FANTEC TV-LHD Media Player Full-HD 1080p / WD Clone Killer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 05-06-2009, 01:49 AM - Thread Starter
ropetry's Avatar
Hello,
anyone knows this new device. It look like a WD TV with LAN and Composite.
h**p://www.fantec.de/html/de/2/artId/__1416/gid/__110090114090/article.html
The specs are very promising and the Manual is here.. h**p://images.fantec.de/FANTEC_TV-LHD_online.pdf
price in Germany would be near 140 Euro.. The WD TV is at 100 Euros + LAN Adapter you are at 130 Euros.. So this could be an option.
hope to here some comments..
bye
ropetry is offline
post #2 of 19 Old 05-06-2009, 03:20 AM - Thread Starter
ropetry's Avatar
Here some specs..
DTS - DOWNMIXING !!
Product details
item no.: 1416
model no.: FANTEC TV-LHD
specification: HDMI, LAN-Streaming, USB-Host, MKV, H.264
connectors: External: 1x USB host connector
HDMI connector (Audio / Video)
AV out (Audio / Video)
Optical Out (Audio)
Coaxial Out (Audio)
LAN RJ45 (10 / 100 mbps)
operating system: Windows 2000/XP/VISTA , Linux, MAC OS
chipset: Sigma Design
supported formats: File fystem for USB-Devices: FAT32 / NTFS
Supported media files:
1. Audio:
MP3, OGG, WMA, AAC, WAV, AC3, FLAC, M4A, PCM
2. Video:
MPEG 1, MPEG 2, MPEG 4, WMV 9, MPEG 2 HD TS, MPEG 4 ASP,
MKV (H.264 + AAC, AC3, MP3)
VC-1
DivX (3.11, 4.x , 5.x)
Xvid
MOV
(*.avi, *.mkv, *.wmv, *.mpg, *.dat, *.vob, *.ifo, *.iso, *.mp4.tp, *.trp, *.ts, *.m3t, *.m3t, *.m2ts, *.mov)
3. Photo:
BMP, JPG
4. Subtitle:
TXT: SMI, SUB, SRT, AQT, UTF, TXT
IMAGE: SUB (with IDX)
resolution: Composite: PAL / NTSC
HDMI: 576p / 720p / 1080i / 1080p
material / color: plastic / black
features: - Media player with remote control for USB & network playback
- Multimedia-content playback on TV, LCD, beamer & hifi stereo
- Supports various multimedia formats (video, music & pictures)
- Supports high definition video formats MKV & H.264
- Streaming of multimedia-content via network
- Supports peer to peer connections to one computer
- Direct access to your network-shares via TV
- Easy Plug & Play of USB-devices
- HDMI output for digital video quality in 720P, 1080i & 1080P
- Digital audio out for finest surround-sound (opt. & coax.)
- USB host to connect USB pen drives & external hard disks
- 10/100 Mbps LAN network port (hub, switch, router, P2P)
accessories including: remote control / battery
AV cable
external power supply
manual
country of origin: China
customs tariff- no.: 84733080
dimensions (w x d x h): 130 x 120 x 40 mm
Power Supply: input: 100-240V ~50-60Hz, 0,7A
output: +5 V, 3.0A, 15 Watt
certifications: CE, FCC, RoHs
weight / piece (kg): 1.0
ropetry is offline
post #3 of 19 Old 05-06-2009, 04:56 AM
Fuelbomb's Avatar
Fuelbomb is offline
post #4 of 19 Old 05-06-2009, 05:08 AM
Spookstah's Avatar
Spookstah is offline
post #5 of 19 Old 05-06-2009, 05:32 AM - Thread Starter
ropetry's Avatar
I will get my Device on next Monday - Wednesday.. Just ordered it and got a confirmation for next week. 8-)
I will report how it works.. If i should test some special things, please write..
bye
ropetry is offline
post #6 of 19 Old 05-06-2009, 05:39 AM
Fuelbomb's Avatar
Excellent! I ordered one too and perhaps I will be able to receive it next week, probably on friday.
Fuelbomb is offline
post #7 of 19 Old 05-06-2009, 05:53 AM
GreenDream's Avatar
I thought the Egreat M34 was supposed to be the WD killer? Seems WD must be doing something right when you get multiple machines being billed as the WD killer. LOL
GreenDream is offline
post #8 of 19 Old 05-06-2009, 06:07 AM
BigBoppa's Avatar
It has ifo-Support (specs.) - Does this mean dvd-menu support?
I think WD have to hurry with a maior software update...
BigBoppa is offline
post #9 of 19 Old 05-06-2009, 06:19 AM
Fuelbomb's Avatar
I hope so! What else could it be?
And I'm not certain if it's so simple to add ifo-support for the wdtv...
Fuelbomb is offline
post #10 of 19 Old 05-06-2009, 06:21 AM
toolman2k10's Avatar
is it a sayabased NMT player ? that would be a major plus......otherwise its another standalone player with maybe not so great support....
toolman2k10 is offline
post #11 of 19 Old 05-06-2009, 07:01 AM
BigBoppa's Avatar
The SD 8623 is a low cost entry level chip in opposite to the 8634 in the WDTV.
So the WDTV should be able to do all the things the fantec can do!
BigBoppa is offline
post #12 of 19 Old 05-06-2009, 07:04 AM
Fuelbomb's Avatar
That's correct, but the differences is not big I suppose (from what I saw on the Sigma Designs HP). But Fantec stated that the LHD can play *.ifo and *.flac... So, can the WDTV play this also with a new FW??
Fuelbomb is offline
post #13 of 19 Old 05-06-2009, 07:47 AM
high_definitely's Avatar
In addition to the inferior Sigma chip, this device has considerably less RAM than the WD TV-HD, too.
Memory: SDRAM 128M, Flash: 16M
According to this and earlier posts, the WD TV-HD has
192MB SDRAM, 16MB flash
As a comparison, the Popcornhour specs: 256MB SDRAM, 32MB flash
So if (still no definite answer to this by the WD guys) RAM is the limiting factor when it comes to H.264 playback and the number of reference frames supported, this device should be even less forgiving than the WD TV-HD in this respect.
high_definitely is offline
post #14 of 19 Old 05-06-2009, 07:53 AM
Fuelbomb's Avatar
That's really, really interesting! I think, we will see what the player can play, when the LHD is available in stores.
Fuelbomb is offline
post #15 of 19 Old 05-28-2009, 02:17 AM
bheirman's Avatar
Originally Posted by ropetry View Post
Here some specs..
DTS - DOWNMIXING !!
Where did you get this info from? It doesn't support DTS downmixing..
bheirman is offline
post #16 of 19 Old 05-28-2009, 04:29 AM
buda_can's Avatar
See the user manual page 6 (English).
In the Audio section it indicates DTS down mixing and pass through.
buda_can is offline
post #17 of 19 Old 06-03-2009, 12:48 AM - Thread Starter
ropetry's Avatar
Hello,
got mine today.. will check what it cn and what not this evening.
bye
ropetry is offline
post #18 of 19 Old 06-03-2009, 02:05 AM
Jagoda's Avatar
So, a bit slower Sigma chip and no DTS downmixing ( looks like they are lying in the manual).
quote:
It does not support DTS downmixing.. I just tested one. This makes it a lot less interesting product
Next player please !
Jagoda is offline
post #19 of 19 Old 06-04-2009, 02:41 AM
daskino's Avatar
cant wait to hear your verdict on it
daskino is offline
