STAX SR-009S - need advice on setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-24-2020, 03:01 PM - Thread Starter
nigeltufnel11's Avatar
I am going to buy the STAX SR-009S earspeaker, but am a novice in the high-end audio world, and need some advice selecting a full setup (amp + preamp) that won’t limit the performance of the SR-009S.
My reason for this purchase is that I used to have a STAX SR-L500mk2 with an SRM-252ii amp, hands-down some of the finest products I’ve ever owned. I absolutely loved the unique STAX sound signature. I have been meaning buy a new STAX product for some time.
My former setup:
Headphones: SR-L500mk2
Amp: SRM-252ii
Preamp: Integra DHC-40.1
Planned new setup:
Headphones: SR-009S
Amp: SRM-007Tii, or SRM-D50
I would like to avoid spending ~$6000 on an amp unless it is truly necessary to maximize the performance of the SR-009S. If I can get 90% of the way there with a more reasonably priced product that would be preferable. Hopefully the 2 options I listed above would be sufficient.
I also want to make sure my pre-amp is not a limiting factor. I’m hoping that won’t throttle performance somehow. I believe an advantage of the SRM-D50 amp would be that I could bypass the need for a pre-amp? Not sure, help very much appreciated, I’m leaning toward the SRM-007Tii if the setup above would work.
Usage will be for music, movies, games, connecting to a PC and PS4.
Thank you in advance for any advice.
nigeltufnel11 is offline
post #2 of 2 Old 05-24-2020, 03:02 PM - Thread Starter
Here are the specs for my pre-amp:
http://www.integrahometheater.com/Pr...urce=prodClass
Reply Headphones
headphone amp , headphones , pre-amplifier
