Looking for 3.5 mm headset & microphone A/B switchbox - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By tbook
post #1 of 3 Old 05-13-2020, 07:42 AM - Thread Starter
Edil's Avatar
Hello,
As many other people I'm working from home. I have the typical inexpensive headset with microphone that I use with my smartphone and my laptop and that's the problem, I have to constantly disconnect the cable from the computer to connect it to the smartphone back and forth. I had search without success for an A/B switchbox like these ones; option1, option2, but those only works for the headphone sound and do not work for the microphone. I'm looking for an inexpensive, nothing-fancy, analog switchbox that works for both things at the same time, receive the sound and send the microphone signal. Perhaps a simple cable splitter can do the trick but again it have to work with both things.
Any ideas?
Edil is offline
post #2 of 3 Old 05-13-2020, 09:09 AM
tbook's Avatar
Quoted: 38 Post(s)
Originally Posted by Edil View Post
Hello,
Any ideas?
This?
https://www.doukaudio.com/2-way-micr...tor-p0160.html
Edil likes this.
tbook is offline
post #3 of 3 Old 05-13-2020, 09:22 AM - Thread Starter
Edil's Avatar
tbook thanks!
That will definitively do the trick.
Very good.
Edil is offline
Reply Headphones
