best desktop DAC+Amp? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By tbacos
post #1 of 9 Old 06-02-2020, 04:53 PM - Thread Starter
Quoted: 87 Post(s)
Liked: 26
Hi guys. I'm looking for recommendations for the best desktop DAC + Amp to use for headphones. I just bought a pair of Sendy Aivas that I'm looking to pmsend more power to. I've watched reviews on the $500 Monolith 124459 THX AAA as well as the $600 Topping DX7 pro. I'm willing to spend some $$, but I really don't want to go with something that requires more than one box. I'd like Bluetooth, but more as a tie breaker than a requirement.
Are there other options besides the above-mentioned that you would recommend? Have you tried either of the above with similar headphones?
Thanks!!
tbacos is offline
post #2 of 9 Old 06-02-2020, 05:42 PM
Hoary's Avatar
Unfortunately, there is no best, there is only best for you.
I've got RME ADI-2 DAC. Besides being one of the best DAC + headphone amp it has a lot of additional functionality built-in. For example, it has 5-band EQ which allowed me to compensate flaws of my new Senn HD6XX. It's not cheap, ~$1000-1200 depends where you get it from. But to me it was worth it.
Some info about it was posted here:
https://www.avsforum.com/forum/173-2...-big-boys.html
Hoary is offline
post #3 of 9 Old 06-02-2020, 07:58 PM - Thread Starter
Quoted: 87 Post(s)
Liked: 26
Thanks Hoary. I'm new to this stuff so I really appreciate the advice. Do you find the RME to output enough power to drive your headphones at pretty high volumes? I'm returning a much lower price Topping A50 because I just could not get the volume I want - in fact it was barely a noticeable improvement over plugging my new Sendys directly into my iPhone 11. I really don't know what max output I should be looking for...
tbacos is offline
post #4 of 9 Old 06-02-2020, 08:13 PM
Hoary's Avatar
HD6xx are pretty sensitive (~107dB?) so they are easy to drive even so nominal impedance is at 300 Ohm. ADI-2 DAC has more than enough power to drive them. I'm using low settings and typically at -30...-20 dB. Just tried to raise to -5 dB and it's way too loud for me.
With planars, check around, maybe ask on audiosciencereview (ASR) forum as it seems more people with ADI-2 DAC hanging around there. There is an RME guy visit that forum periodically.
Hoary is offline
post #5 of 9 Old 06-03-2020, 03:24 PM - Thread Starter
Quoted: 87 Post(s)
Liked: 26
Thanks for the advice. As luck would have it I found a local guy who was selling an ADI-2DAC for $800. Picking it up this evening. Hopefully it's as good as the reviews say!
N8DOGG likes this.
tbacos is offline
post #6 of 9 Old 06-03-2020, 03:28 PM
Quoted: 748 Post(s)
Liked: 398
check out mass drop for some options
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Ascend Acoustics Duo,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #7 of 9 Old 06-03-2020, 07:16 PM
Ovation's Avatar
Quoted: 196 Post(s)
Liked: 182
A Schiit Audio Jotenheim with a DAC option might fit the bill (and your budget).
Ovation is offline
post #8 of 9 Old 06-07-2020, 07:48 PM
robe619's Avatar
Good choice
https://www.audiosciencereview.com/f...hone-amp.7546/
robe619 is offline
post #9 of 9 Old 06-09-2020, 09:13 AM
chenjy9's Avatar
Quoted: 52 Post(s)
Liked: 66
I am pretty happy with my Jolida FX + Liquid Crimson setup or were you looking for an all-in-one setup?
chenjy9 is offline
Reply Headphones
