Recommendations for running Ear Buds - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-23-2020, 07:54 AM - Thread Starter
Liked: 0
Question Recommendations for running Ear Buds
Hi - I've been using some Anker bluetooth headphones for running - (Amazon UK ASIN number B01N6DC2ZE)
I'm now on my 3rd set as after a period of time (roughly 4-6 months), each set has stopped charging. Anker have, so far, sent me a replacement set. But I'm getting a bit fed up with them to be honest.
So, can anyone recommend similar Bluetooth earphones that they have used for a long period (minimum 12+ months, ideally much longer) where the battery has continued to work (ie, charge up ok AND hold charge for what they are supposed to). I'm not looking for audiophile quality (and in fact I am not convinced you can get that good a quality anyway from small earbuds, especially whilst running).
Right now it is important that they sound OK, but more importantly, the battery holds charge when it is charged and lasts for many runs and recharges.
I am wondering whether there is a limitation to the quality of the necessarily such small batteries these items inevitably are built with?
Cheers
Nycoy
nycoy is offline
post #2 of 2 Old 04-24-2020, 08:46 PM
Quoted: 14 Post(s)
Liked: 25
For running, it is better choose earbuds which features water-resistance and comfortable to wear.
Vankyo is offline
Reply Headphones
