Apple TV owners' thread. - Page 420 - AVS Forum | Home Theater Discussions And Reviews
 27831Likes
post #12571 of 23752 Old 02-22-2018, 12:23 PM
steelman1991's Avatar
Quoted: 454 Post(s)
Liked: 219
Originally Posted by Andrew Stirling View Post
The only way Infuse will stutter with uhd rips is if you’re using WiFi or if you’ve got some kind of internal networking issue. Definitely use Ethernet though.
Not my experience Andrew. Both Infuse and MrMC choke on several UHD rips (Transformers 1-4 in the 63 - 67 Mb/s range) all buffer/choke badly at various points on a Gigabit wired connection.
Plex, Kodi and SPMC all play the files on the same network from a Shield - flawlessly (wired from the same switch).
I will admit I'm no network expert, so if anyone wants to chip in with troubleshooting advice - feel free. I have tried swapping the cables from the Shield to the Apple - without success.
Epicurus likes this.
steelman1991 is offline
post #12572 of 23752 Old 02-22-2018, 12:30 PM
Quoted: 1587 Post(s)
Liked: 891
Originally Posted by atbear View Post
Any projected timeframe for when the Apple TV 4K firmware update will be released (full public release) that addresses the Sony Dolby Vision compatibility issue? Thanks
Probably in the Spring. Just guessing based on the fact that we are just on beta 3 and they come out every two weeks.
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is offline
post #12573 of 23752 Old 02-22-2018, 12:36 PM
Quoted: 44 Post(s)
Does anyone know if you buy the "Dark Knight Trilogy" from iTunes, do you get them in 4k? The films are like $20 individually, so $35 for the trilogy would be a good deal - but I can't tell for sure if I get 4k or not.
3nsdan 2 is offline
post #12574 of 23752 Old 02-22-2018, 12:39 PM
ChicagoChris's Avatar
Quoted: 263 Post(s)
Liked: 165
Thanks to all who suggested new cables for my ATV issue. New ultra HDMI cables worked. No drops or sparkles. Just $7 cable and running Dolby vision beautifully.
Guess my 'new' cables from the fall weren't new enough.
Sent from my iPhone using Tapatalk Pro
ChicagoChris is offline
post #12575 of 23752 Old 02-22-2018, 12:42 PM
Liked: 891
In the iTunes Store if you click on each of the included movies each on says 4K Dolby Vision. Look for yourself but that?s what I?m seeing.
Mike
m_snow is offline
post #12576 of 23752 Old 02-22-2018, 12:49 PM
Quoted: 44 Post(s)
Clicking on the individual movies DOES look like they are 4k Dolby Vision just like you say, but the trilogy 'wrapper' says HD... I was curious if anyone had actually bought it and could confirm. I'm not trying to cross my fingers and spend $35 lol
3nsdan 2 is offline
post #12577 of 23752 Old 02-22-2018, 12:50 PM
lujan's Avatar
Quoted: 4365 Post(s)
Liked: 2448
Yes, I bought "The Dark Knight" trilogy in HD on iTunes and got the 4k HDR versions but you can only watch them in 4k on the Apple TV 4k. Since you're buying the HD versions, they don't port over to Vudu in UHD for instance.
rlb and leonmckee like this.
lujan
516 Ultra HD
724 HD
4 SD
lujan is offline
post #12578 of 23752 Old 02-22-2018, 12:51 PM
Quoted: 44 Post(s)
Awesome thanks!
3nsdan 2 is offline
post #12579 of 23752 Old 02-22-2018, 12:55 PM - Thread Starter
bodosom's Avatar
Quoted: 1884 Post(s)
Liked: 1426
There are two questions here so two answers:
  • One might guess six weeks from b1 (24-Jan). You can [look at this timeline] and draw conclusions.
  • tvOS 11.3 will probably still have the Sony DV fix, but it might not be as good as you wish.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500/LG C8
bodosom is online now
post #12580 of 23752 Old 02-22-2018, 01:26 PM
Liked: 891
Also iTunes gives free upgrades to titles bought in HD to the highest quality they have. It’s a pretty awesome deal and if you can find the redeem codes for sale online it’s even cheaper than $35.
Mike
m_snow is offline
post #12581 of 23752 Old 02-22-2018, 01:41 PM
Ph8te's Avatar
Quoted: 6281 Post(s)
Liked: 5920
Do you have timestamps where Infuse chokes? I just watched a little bit of a Transformers rip the other day and it was flawless. I haven’t run into a rip it wouldn’t play yet (outside of ones that were corrupt).
