Years ago I had a Klipsch ProMedia GMX A-2.1. The GMX is the downgraded version. It sounded great. Deep punchy bass, fun/lively, very dynamic, but also a smoothness to it. There was no separation between the speakers and woffer, the sound was very wholesome. It also gave the impression the sound was "coming" at you. Could do a lot of genres, liked to listen to NIN, alternative rock, industrial metal, some bass heavy trance/techno, rap.
Never listened to a pair of headphones that sounded like that. I understand that there are certain things that headphones can't do. Currently I have the HD380Pro's, B&O H9i's, Ultrasone DJ1 and 580i's, Panasonic HTF600, and owned others. They each get close from a certain point of view, but never reach it. The closest that come to it are the H9i's, but they are a bit too raw and in your head. And a bit too lively.
Source is PC, Xonar DGX, Chord Mojo.
Tried the Meze 99 Classics with a 3rd gen pads I think, did not like them. Did not sound fun/dynamic, sounded kind of tame and distant. Recessed mids.
The 580I's are close to the bass I'd like, but it's got recessed mids and don't sound wholesome. Only works with some genres.
I'd like not to spend more than I have to though. I hope I don't have to change the amp/dac.
Ideally they'd be closed circumaural.
1MORE Triple Driver.
Audeze Mobius.
Fostex TH-X00/TH900.
Audioquest.
Beyerdynamic T1 (in the T5 body).
LCD-2 Closed.
Denon AH-D7000.
Ultrasone Signature Pro?
What else should I be looking at?
Audeze Mobius.
Audioquest.
LCD-2 Closed.
Denon AH-D7000.
