Open vs Closed back? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Mocs123
  • 1 Post By aoaaron
post #1 of 10 Old 06-11-2020, 12:37 PM - Thread Starter
MTVhike's Avatar
Location: North Shore of central Long Island, NY (Stony Brook)
Quoted: 306 Post(s)
Liked: 63
What's the benefit of one over the other?
MTVhike is offline
post #2 of 10 Old 06-11-2020, 12:43 PM
Mocs123's Avatar
Quoted: 631 Post(s)
Liked: 417
Closed back help keep sound from leaking into the rest of the room and you for hearing sounds in the room. They are best for when you don't want to disturb others in say an office setting or on a plane. Open back have a more airy sound and better soundstage. I'd go open back if you're not going to be listening in loud environments or worried about disturbing others.
Lp85253 likes this.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, Dual Driver VBSS
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is offline
post #3 of 10 Old 06-13-2020, 06:49 AM
Liked: 2
Agreed. I have Audeze LCD's and the open back sounds phenomenal. I bought the EL-8's in the closed-back version for traveling and they don't sounds as good but great for their intended purpose (Where no one can hear.).
ElTigreJones is offline
post #4 of 10 Old 06-20-2020, 11:19 PM
bdht's Avatar
Quoted: 790 Post(s)
Liked: 378
My Alpha Primes have larger staging and more externalized imaging than alot of open headphones Ive tried.
bdht is online now
post #5 of 10 Old 06-21-2020, 12:16 AM
torii's Avatar
Quoted: 4416 Post(s)
Liked: 2596
closed back sound like you are taking a hearing test
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #6 of 10 Old 06-22-2020, 08:04 AM
Ovation's Avatar
Quoted: 196 Post(s)
Liked: 182
Closed back is more versatile if you are going to use them in a wide variety of environments and only plan to have one set.
I have both types, and use according to need—libraries, archives, at home with lots of ambient noise? Closed. At home when it’s quiet? Open.
Adjust to taste and budget.
Ovation is offline
post #7 of 10 Old 06-25-2020, 04:48 PM
Liked: 0
I found and bought a very low price open back professional headphone and i don't regret... before it arrived i was thinking that was a bad decision. It sounds amazing and... open back is more comfortable. Closed is better to clubs, open is better for home studio.
mattmiller is offline
post #8 of 10 Old 06-26-2020, 09:59 AM
aoaaron's Avatar
Quoted: 261 Post(s)
Liked: 64
To simplify things from my experience,
If you like a tight, accurate, bass-y sound with a small to medium soundstage go for a closed back. It has tighter seal, better noise isolation and can be better for immersion in loud envrionments.
If you like an open, wide, airy sound which is more comfortable to listen to and has better detail retrieval with less bass but a larger soundstage, go for an open back. Due to its open nature and width, it can be more immersive in quiet environments.
I think the common mis-conception is to address open backs as superior to closed backs, but they aren't for all purposes and tastes. They're both good at different things. I really like closed backs for anything to do with bass. I like open backs for sitting down and relaxing, but then again, if I want to sit down and relax, I'll likely use my speakers.
Also consider your use-case and if the wire or reliance on a DAC or AMP will hold you back. If so, get the THX pandas.
If I could only pick one headphone, it will always be the headphone I will use the most for my use-cases. What're yours?
Frostyboy115 likes this.
aoaaron is online now
post #9 of 10 Old 07-02-2020, 02:02 AM
snkadh's Avatar
Liked: 3
Open is better to be used in home.
snkadh is offline
post #10 of 10 Old 07-10-2020, 07:27 AM
Liked: 3
From my ears alone, the closed-back keeps the bottom end beefy and prominent.
"In a world where I feel so small, I can't stop thinking big." (Rush - Caravan)
anthonny is offline
Reply Headphones
