Bluetooth Headphone Recommendation (lost my Bose bose soundsport dynamite) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-09-2019, 06:28 PM - Thread Starter
wacki's Avatar
I listen to podcasts 80% of the time and music 20%. Even though it's mostly podcasts I still need clarity.
I was using a Bose soundsport dynamite and liked it. But I lost it. Got any recommendations for a replacement? Looking for something similar quality but different. I'm sure there more economical options than bose. Plus I just want to try something different.
Any help would be awesome. Thanks!
wacki is offline
post #2 of 3 Old 12-10-2019, 07:30 PM
Pete7874's Avatar
Quoted: 364 Post(s)
Liked: 245
Soundcore Liberty 2 Pro are currently on sale on Amazon for $110. Regular price is $150.
They're good sounding TWS, as long as they fit your ears, but that you'll have to try for yourself.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Samsung UN55B7100  Denon AVR-S740H  Chane A2.4  Dayton MK402X  Premier Acoustic PA120  Roku Premiere Plus  Squeezebox Classic  CCA
Pete7874 is offline
post #3 of 3 Old 12-15-2019, 07:18 AM
Liked: 0
unfortunately brother you just lose the best one
urswexner236 is offline
Reply Headphones