Ph8te is offline
post #12582 of 23752 Old 02-22-2018, 02:07 PM
andygiddings's Avatar
Quoted: 118 Post(s)
Liked: 79
I don't know if you can download an app which will allow you to measure your wired network speed on the two devices - something like TT Client and Server would work, just don't know whether they are in the TV Appstore and Playstore. At least that would eliminate bandwidth issues. Are you getting the same result if you run Speedtest on both? Won't measure your internal network though
Room 1 system: Paradigm Reference Active 7.2 system, Anthem AVM50, Oppo BDP-103. Pioneer Elite 610HD. Room 2: Samsung 65HU8550 with SEK3500, Paradigm Monitor 5.1 system, Denon AVR-X2400H, Oppo BDP-203, Nvidia Shield, Apple TV 4k
andygiddings is offline
post #12583 of 23752 Old 02-22-2018, 02:18 PM
Liked: 891
Speedtest by Ookla has both a Shield and ATV version. ATV is free on the AppStore. The Shield version can be found and sideloaded from apkmirror.com. It’s pretty accurate and let’s you select the same servers so there will be no latency differences.
Mike
m_snow is offline
post #12584 of 23752 Old 02-22-2018, 02:29 PM
mutelight's Avatar
Quoted: 2182 Post(s)
Liked: 2466
That will measure WAN speed but it sounds like they are talking about playing files on the local network so would want to measure that throughput. Not many have 1Gbps internet connections to max out a 1Gbps NIC.
mutelight is offline
post #12585 of 23752 Old 02-22-2018, 02:50 PM
dianebrat's Avatar
Quoted: 360 Post(s)
Liked: 323
and this is why we keep saying it when the naysayers keep saying "but my cables are fine for all my other stuff!"
dianebrat is offline
post #12586 of 23752 Old 02-22-2018, 03:44 PM - Thread Starter
bodosom's Avatar
Liked: 1426
Air Video HD
post #12587 of 23752 Old 02-22-2018, 04:23 PM
eternal21's Avatar
Quoted: 126 Post(s)
Liked: 58
Where would I report a bug I found in current beta software? If you tap the touchpad, a progress bar shows up on the bottom. In previous release the counter on the right bottom side would show you the time remaining. Currently it shows you the total time of the movie. Pretty sure it's a bug, because if you tap the touchpad again, the number used to show you what time the movie would end, so if it was 8PM and there was 1 hour left in the movie it would show 9PM. Currently the second tap will show you the time the movie is supposed to end, but it's calculated using the total length of the movie, so if it's 8PM and there is 1 hour left in a 2 hour movie, it will show you 10PM instead of 9PM. Seeing it on Netflix on Apple 4K TV latest beta (needed it to get Dolby Vision working on my A1E).
Sony XBR-65A1E | AppleTV 4K | PS4 Pro | PSVR
eternal21 is offline
post #12588 of 23752 Old 02-22-2018, 04:30 PM
drewTT's Avatar
Quoted: 1998 Post(s)
Liked: 2150
Would it kill Apple to add a simple time display somewhere in the interface? Maybe when you swipe down, in the top right corner....
LG OLED65E8 | Plinius Hiato | Dynaudio Contour 20 | Dynaudio Stand 6 | REL T/9i | PS Audio DirectStream Junior | Furman IT-Reference 15i | Sony PS4 Pro | Synology DS916+ | Apple TV 4K | BDI Mirage | NEEO | Focal Shape 40 | iFi Pro iDSD | iFi Pro iRack | roon
drewTT is offline
post #12589 of 23752 Old 02-22-2018, 04:40 PM
rsonnens's Avatar
Quoted: 602 Post(s)
Liked: 453
You can ask seri the time
rsonnens is offline
post #12590 of 23752 Old 02-22-2018, 04:41 PM
drewTT's Avatar
Liked: 2150
Yeah I know that.
drewTT is offline
post #12591 of 23752 Old 02-22-2018, 05:06 PM
ROMIL's Avatar
Quoted: 512 Post(s)
Liked: 238
I've seen the same bug. Used to work fine before the 11.3 beta, now it's broken.
eternal21 likes this.
ROMIL is offline
post #12592 of 23752 Old 02-22-2018, 06:53 PM - Thread Starter
bodosom's Avatar
Liked: 1426
Bugs in beta software are reported with Feedback Assistant. Since I see a likely bug I'll report it.
However this bug isn't quite as described.
In 11.3b3 the count-down display is not decrementing by seconds (maybe 2.5s) so you have to:
1) tap and wait for the progress bar to be removed and then tap again, which will decrement remaining time by some amount, or
2) touch the trackpad. As long as you're touching the trackpad the progress bar will stay up and the counter will decrement (but not by seconds).
