Any Bass on any wireless earbuds? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-23-2019, 02:41 PM - Thread Starter
JackB's Avatar
Quoted: 1589 Post(s)
Liked: 382
I have tried a JLabs wireless earbud and though it feels and works fine there is no bass to speak of; even with their digital enhancements turned on and the iPhone bass booster turned on. Are there any earbuds that have some bass? I know that my eight year old 1.5" wired headphones which have the circular around the ear hook have bass. However, I can't find any of these because they have all been obsoleted, as far as I can tell, by the ear bud style.
Jack
JackB is offline
post #2 of 10 Old 12-23-2019, 04:10 PM
Quoted: 96 Post(s)
Liked: 123
Try something from SoundPeats like the TrueEngine SE. Using memory foam tips also helps with the seal in your ear and enhance the bass a bit.
Projector: Epson Home Cinema 2100; Receiver: Sony STR-DN1080; Speakers: Monitor Audio Controlled Performance Inwalls and Inceilings; Subwoofer(s): SVS PC-2000; Bluray Player: Sony BDP-S6500; Remote: Simple Controls; Cables: Monoprice
rnatalli is offline
post #3 of 10 Old 12-23-2019, 08:09 PM
usc1995's Avatar
Quoted: 441 Post(s)
Liked: 297
The Powerbeats sound pretty good and they are currently clearing them out at BestBuy now that the new ones are out. I bought a set for the gym and am pretty happy with them https://www.bestbuy.com/site/beats-b...?skuId=5577821
usc1995 is offline
post #4 of 10 Old 12-23-2019, 08:10 PM
usc1995's Avatar
Quoted: 441 Post(s)
Liked: 297
Forgot to add they have the ear hook you are used to and come with multiple sizes of tips to help you get a good seal.
usc1995 is offline
post #5 of 10 Old 12-24-2019, 10:09 AM - Thread Starter
JackB's Avatar
Liked: 382
After more efforts trying to get my JLab's to sound right I gave up and ordered a pair of Besign SHO3s from Amazon. They are similar to the on the ear foam covered ones I mentioned earlier. A fuller sound I'm hoping and more comfortable for me. Cheap too at only $25. One question. They are 4.1 Bluetooth, not 5.0. What do I lose in the .9 difference?
Jack
JackB is offline
post #6 of 10 Old 01-01-2020, 06:58 PM
IvoZee's Avatar
Quoted: 12 Post(s)
Liked: 4
Hope this answers your question about the Bluetooth versions. https://www.amarinfotech.com/wp-cont...-Bluetooth.jpg
How do you like your Besign SHO3's? I'm looking for earphones/buds for the gym that have some bass but are not too expensive.
IvoZee is offline
post #7 of 10 Old 01-01-2020, 08:16 PM - Thread Starter
JackB's Avatar
Liked: 382
How do you like your Besien SHO3's? I'm looking for earphones/buds for the gym that have some bass but are not too expensive.
I sent them back as they are not what I thought they were. I thought they were the kind where you looped the stem over your ear foe a secure fit. In fact the stem loop is like a vertical springed connector between the two speakers. It squeezes the phones to your ears and is very uncomfortable. No thanks.
Jack
JackB is offline
post #8 of 10 Old 01-01-2020, 10:47 PM
IvoZee's Avatar
Quoted: 12 Post(s)
Liked: 4
Fair enough. I think I'm going to go with one of the Sennheiser wireless earbuds. They were always good for for the sound quality.
IvoZee is offline
post #9 of 10 Old 02-02-2020, 08:25 AM
Liked: 2
I have the Tranya T3 and B530 that I use for the gym and train commuting. They are not flawless but for the price they provide an excellent value, base response, and isolation.
Ace of Spades is offline
post #10 of 10 Old 02-02-2020, 12:34 PM
Liked: 2
Does anyone know how the Sony WF-1000XM3 do with bass?
pring789 is offline
Reply Headphones
