I need a headphone amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-03-2020, 12:31 PM - Thread Starter
freestonew's Avatar
hi all.
I would like to find a headphone amp under about $200 and I am so confused about which of the hundreds of models available that I should buy!
I have a Sennheiser HD 280 Pro, and even a Sennheiser 599, which sounds like garbage on my Denon small home theater setup, probably needs an amp for it.
I read even a senn 280 headphone could benefit from an amp.
Ideally, I use a computer, an iPad, the Denon, tv audio out, and even a PlayStation 2, over the weeks. I have, so far, a mini-jack cord for each system and each cord can plug into my headphone in turns.
Somehow, in my own idealistic mind, I would like to see a headphone amp that is wired into the electric socket. For my computer, I would plug the soundcard cord into this amp, and also with each cord, from my other devices, as I used them. Seemingly, no such luck, so far, in finding such an amp.
I either find a computer-driven USB amp or a battery-driven portable amp.
I never want to turn on my computer just to listen to my iPad!
Batteries? I do not want to change batteries every few days either if that is the case with a battery-operated amp. Batteries would work if I only need to change the batteries once in a while and this battery amp is of good quality.
so.
could someone recommend a good headphone amp for me?
thank you,
freestone
freestonew is offline
post #2 of 6 Old 06-03-2020, 02:33 PM
Hoary's Avatar
Drop might just got a solution for you for $149 - HELM Audio DB12 AAAMP THX Amp:
https://drop.com/buy/helm-audio-db12-aaamp-thx-amp
They just started selling it so, no idea how good/bad it is...
Hoary is offline
post #3 of 6 Old 06-05-2020, 02:47 AM
glangford's Avatar
Quoted: 874 Post(s)
Liked: 777
You can pick up a headphone amp from schiit audio for 99 bucks, one from monoprice.com for a bit less. The schiit would be a better buy.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #4 of 6 Old 06-05-2020, 05:23 AM
Liked: 7
I use a Schiit Magni 3 at my desk at home. For $99, it's a great headphone amp.
https://www.schiit.com/products/magni-1
If you want to spend a total of $200, you could also get a $99 Schiit Modi DAC.
https://www.schiit.com/products/modi-1
For a combined DAC/amp, look at their Fulla or Hel products.
If you want to do a "deep dive" into the world of personal audio, check out Head-Fi.
https://www.head-fi.org/
mnrocketry is offline
post #5 of 6 Old 06-05-2020, 07:13 PM
Mocs123's Avatar
Quoted: 631 Post(s)
Liked: 417
The JDS Atom tests very well and is only $99 - I think it may worth looking into. The THX amps made by Monoprice and Massdrop are also great amps.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, Dual Driver VBSS
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is offline
post #6 of 6 Old 06-07-2020, 02:00 PM
robe619's Avatar
I would go with either the Schiit Magni Heresey or JDS Labs Atom Or Geshelli Archel 2.5
https://www.audiosciencereview.com/f...reviews.10311/
https://www.audiosciencereview.com/f...er-champ.9438/
robe619 is offline
Reply Headphones
headphone , headphone amp
