Which over the ear headphones?? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Ovation
post #1 of 8 Old 05-02-2020, 12:41 PM - Thread Starter
Quoted: 161 Post(s)
Liked: 9
Hi, im looking to change my headphones. Now i have a creative aurvana live 2. My budget its up to 200u$s. I want over the ear and closed ones.
Which do you recommend? Its a good upgrade going for the audiotechnica 40x? Or the beyerdynamic 770 (80 ohms)
I will use it with my phone lg g7 and tidal (mqa)
Enviado desde mi LM-G710 mediante Tapatalk
Trunksleo is offline
post #2 of 8 Old 05-06-2020, 06:37 PM
Smokey B's Avatar
Quoted: 13 Post(s)
Liked: 9
I've had the ATH-M50X for a few years and really like them. Still under $200.
Smokey B is offline
post #3 of 8 Old 05-21-2020, 09:55 AM - Thread Starter
Quoted: 161 Post(s)
Liked: 9
Some people told me that has a heavy bass and they recommend me the 40x
post #4 of 8 Old 05-22-2020, 06:14 PM
Smokey B's Avatar
Quoted: 13 Post(s)
Liked: 9
Neutral sound
They're generally praised for having a very neutral sound. Lots of musicians use them for recording. I was able to demo a pair at a local Guitar Center, so...if you have a music store locally you could see if they're in stock and give them a try.
For what it's worth, I don't listen to much hip hop or bass heavy stuff. Mostly classic rock, R&B and singer/song writer. If you're more hip hop than maybe my opinion isn't a good one. No worries though, you do you.
Smokey B is offline
post #5 of 8 Old 05-22-2020, 06:23 PM
torii's Avatar
Quoted: 4416 Post(s)
Liked: 2596
I own a bunch of headphones. comfort needs to be a top priority. my most expensive headphones are heavy and hard to listen for more than a hr.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #6 of 8 Old 05-30-2020, 12:38 AM
robe619's Avatar
Under $200USD you can't go wrong with the Phillips Audio Fidelio X2HR or the Drop Sennheiser 58X Jubilee.
robe619 is offline
post #7 of 8 Old 06-02-2020, 09:01 PM
Liked: 4
That Drop 58X is very good. I dont own them but have put some hours on it at a friends house.
nreeque is offline
post #8 of 8 Old 06-03-2020, 07:05 PM
Ovation's Avatar
Quoted: 196 Post(s)
Liked: 182
I second (or third?) this recommendation. I own the 58X and I consider it my most versatile headphones (out of my eight pairs, most of which are more expensive). I have some that are better at specific tasks but if I were forced to pick only one of my headphones and get rid of the rest, I'd keep the 58X.
nreeque likes this.
Ovation is offline
Reply Headphones
