NMT now with USB Slave (New: eGreat) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-24-2008, 11:37 AM - Thread Starter
Hi-Jack's Avatar
End of April a new NMT model will start spreading called the eGreat EG-M31A NMT. This is the first amongst the NMT players to future a USB Slave so copying data can be fast to the unit (see methods below). The player is loaded with no less than 512MB of memory which shows in the use of the player. The player is small and can hold an internal hard drive (square box). The rear harbors a few SPDIF style connectors for Component and then some and all cables (except network cable) are provided in the box.
We recently reviewed the unit and the results made eGreat change the colling system and layout a little of the front panel. It is fully plastic but works great, just like most NMT's do with the benefit of having the USB slave now...
Introduction / review eGreat:
http://www.mpcclub.com/banner_log.php?id=5076
Updated changes (after review):
http://www.mpcclub.com/modules.php?n...rticle&sid=540
Web Site:
http://www.egreatworld.com/en/index.asp (Still shows old design only)
Copying with USB slave
- In case you want the NMT apps installed, USB slave with windows pc's will only be possible using ext2/3 drivers for windows to read the partition. In general we recommend installing the NMT apps on a USB stick and then use the drive as NTFS.
Using the drive as NTFS will however disable FTP and SMB mapping options as the NTFS support is "read only" so copying files using other methods will not be possible this way.
Enjoy
Hi-Jack
www.mpcclub.com
Things can be interpreted in two ways - positively or exactly as it is!
You decide which leads to the real truth!
Hi-Jack is offline
post #2 of 4 Old 09-01-2008, 07:25 PM
Riot Nrrrd's Avatar
Quoted: 63 Post(s)
Liked: 51
And now there is the eGreat EG-M31B with HDMI 1.3. I will get mine in the next couple of days. I believe it has the best design & feature set of the current generation of Sigma SMP8635-based NMT-style players.
Riot Nrrrd is offline
post #3 of 4 Old 09-04-2008, 05:07 AM
Audi0phile's Avatar
I've pre-ordered one. Hope to get mine next week.
Audi0phile is offline
post #4 of 4 Old 09-04-2008, 10:53 AM - Thread Starter
Hi-Jack's Avatar
Nice choice... except for the plastic i like the unit.
I like the others too :-)
Did you check the new HDX-1000 for design?
http://www.mpcclub.com/modules.php?n...rticle&sid=663
Enjoy
Hi-Jack
www.mpcclub.com
Hi-Jack is offline
