Netflix sync issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-12-2020, 06:31 PM - Thread Starter
Quoted: 30 Post(s)
Netflix sync issue
I am wanting to buy some budget headphones, probably the Anker Soundcore Q20's.I am concerned about a possible issue of not syncing right with netflix, streamed through my LG65B7 tv. Will be using bluetooth, which I assume will paired with my Yamaha Advantage A780. Anyone have any input or experience with this subject?
jaybo666 is offline
post #2 of 3 Old 06-13-2020, 02:15 AM
Roseval's Avatar
Quoted: 92 Post(s)
Liked: 55
This is called lip sync.
Some people are bothered by it, others not.
Due to the latency of Bluetooth expect a delay of 170 ms.
The only codec with a low latency is aptX LL (35 ms)
Observe that both TV and headphone must support it.
Bitmoreabout BT: https://www.thewelltemperedcomputer..../Bluetooth.htm
Roseval is offline
post #3 of 3 Old 06-14-2020, 02:19 AM
glangford's Avatar
Quoted: 874 Post(s)
Liked: 777
I have the LG OLED B6 and I've used my Bose QC35 with the TV sometimes. There is definitely a lip sync issue. It's a bit bothersome, but not overly so. I try not to focus on it, if you do it seems worse!
I recently hooked HDMI ARC up to my receiver so I can now use regular headphones. Problem solved.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
Reply Headphones