If you tap twice the progress bar changes to time of day mode.
post #12593 of 23752 Old 02-22-2018, 07:28 PM - Thread Starter
bodosom's Avatar
Liked: 1426
And it seems to be content dependent. That complicates things.
post #12594 of 23752 Old 02-22-2018, 07:47 PM
Quoted: 299 Post(s)
Liked: 142
I did an update today and now a few movies are missing from the 4K HDR section. Has this happened to anyone? The ones missing are: Dark Knight Rises, Live Die Repeat, Harry Potter 1,2,5,7. So my total was 154 titles in 4K HDR before updating, then after updating, it says 148 titles. I do own those 6 titles in Vudu in UHD, so it is weird that they just show as only HD now? any ideas?
Theater: Denon AVR-X8500H, Epson 4040, Panasonic DMP-UB900, Roku 4, ATV4K, Oppo UDP-203
Living Room: Denon AVR-X4500H, Samsung UN65JS9500, Samsung K8500, Roku Ultra, ATV4K, Oppo UDP-203
Master: Sony XBR-55A1E OLED, LG SJ9, ATV4K, Panasonic DMP-UB900, Oppo UDP-203
Game: LG OLED 55C6P, LG UP970, Samsung K8500, Philips BDP7501, Marantz SR7010, Oppo 103
Bejoy is offline
post #12595 of 23752 Old 02-22-2018, 09:44 PM
rjhseven's Avatar
Quoted: 572 Post(s)
Liked: 93
Originally Posted by NashGuy View Post
I had meant to say what you did- with 4K at 32 GB. Good, that future proofs me for awhile on interest with the gigabit port.
Memphis Tiger Fan-Sports enthusiast
rjhseven is offline
post #12596 of 23752 Old 02-22-2018, 09:52 PM
rjhseven's Avatar
Quoted: 572 Post(s)
Liked: 93
Not if you are hearing impaired
rjhseven is offline
post #12597 of 23752 Old 02-22-2018, 10:48 PM
Quoted: 55 Post(s)
Liked: 71
Could be the termination of your internal wiring. You should pull your wall plate and check the head end wiring too. Gigabit means nothing unless it’s actually installed correctly. I’ve seen some termination issues that were nightmarish to clients that connected to offsite servers with several disconnects per day. Reterminated both ends 0 problems since then. It can also be cheap parts that are failing. You can’t go wrong with Leviton for the CAT5/6 ends. I’ve probably replaced almost every other brand at one point or another. Skimping on wire, patch panels or CAT 5/6 connectors just isn’t worth the couple of $ you “save”.
You could run speed test all day long on a poorly terminated network and get great results, but every once in a while you can have a blip in connectivity for a moment and in your case video problems might come up. Hard to diagnose via Speedtest a since it works 99.9% of the time.
rlb likes this.
Houdini415 is offline
post #12598 of 23752 Old 02-23-2018, 12:33 AM
Quoted: 222 Post(s)
Liked: 202
aesthetically, it's cleaner without a clock...
Also, if you tap the touchpad as you are watching the film it will show you the progress bar, tap it again and it will show the current time and the movie ending time...
Uppsalaing is offline
post #12599 of 23752 Old 02-23-2018, 02:01 AM
Liked: 891
Yes it's happening to a LOT of people. It's all over the Google+ chat rooms. About 10% of my library, all DV or HDR 4K, was "downgraded". Some show up wrong in the description others don't play DV or HDR when they are supposed to and a couple are now described as DV and SD but are just SD not even 4K anymore. I'm hoping it's just a glitch but since all these other users that are reporting it are not in the beta it sounds more like an Apple database/infrastructure issue and not on the device.
Mike
m_snow is offline
post #12600 of 23752 Old 02-23-2018, 05:45 AM
kbmb's Avatar
Quoted: 980 Post(s)
Liked: 765
Originally Posted by leonmckee View Post
Try programing your remote to switch away from any device that uses HDCP, if possible, before you shut down everything. This helped me at some point in the past so I've just made it a best practice.
Leon McKee
Please share your commands if they work.
Another update......I "think" that @leonmckee suggestion is helping. I have for the past 2 days been able to turn on my TV and the ATV was fine. I was also able to turn on the TV multiples times per day and it was fine. I did have the one instance yesterday where it wasn't......but I'm thinking this switching to a different input has helped a bit. Still think it's something ultimately Apple needs to solve, as more and more people on the Apple forum threads I follow report they have similar issues. Thanks again for the suggestion.
leonmckee likes this.
kbmb is offline
apple 4k tv , Apple Tv Mc572ll A , Apple Tv Md199ll A , grainy , hdr , issue , mgy52ll , mqd22ll , Samsung
