Official SONOS owners thread - Page 62 - AVS Forum | Home Theater Discussions And Reviews
 78Likes
post #1831 of 1845 Old 02-23-2019, 08:26 AM
qirex's Avatar
Quoted: 138 Post(s)
Liked: 109
Has anyone noticed balance or EQ settings getting weird? Since a recent update the stereo pair I have in my bedroom basically won't respond to changes in balance, this is important since one of the speakers is right next to my head and the other is much farther away.
qirex is offline
post #1832 of 1845 Old 02-26-2019, 11:34 AM
Mac.Concierge's Avatar
Looking for Sonos 9.1 installer for Mac or Windows
Sonos 9.1 is the last version that would still support the Sonos Dock, which I have and still use.
Mac.Concierge is offline
post #1833 of 1845 Old 05-05-2019, 10:19 AM
billymac's Avatar
Quoted: 55 Post(s)
Looking for some help. I've given up on trying to utilize the Phono stage input on my new Denon with my Sonos Connect. Pre-outs from the AVR to the Connect introduce noticeable delay to other Sonos speakers unless I run from Turntable to the Connect FIRST, but I can't do that because the TT doesn't have a built in phono pre-amp. I had this working flawlessly on my old Pio Elite, but it was a dinosaur and had Tape In/Tape Out-- no delay even with DSP.
So, I just picked up a pre-amp: Amazon Prime Same-day to the rescue.
Here's my question:
If I have ZERO delay using my Sonos Connect with my AVR for internet radio, spotify, etc., then is it safe to say, if I insert a pre-amp between the TT and the Connect and then go line-out from Connect to my AVR, I can expect similar results with no delay?
I still don't quite fully understand why this new setup is not working. I understand that the Connect inserts a delay caused by buffering so that all speakers are in sync, but I don't quite get why it used to work before on the old AVR.
Anyway, can someone give me some reassurance on my assumption above?
TIA
"the one who has the most fun wins."
billymac is offline
post #1834 of 1845 Old 05-08-2019, 01:24 PM
gregoryperkins's Avatar
Quoted: 685 Post(s)
Liked: 254
Here's my question:
TIA
Maybe related, I can't get my Denon X6400 to play in sync with my Sonos because the Denon is processing the signal with Audyssey. If you run the receiver in direct mode, it is in sync. It's just a little delay, but enough to be maddening. The problem with this is I have 9 speakers and 4 subs and they won't run in direct mode, stereo only!
I used to use Internet radio all the time, but now it uses Heos so it becomes more difficult than just pushing a button to play your last station. Last weekend I tried plugging my stereo pre-output from the Denon into the connect but it didn't work, I got no audio. I plugged my tivo stereo out into it and it did, I was just trying to get tv audio around the house so I didn't pursue it further. The Tivo is connected via hdmi, so I'm not sure why it didn't work.
gregoryperkins is offline
post #1835 of 1845 Old 05-11-2019, 01:48 PM
nathan_h's Avatar
Quoted: 2724 Post(s)
Liked: 1956
eIf I have ZERO delay using my Sonos Connect with my AVR for internet radio, spotify, etc., then is it safe to say, if I insert a pre-amp between the TT and the Connect and then go line-out from Connect to my AVR, I can expect similar results with no delay?
That is my understanding. I do a similar thing with a bluetooth dongle that I stream content to. That dongle is connected to the line in on the Sonos Connect. The SONOS connect digital output is connected to my AVR. My AVR audio and all the other Sonos devices are in sync. Note that I do not do any processing in the AVR other than subwoofer bass management crossover stuff.
I am making the assumption that the analog output from a bluetooth receiver and the analog output from a turntable pre-amp will both behave the same way and that your AVR itself is not going to add delay (ie, through room correction software, or some kind of A/V sync setting you use for video playback, etc.).
I don't think I understand your description of your old setup well enough to hazard a guess how it was working.
nathan_h is offline
post #1836 of 1845 Old 06-24-2019, 01:44 PM
GoZags13's Avatar
Quoted: 174 Post(s)
Liked: 91
Anyone know what spec is require for the new Sonos Amp to power 6 speakers that aren't from them? It seems ridiculous to be forced to buy their speakers in order to use 6 speakers. Especially with outdoor speakers where the sound quality is not near as important (at least for me).
Denon X4300H; Sony XBR75 900E; Definitive Technology RLS-II/DI 5.5LCR/DI 5.5R; NHT SW12
GoZags13 is offline
post #1837 of 1845 Old 06-24-2019, 09:16 PM
qirex's Avatar
Quoted: 138 Post(s)
Liked: 109
Your best bet is probably to use a Connect along with a multi channel home distribution amp.
qirex is offline
post #1838 of 1845 Old 06-25-2019, 07:15 AM
beastaudio's Avatar
Quoted: 5541 Post(s)
Liked: 5370
Yep! I have been doing it this way for close to 10 years now with a Connect connected to my AVP, which allows for my HT to play off zone 1, then an 8 channel 4 zone Sherbourne amp connected via zone 2, which handles 3 different setups, all outdoors, but could easily be indoor/outdoor for your specific needs. Works fabulously and with the modern receivers from Denon/Marantz, Yammy, Onkyo, and even the boutique higher end stuff, their "Apps" for AVR control via your phone typically allow for separate volume control for your main zone and secondary zone. The only downside to this you don't get more granular control of the volumes for each separate room like you would with all sonos speakers as an alternative. Since three of my zones are outside, I dont need to control each zone's volume independently so a single volume control for all three is fine for me. If you really wanted to you could install an in-line attenuator for different zones/speakers if you really needed it.
