Why is a flat frequency response desired for speakers but not headphones? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-25-2019, 07:51 PM - Thread Starter
goldark's Avatar
Quoted: 321 Post(s)
Liked: 86
Exactly as the title asks. I know for speakers, there are a standard set of measurements which correlate highly with sound quality and a flat an-echoic on-axis frequency response is one of them.
Why don't headphones follow the same standard?
For example, a long time standard for headphone neutrality would be the Sennheiser HD600 but the frequency response is anything but flat: https://www.rtings.com/headphones/1-3-1/graph#325/3182
Can anyone explain why this is?
goldark is online now
post #2 of 4 Old 12-25-2019, 07:55 PM
blue 72's Avatar
Quoted: 46 Post(s)
Liked: 36
Basically, because they sit so close to your ear, the proximity/geometry of the ear changes the way your ear handles certain frequencies. In order to achieve neutral response that close to your ear, a completely different frequency response curve is needed. The curve is not flat, but when it's on your head, it can sound flat.
TCL R615 | Sony UBP-X700 | Integra DTR-7.8 | Front = Klipsch KLF-20 | Center & Surrounds = Klipsch KG 5.5 | Subwoofers = 2x sealed Velodyne ULD-15 and 6x ported subs with miniDSP 2x4
Large JBL cinema horns under construction and testing.
"The more to the right it is turned, the greater the volume."
blue 72 is offline
post #3 of 4 Old 12-25-2019, 08:44 PM - Thread Starter
goldark's Avatar
Quoted: 321 Post(s)
Liked: 86
Thanks for the response! That makes sense. So because everyone's ears are a little different does this imply that different headphones may sound more neutral to each individual?
post #4 of 4 Old 12-26-2019, 04:25 PM
blue 72's Avatar
Quoted: 46 Post(s)
Liked: 36
Start here:
https://www.innerfidelity.com/headph...ents-explained
blue 72 is offline
Reply Headphones
