Sony BDP-S350 low volume via headphones RCA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-18-2020, 09:32 AM - Thread Starter
Liked: 0
Hi, i've setup an old Sony BDP-S350 blu-ray player recently, and i decided to use a pair of headphones (30 ohm inpendence) for it, and i'd rather not go buying an expensive pair of speakers, however i've noticed no matter what settings i change via the audio menu, the volume is low, i'm thinking it's the blu-ray player's soundcard being old.
Via my PC the sound is alot louder so i assume once again, sound card.
To combat this, i'm thinking of getting a headphone amplifier (Mackie HM4 or LD Systems HPA4) to boost the volume up to normal levels, cause the bdp-s350 is a really good blu-ray player, and i'd rather not buy another one.
Any advice on this guys ? should i go with an amp ?
trggog is offline
post #2 of 8 Old 03-19-2020, 02:55 AM
Roseval's Avatar
Quoted: 79 Post(s)
Liked: 50
RCA is not suite to drive headphones.
Better get a headphone amp
Roseval is offline
post #3 of 8 Old 03-19-2020, 03:01 AM
glangford's Avatar
Quoted: 813 Post(s)
Liked: 715
Yes, a headphone amp. I'd look at Schiit headphone amps. Here's one for 99 bucks the Magni.
https://www.schiit.com/products/magni-1
Or even a cheaper one from monoprice with a USB dac.
https://www.monoprice.com/product?p_id=11567
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #4 of 8 Old 03-19-2020, 09:23 AM - Thread Starter
Liked: 0
[quote=glangford;59386128]Yes, a headphone amp. I'd look at Schiit headphone amps. Here's one for 99 bucks the Magni.
I'm in australia, and the Schiit magni 3 is $260
I'd rather go for a much cheaper headphone amp, like the Mackie HM4 (look up on DJCity AU) or LD Systems HPA4 (look up on DJCity AU)
which out of those two would be the best ?
trggog is offline
post #5 of 8 Old 03-19-2020, 09:28 AM - Thread Starter
Liked: 0
Well in order to use the amp, since the BDP-S350 dosen't have any headphone jack, or usb ports, i'd have to use RCA to 3.5mm cable into a 1/4 inch adapter into the amp, then a 1/4 inch adapter into my headphones, that's the only setup i can think of, would that be good ?
trggog is offline
post #6 of 8 Old 03-19-2020, 01:22 PM
Roseval's Avatar
Quoted: 79 Post(s)
Liked: 50
I assume the BDP-S350 hase line out (RCA)
Connect these to the RCA in of a headphone amp.
Roseval is offline
post #7 of 8 Old 03-20-2020, 02:22 AM
glangford's Avatar
Quoted: 813 Post(s)
Liked: 715
It does, I checked yesterday. RCA out to RCA in of a headphone amp.
post #8 of 8 Old 03-20-2020, 02:30 AM
glangford's Avatar
Quoted: 813 Post(s)
Liked: 715
You live in australia. I don't know if they are cheaper there than here, but Burson Audio is made down under. The Fun is 199-245 US dollars depending on op amp chosen, I'd assume it's cheaper there. I've never heard of the headphone amps you mention. I have the Burson audio Soloist MKII. it was 499 and a great headphone amp.
Reply Headphones
