, MC2205, Martin Logan Motion 40's, SVS PB-1000, Technics SL-1200MK5 w/Nagoka MP-200, Topping D50, Magni 3, Macbook Pro w/Music in ALAC
Thrill Killer is offline
Reply Headphones
