Headphone/amplifier interference - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-04-2020, 10:38 PM - Thread Starter
Adam-JM's Avatar
Liked: 1
Hi guys, just wanted to see if anyone has any suggestions here. I have just today started experiencing interference with my headphone/amp/dac. It's pretty much a repetitive ringing/humming kind of noise in the left ear.
I have just spent hours trying to fix this including trying different headphones, 3 seperate amps & 2 different DACs connected to each other with RCA & then into my TV via optical. The problem mainly seems to be on my Xbox One when the volume is turned up high but seems to disappear or at least lessen significantly when I switch over to PS4. I also tried 2 different Xbox consoles & it happened on both of them.
I have been using this same setup for ages with no problems but all of a sudden this interference appeared & I'm at a loss on how to get rid of it. Thanks in advance for any help. ✌️
Adam-JM is offline
post #2 of 5 Old 04-04-2020, 10:48 PM
torii's Avatar
Quoted: 4363 Post(s)
Liked: 2527
recheck your settings...bitstream/pcm, etc...
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is online now
post #3 of 5 Old 04-04-2020, 11:51 PM - Thread Starter
Adam-JM's Avatar
Liked: 1
Yeah I tried that. I can only set it to uncompressed stereo as I don't have a surround system hooked up.
Have not changed any settings or devices & the interference pretty much started for no reason. Not sure if using a ground loop isolator or possibly a fully balanced DAC would make a difference.
It's not just a normal hum either, more like a 'ping' sound that repeats over & over in the left ear only. Very strange.
Adam-JM is offline
post #4 of 5 Old 04-04-2020, 11:58 PM
torii's Avatar
Liked: 2527
make sure rca's plugged in all the way...idk, if not settings or cables...maybe something is broken.
torii is online now
post #5 of 5 Old 04-05-2020, 12:03 AM - Thread Starter
Adam-JM's Avatar
Liked: 1
The noise only appears when I plug in the white (left) side of the RCA cable to the amp. The right side sounds totally fine. I have also tried 2 different RCA cables to make sure that wasn't the problem.
I have done my best to eliminate different variables including plugging in other amps & DACs but all of them are exhibiting this issue which is what has me stumped.
Adam-JM is offline
Reply Headphones