Another method is an independent multi-zone amp with a Connect for each room or stereo pair you want independent control of, then install the outdoor or in-ceiling speakers of your choice from there, but from a cost standpoint you'll end up being about where you would be if you just bought sonos speakers to begin with. This way does however allow you to choose your own speakers, so if you ever were to change to a different system that is non-sonos and sold off your connects, you would still have a house full of speakers already wired for what may come around next
beastaudio is online now
post #1839 of 1845 Old 06-25-2019, 01:28 PM
Quoted: 685 Post(s)
Liked: 254
You can always get a 4 speaker selector. Most amps can handle running 2 sets of speakers without a problem. They just set up the speakers in serial. I have done that for speaker testing. Monoprice has them for ~$20.
https://www.monoprice.com/category/a...me-controllers
I have my connect going to my 13 speaker avr (no amp), but I have to run it in direct if I want it in sync with the Sonos system. The Audyssey processing adds enough delay that it is just noticeable, so my 4 subs sit idle...
post #1840 of 1845 Old 06-26-2019, 10:42 AM
qirex's Avatar
Quoted: 138 Post(s)
Liked: 109
I've always wondered why Sonos doesn't make something like the HEOS Drive, it seems like kind of a no-brainer but their entire custom install strategy seems to be "buy a bunch of Amps and rack mount them."
qirex is offline
post #1841 of 1845 Old 06-27-2019, 07:22 AM
tunaman00's Avatar
Hoping someone here can provide me guidance. I have multiple Echo Dots (v1) throughout the house (2 in separate kids rooms, 1 in master and 1 outside). The kids use them to ask questions, set timers and play music directly thru the poor internal speaker (they don't care how good or bad it sounds). The outside echo dot is paired with a Sonos Amp which powers the outdoor speakers. I can walk outside and say 'Alexa play Pandora Rolling Stones Radio on Patio (Sonos Amp name)' and it works great. I have two annoyances I cannot seem to solve.
First, if I am playing any sound on the outdoor speakers via the Sonos Amp and someone speaks to an Echo Dot in another location, the outdoor (Sonos Amp) volume will dim (nearly mute) while Alexa listens and responds in the other location. Can the 'dimming' via the Sonos Amp be stopped when the 'other' echo dots are used but still allow it to dim when using the outside Echo Dot? I have searched, but cannot seem to find a solution to this. Thoughts?
Secondly, via the outdoor Echo Dot, I can ask Alexa to turn volume up or down on 'Patio' (Sonos Amp Name) but the volume 'steps' seem too steep. I try words like 'a little' or 'a lot' but they don't seem to have an effect even though Alexa does not balk at them. I then need to use the Sonos app to fine tune the volume in the middle. Is there a way to narrow the volume steps? I have also searched, but cannot seem to find a solution to this either. Thoughts?
Thank you in advance for any useful insights.
Nevermind...found my answer:
https://en.community.sonos.com/amazo...ivated-6794818
Not sure why I couldn't find this in my previous searches.
tunaman00 is offline
post #1842 of 1845 Old 07-13-2019, 09:07 AM
sooke's Avatar
Quoted: 116 Post(s)
Liked: 70
Has anyone heard whether the Sonos One will get Alexa "drop-in" support? Is there an ETA? Thanks.
Panasonic TC-P60ZT60 plasma panel
Sony BDP-S5500 Blu-ray player
Arris DCX3600-M DVR
Yamaha RX-V650 AVR
XBox One
URC MX-780 remote control
sooke is offline
post #1843 of 1845 Old 07-22-2019, 05:27 PM
Sittler27's Avatar
Quoted: 1143 Post(s)
Liked: 86
Joining Personal Hotspot Wifi
I unplugged my home router. I put up a personal hotspot using another phone. This hotspot is named the same as my home network and I also used the exact same password.
My phone connected to the hotspot as a wifi connection no problem; however, my Sonos Amp did not.
So I went to the Sonos app on my phone while on the hotspot wifi and tried to add the Sonos Amp (as per the item in the app about how maybe my wifi/router settings may have changed).
Now here's the interesting thing, when it asks me to press the Connect button on the back of the Amp, the app immediately acts as if it finds the Amp and even shows it's MAC address in the app. But then when it starts to configure and set it up it eventually just errors out every time.
So I also tried naming the personal hotspot put up by the other phone to another name than my home wifi, but then I couldn't even get the Sonos app to recognize the Amp when I press it's Connect button.
So I'm thinking it is somehow on the personal hotspot network, but yet it's not.
Is it just a matter of leaving the hotspot on with my home router shutoff for a longer period of time and it will eventually connect to it?
Or, maybe somehow Sonos cannot connect to wifi hotspots (albeit, not sure how it would know the difference)?
Sittler27 is offline
post #1844 of 1845 Old 07-22-2019, 06:33 PM
Sittler27's Avatar
Liked: 86
Ok well looks like it finally just worked. It did it on it's own after trying again for the 3rd time (total times tried about 10).
Very flaky, so I hope it works when I transport this experiment where there really is no real wifi at the cottage.
Will be testing it a few times this week to see if it holds.
Why doesn't it just work the first time? Why does it need to be on the 10th?
post #1845 of 1845 Old 07-24-2019, 08:21 AM
Quoted: 685 Post(s)
Liked: 254
I've done a similar thing at an apartment with Sonos using a Linksys that is configured the same as my Netgear at home, connected to broadband. It worked great, although the Sonos music server wasn't present. I just turned Sonos on and recalibrated the speakers for the room.
amp , Marantz Pm6004 Integrated Amplifier , Sonos , Sonos Playbar Tv Soundbar And Wireless Speaker For Streaming Music
